查看: 1486|回复: 2
[原创]: 示例:连接直线为优化多义线
发表于 2006-7-2 12:42:45 | 显示全部楼层 |阅读模式
[php]
Sub jline()
    Dim obj As AcadLine, pnt
    Dim objs As New Collection
    Dim selobj As AcadLine
    Dim pnts As New Collection
    Dim i, j
    ThisDrawing.Utility.GetEntity obj, pnt
    Dim ss As New TlsSelectionSet
    pnts.Add obj.StartPoint
    pnts.Add obj.EndPoint
    objs.Add obj
    '从选择线起点找起,一直到没有连接的直线或一个以上的直线为止
    Do While True
        ss.Init
        ss.Filter.SetData 0, "line", -4, "<or", 10, pnts(1), 11, pnts(1), -4, "or>"
        ss.SelectObject acSelectionSetAll
        If ss.Count = 2 Then
            If ss.Item(0) Is obj Then
                Set obj = ss.Item(1)
            Else
                Set obj = ss.Item(0)
            End If
            If isChild(objs, obj) Then Exit Do
            If obj.StartPoint(0) = pnts(1)(0) And obj.StartPoint(1) = pnts(1)(1) Then
                pnts.Add obj.EndPoint, , 1
            Else
                pnts.Add obj.StartPoint, , 1
            End If
            objs.Add obj, , 1
        Else
            Exit Do
        End If
    Loop
    '从选择线终点找起,一直到没有连接的直线或一个以上的直线为止
    Set obj = selobj
    Do While True
        ss.Init
        ss.Filter.SetData 0, "line", -4, "<or", 10, pnts(pnts.Count), 11, pnts(pnts.Count), -4, "or>"
            Else
            End If
            If obj.StartPoint(0) = pnts(pnts.Count)(0) And obj.StartPoint(1) = pnts(pnts.Count)(1) Then
            Else
            End If
            objs.Add obj
        Else
            Exit Do
        End If
    Loop
    Dim dots() As Double
    ReDim dots(pnts.Count * 2 - 1)
    For i = 1 To pnts.Count
        For j = 0 To 1
            dots((i - 1) * 2 + j) = pnts(i)(j)
        Next
    Next
    ThisDrawing.ModelSpace.AddLightWeightPolyline dots
    For Each i In objs
        i.Delete
    Next i
End Sub
Function isChild(objs As Variant, obj As Object)
Dim i
For Each i In objs
    If i Is obj Then isChild = True: Exit For
Next
End Function
[/php]
发表于 2006-7-10 13:48:13 | 显示全部楼层
如果支持框选若干线
自动连接就好了。(可能包含一条以上独立线)
还有不支持PLINE
发表于 2006-7-11 23:17:21 | 显示全部楼层
呵呵,几乎就是消除伪节点,不过这个例子简单多了
GMT+8, 2026-11-22 09:18 , Processed in 0.136656 second(s), 12 queries , Gzip On, File On.
