查看: 1150|回复: 2
[求助]:acedDragGen()动态拖动问题------实体显示
发表于 2006-5-30 09:58:53 | 显示全部楼层 |阅读模式
我用acedDragGen(ss, "\n添加点:", 0, dragprosess, rpt);实现的动态拖动,并在dragprosess()函数中修改了选择集(ss)内实体的的数据。问题出现了:
   捕捉关闭状态:当我拖动实体时实体能够显示出来,但当鼠标不动时实体不显示。
   捕捉打开状态:实体正常显示。
我在dragprosess()函数中加了如下代码:
        acedSSLength(ss,&len);
        for(long j = 0; j < len; j++ )
                acedSSName(ss,j,ent);
                acedRedraw(ent,1);
也不管用,
请大侠指点,多谢了!!
发表于 2006-5-30 15:10:49 | 显示全部楼层
估计是acedRedraw()的参数的问题,必须成对调用。帮助文件中这样解释
acedRedraw() calls must be made in matched pairs. Every call with a mode of 2 must be followed at some point by a call with a mode of 1. Every call with a mode of 3 must be followed at some point by a call with a mode of 4. Mismatched calls such as a call with a mode of 3 followed by a call with a mode of 1 are not allowed. (This is a change from the previous behaviour of this function that was necessary for display performance optimization.)
 楼主| 发表于 2006-5-30 16:08:32 | 显示全部楼层
但是就是不加acedRedraw()也是一样的毛病啊,
如果acedRedraw()运用正确能解决这个问题吗?好象也解决不了。
有个想法:就是模拟捕捉操作,到底捕捉操作后台执行了些什么呢???
GMT+8, 2026-11-5 03:52 , Processed in 0.574054 second(s), 36 queries , Gzip On.
