查看: 808|回复: 0
[求助]:[求助]: Ratx =*********** Raty =***********
发表于 2006-8-3 08:35:39 | 显示全部楼层 |阅读模式
Ratx =***********        Raty =***********到底是什么意思,为什么会这样,
我这结构是从3层至6层为2塔
  各层刚心、偏心率、相邻层侧移刚度比等计算信息
  Floor No     : 层号
  Tower No     : 塔号
  Xstif,Ystif : 刚心的 X,Y 坐标值
  Alf          : 层刚性主轴的方向
  Xmass,Ymass : 质心的 X,Y 坐标值
  Gmass        : 总质量
  Eex,Eey     : X,Y 方向的偏心率
  Ratx,Raty   : X,Y 方向本层塔侧移刚度与下一层相应塔侧移刚度的比值
  Ratx1,Raty1 : X,Y 方向本层塔侧移刚度与上一层相应塔侧移刚度70%的比值
                 或上三层平均侧移刚度80%的比值中之较小者
  RJX,RJY,RJZ: 结构总体坐标系中塔的侧移刚度和扭转刚度
  Floor No.   1     Tower No.   1
  Xstif=     5.0214(m)     Ystif=    14.0983(m)     Alf  =    45.0000(Degree)
  Xmass=     9.6553(m)     Ymass=    14.5981(m)     Gmass=   530.5161(t)
  Eex  =     0.3051        Eey  =     0.0329
  Ratx =     1.0000        Raty =     1.0000
  Ratx1=   209.4557        Raty1=   219.7251  薄弱层地震剪力放大系数= 1.00
  RJX  = 6.6354E+07(kN/m)  RJY  = 5.8370E+07(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   2     Tower No.   1
  Xstif=     5.0667(m)     Ystif=    14.0553(m)     Alf  =    45.0000(Degree)
  Xmass=     5.1455(m)     Ymass=    13.7561(m)     Gmass=  1434.0870(t)
  Eex  =     0.0052        Eey  =     0.0196
  Ratx =     0.0068        Raty =     0.0065
  Ratx1=     2.5151        Raty1=     3.2386  薄弱层地震剪力放大系数= 1.00
  RJX  = 4.5256E+05(kN/m)  RJY  = 3.7950E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   3     Tower No.   1
  Xstif=     5.7002(m)     Ystif=    24.4796(m)     Alf  =     0.0000(Degree)
  Xmass=     6.2462(m)     Ymass=    25.1568(m)     Gmass=   496.0565(t)
  Eex  =     0.0507        Eey  =     0.0567
  Ratx =     0.5138        Raty =     0.4013
  Ratx1=     1.3956        Raty1=     1.3992  薄弱层地震剪力放大系数= 1.00
  RJX  = 2.3255E+05(kN/m)  RJY  = 1.5231E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   3     Tower No.   2
  Xstif=     6.6795(m)     Ystif=     4.5991(m)     Alf  =     0.0000(Degree)
  Xmass=     5.6098(m)     Ymass=     3.5860(m)     Gmass=   527.0638(t)
  Eex  =     0.0955        Eey  =     0.0893
  Ratx1=     1.3288        Raty1=     1.2150  薄弱层地震剪力放大系数= 1.00
  RJX  = 2.4879E+05(kN/m)  RJY  = 1.7993E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   4     Tower No.   1
  Ratx =     0.9414        Raty =     0.9273
  Ratx1=     1.3948        Raty1=     1.3647  薄弱层地震剪力放大系数= 1.00
  RJX  = 2.1893E+05(kN/m)  RJY  = 1.4123E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   4     Tower No.   2
  Ratx =     0.9817        Raty =     1.0286
  Ratx1=     1.3715        Raty1=     1.2774  薄弱层地震剪力放大系数= 1.00
  RJX  = 2.4424E+05(kN/m)  RJY  = 1.8507E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   5     Tower No.   1
  Ratx =     1.0199        Raty =     1.0329
  Ratx1=     1.5281        Raty1=     1.5057  薄弱层地震剪力放大系数= 1.00
  RJX  = 2.2329E+05(kN/m)  RJY  = 1.4588E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   5     Tower No.   2
  Ratx =     1.0150        Raty =     1.0656
  Ratx1=     1.4761        Raty1=     1.4245  薄弱层地震剪力放大系数= 1.00
  RJX  = 2.4792E+05(kN/m)  RJY  = 1.9721E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   6     Tower No.   1
  Xstif=     5.7106(m)     Ystif=    24.2840(m)     Alf  =     0.0000(Degree)
  Xmass=     6.0738(m)     Ymass=    25.0532(m)     Gmass=   289.4996(t)
  Eex  =     0.0335        Eey  =     0.0600
  Ratx =     0.8180        Raty =     0.8302
  Ratx1=     1.2500        Raty1=     1.2500  薄弱层地震剪力放大系数= 1.00
  RJX  = 1.8266E+05(kN/m)  RJY  = 1.2110E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   6     Tower No.   2
  Xstif=     6.0278(m)     Ystif=     4.5032(m)     Alf  =    45.0000(Degree)
  Xmass=     5.8833(m)     Ymass=     3.9995(m)     Gmass=   327.2906(t)
  Eex  =     0.0125        Eey  =     0.0437
  Ratx =     0.8468        Raty =     0.8775
  RJX  = 2.0994E+05(kN/m)  RJY  = 1.7305E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
GMT+8, 2026-11-22 11:05 , Processed in 0.350235 second(s), 8 queries , Gzip On, File On.
