查看: 1294|回复: 4
[密技]:CAD中输入带圈的数字的办法
发表于 2006-9-18 12:44:44 | 显示全部楼层 |阅读模式
 *运行宏 数变编号,加圆圈
Public Sub bh()
ThisDrawing.Utility.Prompt "请选择要加圆圈的文本" + vbCrLf
Dim sset As AcadSelectionSet
Dim gp(0) As Integer
Dim data(0) As Variant
If ThisDrawing.SelectionSets.Count <> 0 Then
For i = 0 To ThisDrawing.SelectionSets.Count - 1
Set sset = ThisDrawing.SelectionSets.Item(i)
sset.Delete
Next
Else
End If
Set sset = ThisDrawing.SelectionSets.Add("ss")
AcadApplication.Visible = True
gp(0) = 0
data(0) = "*Text"
123: sset.SelectOnScreen gp, data
Dim min As Variant
Dim max As Variant
Dim o(0 To 2) As Double
Dim cir As AcadCircle
If sset.Count < 1 Then
MsgBox "没选文本"
GoTo 123
End If
For i = 0 To sset.Count - 1
sset(i).GetBoundingBox min, max
o(0) = (min(0) + max(0)) / 2
o(1) = (min(1) + max(1)) / 2
o(2) = 0
ThisDrawing.ModelSpace.AddCircle o, 4.5
Next
End Sub
发表于 2006-9-18 12:57:14 | 显示全部楼层
如何运行宏呀?
发表于 2006-9-20 10:01:56 | 显示全部楼层
这个东东好用么??象是带属性的文本,轴线上用的那种??
发表于 2006-9-20 11:06:17 | 显示全部楼层
好用吗
已领礼包: 111个
发表于 2006-9-20 15:24:35 | 显示全部楼层
试试这个
  1. ;;;by yshf
  2. (defun c:cc()
  3.    (vl-load-com)
  4.    (if (progn (Prompt "\n请选择要加圆圈的文本")
  5.               (setq ssa (ssget '((0 . "*TEXT")))))
  6.        (while (setq ent (ssname ssa 0))
  7.           (vla-getboundingbox (vlax-ename->vla-object ent) 'minpt 'maxpt)
  8.           (setq con (mapcar 'vlax-safearray->list (list minpt maxpt))
  9.                 po  (mapcar '* '(0.5 0.5) (mapcar '+ (car con) (cadr con)))
  10.                 ssa (ssdel ent ssa)
  11.           )
  12.           (entmake (list '(0 . "CIRCLE") (cons 10 po)
  13.                           (cons 40 (distance po (car con)))))
  14.        )
  15.        (alert "没有选择到任何文本!")
  16.    )
  17.    (princ)
  18. )
GMT+8, 2026-11-2 16:45 , Processed in 0.427606 second(s), 40 queries , Gzip On.
