查看: 794|回复: 0
[求助]:EXCEL VBA 要如何 使用DELETE等SQL
发表于 2006-8-15 08:59:33 | 显示全部楼层 |阅读模式
ㄧ般EXCEL VBA 下 使用 SQL 方式
Function getRS()  '
    Dim myCon As ADODB.Connection
    Dim myRS As ADODB.Recordset
    Set myCon = New ADODB.Connection
    myCon.Open "Provider=IBMDA400.DataSource.1;Persist Security Info=False;Data Source=s10a1512"
    Set myRS = New ADODB.Recordset
    With myRS
        .ActiveConnection = myCon
        .Source = "select ...................................... "
        .CursorType = adOpenStatic
        .Open
    End With
    myRow = 0
    Do Until myRS.EOF = True
         duns = myRS.Fields(0)
         myRS.MoveNext        '移動目前記錄
    Loop
    myRS.Close
    Set myRS = Nothing
    myCon.Close
    Set myCon = Nothing
End Function
Q1.若我要用 DELETE ,INSERT ,UPDATE
則要如何使用  呢
Q2.除了 SQL 來刪除資料 ,EXCEL VBA 還可以用哪一個方法 來刪除 100筆資料中 的40筆某條件下的資料
GMT+8, 2026-11-22 10:38 , Processed in 0.356570 second(s), 10 queries , Gzip On, File On.
