查看: 1337|回复: 0
[求助]:仿CAD效果的自定义直线,一个问题求助(附源码)
发表于 2006-8-9 15:12:09 | 显示全部楼层 |阅读模式
void crtLine()
        int rc, i = 0;//输入返回状态和当前点数
        char kw[8];//获取用户输入关键字
        AcGePoint3d p;
        AcGePoint3dArray ptArr;//保存所有输入的有效点
        AcDbObjectId objId;
        AcDbLine *pLine = NULL;
        AcDbBlockTable *pBlockTable = NULL;
        AcDbBlockTableRecord *pBlockTableRecord = NULL;
        //打开数据库
        acdbHostApplicationServices()->workingDatabase()->
                getSymbolTable(pBlockTable, AcDb::kForRead);
        pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite);
        pBlockTable->close();
        while (TRUE)
                if (i == 0)//没有点
                        rc = acedGetPoint(NULL, "\n指定第一点: ",  asDblArray(p));
                else if (i < 3)//少于三个点
                        acedInitGet(RSG_OTHER, "Undo _ U");
                        rc = acedGetPoint(asDblArray(p),
                                "\n指定下一点或[放弃(U)]: ", asDblArray(p));
                else//大于三个点
                        acedInitGet(RSG_OTHER, "Close Undo _ C U");
                                "\n指定下一点或[闭合(C)/放弃(U)]: ",  asDblArray(p));
                if (i == 0 && rc == RTNORM)
                        ptArr.append(p);
                        ++i;
                else if (i == 1)
                        if (rc == RTNORM)//有两个点并返回正常,创建一条直线
                                ptArr.append(p);
                                ++i;
                                pLine = new AcDbLine(ptArr.first(), p);
                                actrTransactionManager->startTransaction();
                                pBlockTableRecord->appendAcDbEntity(pLine);
                                pLine->close();
                        else
                                actrTransactionManager->abortTransaction();
                                break;
                else
                        if (rc == RTNORM)//没增加一个点,创建一条直线
                                pLine = new AcDbLine(ptArr.last(), p);
                                ptArr.append(p);
                                ++i;
                                pLine->close();
                        else if (rc == RTKWORD)
                                if (acedGetInput(kw) != RTNORM) break;;
                                if (strcmp(kw, "U") == 0)
                                        ptArr.removeLast();
                                        --i;
                                        p = ptArr.last();
                                else if (strcmp(kw, "C") == 0)
                                        pLine = new AcDbLine(p, ptArr.first());
                                        pLine->close();
                                        break;
                        else break;
        pBlockTableRecord->close();
        actrTransactionManager->endTransaction();
存在的问题是:直线创建完之后,选择直线改变颜色没有反应,要regen命令后才有反应
另外当把创建的直线与其它物体求交点之类的操作,都求不出来,好像是实体没进入数据库似的
但把图形保存起来重新打开就正常
请问该怎么处理
GMT+8, 2026-11-22 08:19 , Processed in 0.393956 second(s), 10 queries , Gzip On, File On.
