查看: 1046|回复: 2
[求助]:请帮忙编一个自动处理的程序
发表于 2006-8-18 23:17:39 | 显示全部楼层 |阅读模式
自动处理以下一些内容:
1、增加图层A、B等数个图层;
2、删除图层1、2等数个图层里的对象;
3、修改图层4、5等数个图层线宽、颜色;
4、替换文字“A”为“B”;
5、关闭图层4、5、6等;
程序是开放式的,我自己根据需要来调整。
哪位高手能帮助一下。谢谢!
已领礼包: 12488个
发表于 2006-8-19 12:13:36 | 显示全部楼层
  1. (DEFUN C:TEST ()
  2. (SETVAR "CMDECHO" 0)
  3. (COMMAND ".UNDO" "BE")
  4. (COMMAND "LAYER" "N" "A,B" "")
  5. (IF (SETQ SS (SSGET "X" '((8 . "1,2"))))
  6.   (COMMAND "ERASE" SS "")
  7. )
  8. (COMMAND "LAYER" "C" "RED" "4" "C" "3" "5" "")
  9. (COMMAND "LAYER" "LW" "0.3" "4" "LW" "0.5" "5" "")
  10. (IF (SETQ SS (SSGET "X" '((0 . "*TEXT") (1 . "A")))) (PROGN
  11.   (SETQ I -1)
  12.   (REPEAT (SSLENGTH SS)
  13.    (SETQ ENT (ENTGET (SSNAME SS (SETQ I (1+ I))))
  14.          ENT (SUBST (CONS 1 "B") (ASSOC 1 ENT) ENT))
  15.    (ENTMOD ENT)
  16.   )
  17. ))
  18. (COMMAND "LAYER" "OFF" "4,5,6" "")
  19. (COMMAND ".UNDO" "E")
  20. (PRINC)
  21. )
 楼主| 发表于 2006-8-19 19:28:45 | 显示全部楼层
感谢zxq0220 !
我对程序按自己的要求进行了修改后,
(DEFUN C:TEST ()
(IF (SETQ SS (SSGET "X" '((8 . "0污水,0污水井,0管径坡度,dm,gx-标注"))))
(IF (SETQ SS (SSGET "X" '((0 . "*TEXT") (1 . "污水")))) (PROGN
  (SETQ I -1)
         ENT (SUBST (CONS 1 "给水") (ASSOC 1 ENT) ENT))
   (ENTMOD ENT)
(IF (SETQ SS (SSGET "X" '((0 . "*TEXT") (1 . "WS")))) (PROGN
  (SETQ I -1)
         ENT (SUBST (CONS 1 "YS") (ASSOC 1 ENT) ENT))
   (ENTMOD ENT)
(PRINC)
调入CADR2002中出现:  错误: 输入的列表有缺陷
我再调整后,
(DEFUN C:TEST ()
  (SETQ I -1)
   (ENTMOD ENT)
(PRINC)
查找"污水"替换为"给水"没有成功.
请高手再帮我查查原因,我是不懂LISP,只是照瓣画葫芦而已.
(最好的能做多个替换.)
GMT+8, 2026-11-5 02:17 , Processed in 0.449016 second(s), 36 queries , Gzip On.
