查看: 915|回复: 2
[求助]:有谁能提供由若干线围成的面积VB源码
发表于 2006-8-3 08:37:41 | 显示全部楼层 |阅读模式
有谁能提供由若干线围成的面积VB源码,线可以是Line,Pline
发表于 2006-8-9 19:16:23 | 显示全部楼层
Sub test()
    On Error Resume Next
    Dim n As Long
    n = ThisDrawing.ModelSpace.Count
       Dim Pt As Variant
Here:
    Err = 0
    Pt = ThisDrawing.Utility.GetPoint(, "请指定内部点: ")
    If Err Then GoTo Here
    ThisDrawing.SendCommand "_-Boundary" & vbCr & Pt(0) & "," & Pt(1) & vbCr & vbCr
    Dim lwpLineObj As AcadLWPolyline
    If ThisDrawing.ModelSpace.Count > n Then
        Set lwpLineObj = ThisDrawing.ModelSpace.Item(ThisDrawing.ModelSpace.Count - 1)
        MsgBox lwpLineObj.Area
    Else
        MsgBox "未发现有效的刃口,请检查可视区域是否闭合. "
End If
End Sub
昨天明经上看到了
 楼主| 发表于 2006-8-10 10:05:13 | 显示全部楼层
[tigersapce ]太酷了,很好用啊,万分感谢!!!!!
GMT+8, 2026-11-22 10:42 , Processed in 0.363482 second(s), 14 queries , Gzip On, File On.
