查看: 847|回复: 4
[求助]:能用isClosed闭合Spline吗?
发表于 2006-5-29 21:10:48 | 显示全部楼层 |阅读模式
我用Spline画了一条渐开线
AcDbSpline *pSpline=new AcDbSpline(PointArray);
接下来用:
pSpline->isClosed() ==kTrue;
本来想强制将其封闭,
结果怎么也不行,
请问错在哪儿了???
非常感谢~~~~~
发表于 2006-6-3 19:15:05 | 显示全部楼层
因为这个函数只是用来查询spline是否闭合,如果是则返回kture。
而不能用来改变spline的闭合状态。
发表于 2006-6-4 00:39:33 | 显示全部楼层
这是查询属性,而不是操作方法,应该在其构造函数有一个曲线闭合的参数。
发表于 2006-6-4 18:21:15 | 显示全部楼层
isClosed()使用来判断的吧
 楼主| 发表于 2006-6-5 10:09:04 | 显示全部楼层
谢谢各位老大~~
我参考了一个函数:
//封闭SPLINE
void setClosed(AcDbSpline *pSpline)
        if (!(pSpline))
                return;
        int         degree;
        Adesk::Boolean  rational;
        Adesk::Boolean  closed;
        Adesk::Boolean  periodic;
        AcGePoint3dArray controlPoints;
        AcGeDoubleArray  knots;
        AcGeDoubleArray  weights;
        double    controlPtTol;
        double    knotTol;
        pSpline->getNurbsData(degree, rational, closed, periodic,
                controlPoints, knots, weights,
                controlPtTol, knotTol);
        if(closed == Adesk::kTrue)
                return;
        closed = Adesk::kTrue;
        pSpline->setNurbsData(degree, rational, closed, periodic,
结果挺好使的。
GMT+8, 2026-11-5 03:49 , Processed in 0.430918 second(s), 40 queries , Gzip On.
