查看: 1429|回复: 0
[求助]:如何编写LISP求解多个不规则封闭图形的总面积,总周长,个数?
发表于 2007-9-3 09:38:28 | 显示全部楼层 |阅读模式
Sub GetTolArea()
     ThisDrawing.SendCommand
  "(vl-load-com)" & vbCr
     Dim CurveObj As Curve
     Set CurveObj =
  New Curve
     Dim VlaxObj As VLAX
     Set VlaxObj =
  New VLAX
     Dim OutEnt As
  AcadEntity
     Dim Pnt As Variant
     ThisDrawing.Utility.GetEntity OutEnt, Pnt, "选择外框:"
     Dim MinBox As Variant
     Dim MaxBox As Variant
     Dim OutArea As Double
     Dim OutLeng As Double
     OutEnt.GetBoundingBox MinBox, MaxBox
     If OutEnt.ObjectName
  "AcDbRegion"
  Then
         OutArea = OutEnt.Area
         OutLeng = OutEnt.Perimeter
     Else
         Set CurveObj.Entity = OutEnt
         OutArea = CurveObj.Area
         OutLeng = CurveObj.length
     End If
     'Set CurveObj.Entity = OutEnt
     Dim ss As
  AcadSelectionSet
     Set ss = CreatSSet
     Dim FType(0)
  As Integer
     Dim FData(0)
  As Variant
     FType(0)
  = 0
     FData(0)
  "SPLINE"
     ss.Select acSelectionSetWindow, MinBox, MaxBox, FType, FData
     'Debug.Print ss.Count
     Dim i As Integer
     Dim InArea()
  As Double
     Dim InLeng()
  As Double
     Dim j As Integer
     Dim Ent As
  AcadEntity
     ReDim Preserve InArea(0)
  As Double
     ReDim Preserve InLeng(0)
  As Double
     For i = 0 To ss.Count
  - 1
         If ss.Item(i).ObjectID  OutEnt.ObjectID
  Then
             Set Ent = ss(i)
             Set CurveObj.Entity = Ent
             VlaxObj.EvalLispExpression "(gc)"
             If i  0 Then
                 j = UBound(InArea)
  + 1
                 ReDim Preserve InArea(j)
  As Double
                 ReDim Preserve InLeng(j)
  As Double
                 InArea(j)
  = CurveObj.Area
                 InLeng(j)
  = CurveObj.length
             Else
                 InArea(0)
  = CurveObj.Area
                 InLeng(0)
  = CurveObj.length
             End If
         End If
     Next
     Dim TolArea As Double
     Dim TolLeng As Double
     Dim AreaPer As Double
     Dim dispMsg As
  String
     dispMsg =
  "外框的面积为:" & OutArea & ",周长为:" & OutLeng & vbCrLf & vbCrLf
     dispMsg = dispMsg & "内部曲线的面积及周长如下:" & vbCrLf
     For i = 0 To UBound(InArea)
         dispMsg = dispMsg & "曲线" & i & "面积:" & InArea(i) & ",周长:" & InLeng(i) & vbCrLf
         TolArea = TolArea + InArea(i)
         TolLeng = TolLeng + InLeng(i)
     Next
     dispMsg = dispMsg & vbCrLf
     dispMsg = dispMsg & "总面积为:" & TolArea & " 总周长为:" & TolLeng & vbCrLf & vbCrLf
     AreaPer = TolArea / OutArea * 100
     dispMsg = dispMsg & "内部曲线面积总各占外框面积的百分比:" & AreaPer & "%"
     'MsgBox dispMsg
     ThisDrawing.Utility.Prompt dispMsg
End Sub
Function CreatSSet()
     Dim ss As
  AcadSelectionSet
     On
  Error
  Resume
  Next
     Set ss =
  ThisDrawing.SelectionSets.Add("mccad")
     If Err Then
         Err.Clear
         Set ss =
  ThisDrawing.SelectionSets("mccad")
         ss.Clear
     End If
     Set CreatSSet = ss
End Function
GMT+8, 2026-11-22 08:05 , Processed in 0.322542 second(s), 10 queries , Gzip On, File On.
