查看: 810|回复: 0
[ARX程序]:VBnet生成块
发表于 2006-7-17 18:19:34 | 显示全部楼层 |阅读模式
用VBnet生成一个块,insert的时候总是提醒没关闭,Transaction自动关闭,不知哪个没有关闭,代码如下:
<Autodesk.AutoCAD.Runtime.CommandMethod("CREATEB")> _
Public Sub CreateEmployeeDefine()
        Dim db As Database = HostApplicationServices.WorkingDatabase()
        Dim trans As Transaction = db.TransactionManager.StartTransaction()
        Try
            Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
            Dim myBtr As BlockTableRecord = New BlockTableRecord()
            myBtr.Name = "EmployeeBlock"
            Dim myBtrId As ObjectId
            myBtrId = bt.Add(myBtr)
            Dim btr As BlockTableRecord = trans.GetObject(myBtrId, OpenMode.ForWrite)
            Dim layerId As ObjectId = New ObjectId()
            layerId = CreateLayer()
            Dim center As Point3d = New Point3d(10, 10, 0)
            '生成一个圆
            Dim Circle As Circle = New Circle(center, Vector3d.ZAxis, 2.0)
            Circle.LayerId = layerId
            Circle.ColorIndex = 1
            btr.AppendEntity(Circle)
            '生成一个Mtext
            Dim Mtext As MText = New MText()
            Mtext.Contents = "lihengwang"
            Mtext.Location = center
            Mtext.LayerId = layerId
            Mtext.ColorIndex = 2
            btr.AppendEntity(Mtext)
            '生成一个椭圆
            Dim othPoint As Point3d = New Point3d(29, 3, 0)
            Dim ellipse As Ellipse = New Ellipse(center, Vector3d.ZAxis, Vector3d.XAxis, 0.7, 0, 2 * 3.1415926535897)
            ellipse.LayerId = layerId
            Mtext.ColorIndex = 3
            btr.AppendEntity(ellipse)
            trans.AddNewlyCreatedDBObject(btr, True)
            trans.Commit()
        Catch
            MsgBox("Error Adding Entities")
        Finally
            trans.Dispose()
        End Try
    End Sub
GMT+8, 2026-11-3 07:21 , Processed in 0.599747 second(s), 32 queries , Gzip On.
