查看: 3225|回复: 4
[求助]:编辑问题,急
发表于 2006-11-2 11:06:22 | 显示全部楼层 |阅读模式
近日由原来的V7的MDL程序升级到V8,套用了V8程序的一些东西。但编译总是不成功,编译信息入下。望高手指点下是哪里错误了:
MicroStation Resource Compiler 08.01.01
   Generating header file (d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbacmd.h) ... done.
MicroStation Type Resource File Generator 08.01.01
MicroStation Development Language Linker  08.01.01
### d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\library\dgnfileio.dlo: ####Unresolved symbol CheckDBConnect in d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbasic.mo.
### d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\library\dgnfileio.dlo: Unrecoverable errors detected.  Output file not created.
Bentley Systems Make Utility. Version 08.01.01.03, Mar 18 2003
Thu Nov 02 11:00:19 2006
~mkdir d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects
~mkdir d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\rscobj
~mkdir d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\reqdobjs
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbacmd.h, (F:\MDL_doc\forv8mdl\dgnlevel\mdlbacmd.r) ==]
d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\bin\rcomp @d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\make.opt
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbacmd.rsc, (F:\MDL_doc\forv8mdl\dgnlevel\mdlbacmd.r) ==]
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbatyp.r, (F:\MDL_doc\forv8mdl\dgnlevel\mdlbasic.h) ==]
d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\bin\rsctype @d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\make.opt
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbatyp.rsc, (d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbatyp.r) ==]
d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbacmd.h  F:\MDL_doc\forv8mdl\dgnlevel\mdlbadlg.h
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbasic.mp, (d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbasic.mo) ==]
d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\bin\mlink @d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\temp.cmd
Thu Nov 02 11:00:20 2006, elapsed time: 0:01
BMAKE: call trace
    line:   79, F:\MDL_doc\forv8mdl\dgnlevel\MDLBASIC.mke
Error executing bmake.
MDLBASIC.ma - 1 error(s), 0 warning(s)
下面是MKE的内容
%if defined (_MakeFilePath)
baseDir    = $(_MakeFilePath)
%else
baseDir           = $(MS)/mdl/examples/viewctrl/
%endif
appName     = mdlbasic
sAppName    = mdlba
privateInc  = $(baseDir)
langSpec    = $(baseDir)english/
%include $(MS)/mdl/include/mdl.mki
$(o)$(tstdir)                        : $(o)$(tstdir)
$(rscObjects)$(tstdir)                : $(rscObjects)$(tstdir)
$(reqdObjs)$(tstdir)                : $(reqdObjs)$(tstdir)
viewctrlObjs = $(o)$(appName).mo    \
                    $(mdlLibs)ditemlib.dlo
viewctrlRscs =         $(o)$(appName).mp            \
                    $(o)$(sAppName)typ.rsc        \
                $(o)$(sAppName)cmd.rsc
$(genSrc)$(sAppName)cmd.h        : $(baseDir)$(sAppName)cmd.r
$(o)$(sAppName)cmd.rsc            : $(baseDir)$(sAppName)cmd.r
$(o)$(sAppName)typ.r         : $(baseDir)$(sAppName)typ.mt      \
                                    $(privateInc)$(appName).h
$(o)$(sAppName)typ.rsc    : $(o)$(sAppName)typ.r
$(o)$(appName).mo                :   $(baseDir)$(appName).cpp        \
                                    $(privateInc)$(appName).h        \
                                    $(genSrc)$(sAppName)cmd.h        \
                                    $(privateInc)$(sAppName)dlg.h
$(o)$(appName).mp                :   $(viewctrlObjs)
        $(msg)
        > $(o)temp.cmd
        -a$@
        $(linkOpts)
        $(viewctrlObjs)
        $(MLinkCmd) @$(o)temp.cmd
        ~time
$(o)$(appName).mi        :   $(viewctrlRscs)
        $(msg)
        > $(o)make.opt
        -o$@
        $(viewctrlRscs)
        $(RLibCmd) @$(o)make.opt
        ~time
maRscs = $(o)$(appName).mi        \
            $(o)$(sAppName)dlg.rsc         \
             $(o)$(sAppName)msg.rsc
$(o)$(sAppName)dlg.rsc        : $(baseDir)$(sAppName)dlg.r         \
                          $(privateInc)$(sAppName)dlg.h        \
                          $(langSpec)$(sAppName)txt.h
modules for
$(o)$(sAppName)msg.rsc                : $(langSpec)$(sAppName)msg.r         \
$(mdlapps)$wSSS.ma                : $(maRscs)
    $(msg)
    > $(o)make.opt
    -o$@
    $(maRscs)
    ~time
发表于 2006-11-2 13:13:10 | 显示全部楼层
问一下,CheckDBConnect这个函数在哪边定义的?
最好能够上传一部份源代码上来,这样方便我们查找错误;
 楼主| 发表于 2006-11-2 14:52:26 | 显示全部楼层
感谢~
上面的问题已经解决了,但又有一个问题。编译提示为:
MicroStation Development Language Compiler 08.01.01
MicroStation Resource Librarian 08.01.01
There must be at least 1 resource defined. Aborted.
Thu Nov 02 14:49:18 2006
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbacmd.h, (F:\MDL_doc\forv8mdl\MDLBASIC\mdlbacmd.r) ==]
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbacmd.rsc, (F:\MDL_doc\forv8mdl\MDLBASIC\mdlbacmd.r) ==]
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbatyp.r, (F:\MDL_doc\forv8mdl\MDLBASIC\mdlbatyp.mt) ==]
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbasic.mo, (F:\MDL_doc\forv8mdl\MDLBASIC\mdlbadlg.h) ==]
d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\bin\mcomp @d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\make.opt
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbasic.mi, (d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbasic.mp) ==]
d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\bin\rlib @d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\make.opt
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbadlg.rsc, (F:\MDL_doc\forv8mdl\MDLBASIC\mdlbadlg.h) ==]
[== Building d:\PROGRA~1\Bentley\Program\MICROS~1\mdl\objects\mdlbamsg.rsc, (F:\MDL_doc\forv8mdl\MDLBASIC\mdlbadlg.h) ==]
Thu Nov 02 14:49:21 2006, elapsed time: 0:03
BMAKE: call trace
    line:  137, F:\MDL_doc\forv8mdl\MDLBASIC\MDLBASIC.mke
谢谢!
发表于 2006-11-2 16:16:19 | 显示全部楼层
MDLBASIC.mke的137句错误, 你看看什么内容
另外把你的问题都请放在一个主题内, 已经不是第一次说你了
发表于 2006-11-3 09:33:02 | 显示全部楼层
“There must be at least 1 resource defined. Aborted.”说明编译程序找不到你在mki文件指定的.r资源文件,可能在你的源代码中没有.r文件,那么需要把mki文件修改一下,把编译.r的语句去掉就行了
GMT+8, 2026-11-22 07:50 , Processed in 0.585300 second(s), 18 queries , Gzip On, File On.
