查看: 2410|回复: 2
[求助] [求助]:如何用lisp删除。创建图层过滤器?
发表于 2006-9-4 13:56:56 | 显示全部楼层 |阅读模式
如何用lisp删除。创建图层过滤器?
N千多个图层过滤器,每次打开图层管理器都要半天时间,烦死了!
已领礼包: 9347个
发表于 2006-9-4 15:57:33 | 显示全部楼层
http://discussion.autodesk.com/thread.jspa?messageID=1194782
(defun C:fildel        ()
  (vl-Load-Com)
  (vl-Catch-All-Apply
    '(lambda ()
       (vla-Remove
         (vla-GetExtensionDictionary
           (vla-Get-Layers
             (vla-Get-ActiveDocument
               (vlax-Get-Acad-Object)
         "ACAD_LAYERFILTERS"
  (princ "\nAll layer filters have been deleted.")
  (princ)
(defun c:filtrdel (/ names)
  (vl-Load-Com)
  (textscr)
  (princ
    (strcat
      "\nRoutine to delete all but the specified Layer filters. "
      "When entering filter names to retain, wildcards are allowed. "
      "i.e., entering \"zz*,xx*\" will delete all filters "
      "except those beginning with zz and xx."
  (setq names (getstring  "\nEnter filter names to retain, press Enter for none: "))
  (vl-Catch-All-Apply
    '(lambda ()
       (setq dicts (vla-GetExtensionDictionary
                     (vla-Get-Layers
       (vlax-for dict dicts
         (if (and (= (vla-get-name dict) "ACAD_LAYERFILTERS")
                  (> (vla-get-count dict) 0)
           (progn
             (vlax-for filtr dict
               (if (not (wcmatch (vla-get-name filtr) names))
                 (vla-delete filtr)
  (graphscr)
  (princ "\nSpecified layer filters have been deleted.")
  (princ)
发表于 2006-9-4 16:38:17 | 显示全部楼层
http://www.theswamp.org/index.php?topic=7560.msg113739#msg113739
有个专门讨论这个的帖子和几个源码
GMT+8, 2026-11-7 06:49 , Processed in 0.522932 second(s), 36 queries , Gzip On.
