查看: 1272|回复: 3
[VBA程序]:图形安全操作,保持图元不被拷贝走
发表于 2006-7-6 10:32:03 | 显示全部楼层 |阅读模式
想实现以下的功能,主要是对知道句柄的实体进行操作,使那些实体在COPY,MOVE等操作中被过滤掉不被操作。目前在BeginCommand命令中控制的不好,使用.PickfirstSelectionSet.Count将把所有的选择物体进行过滤掉了,在命令发出之后进行操作就无法控制了,请各位大侠给指点一下。*-*4
发表于 2006-7-6 17:57:24 | 显示全部楼层
Sub tt()
    Dim obj As AcadEntity, pnt
    Dim xt(1) As Integer, xd(1)
    ThisDrawing.Utility.GetEntity obj, pnt
    xt(0) = 1001: xd(0) = "Tls_NoCopy"
    xt(1) = 1000: xd(1) = obj.Handle
    obj.SetXData xt, xd
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
On Error Resume Next
    If CommandName = "COPY" Then
        Dim ss As AcadSelectionSet
        Dim ft(0) As Integer, fd(0)
        Dim xt, xd, i
        ThisDrawing.SelectionSets("Tls_NoCopy").Delete
        Set ss = ThisDrawing.SelectionSets.Add("Tls_NoCopy")
        ft(0) = 1001: fd(0) = "Tls_NoCopy"
        ss.Select acSelectionSetAll, , , ft, fd
        For Each i In ss
            i.GetXData "Tls_NoCopy", xt, xd
            If i.Handle <> xd(1) Then
                i.Delete
            End If
        Next i
        ss.Delete
    End If
End Sub
 楼主| 发表于 2006-7-7 11:00:07 | 显示全部楼层
谢谢斑主,调试完成后我将最终成果发上来
发表于 2006-7-12 20:37:37 | 显示全部楼层
确实有很多高手
GMT+8, 2026-11-3 03:14 , Processed in 0.449077 second(s), 38 queries , Gzip On.
