查看: 1683|回复: 2
[求助]:请问CAD-VBA中的AcadEntity是何意思,另外.....
发表于 2006-9-21 19:11:01 | 显示全部楼层 |阅读模式
请问CAD-VBA中的AcadEntity是何意思,另外小弟用VBA编写了个程序,但检查不出错误,请大家指教
Public Sub subtract1()
   Dim a(0 To 1) As AcadCircle
   Dim b(0 To 2) As Double, c As Double
   b(0) = 4: b(1) = 4: b(2) = 0
   c = 2
   Set a(0) = ThisDrawing.ModelSpace.AddCircle(b, c)
   c = 1
   Set a(1) = ThisDrawing.ModelSpace.AddCircle(b, c)
   Dim s As Variant
   s = ThisDrawing.ModelSpace.AddRegion(a)
   Dim mm As AcadRegion, nn As AcadRegion
   If s(0).Area > s(1).Area Then
      mm = s(0)
     nn = s(1)
     Else
     mm = s(1)
     nn = s(0)
     End If
   mm.color = acRed
   nn.color = acBlue
   ZoomAll
   mm.Boolean acSubtraction, nn
   MsgBox mm.Area
End Sub
发表于 2006-9-28 13:34:25 | 显示全部楼层
解决方法如下:
Public Sub test1()
c0 = 2: c1 = 1
Set a(0) = ThisDrawing.ModelSpace.AddCircle(b, c0)
Set a(1) = ThisDrawing.ModelSpace.AddCircle(b, c1)
Dim s As Variant
        Set mm = s(0) '★★这里是重点
    Set nn = s(1) '★★给对象赋值需使用set
Else
        Set mm = s(1)
        Set nn = s(0)
End If
mm.color = acRed
nn.color = acBlue
MsgBox mm.Area
ZoomAll
End Sub
*-*9
发表于 2006-10-4 16:02:54 | 显示全部楼层
AcadEntity是所有CAD实体的基类
GMT+8, 2026-11-22 08:09 , Processed in 0.402196 second(s), 14 queries , Gzip On, File On.
