查看: 2322|回复: 0
[他山之石] Align Text
发表于 2013-5-6 12:52:08 | 显示全部楼层 |阅读模式
Program Description
This relatively simple program enables the user to reposition a selection of text objects (single-line text), equispaced by a factor of the text height and aligned in a direction perpendicular to the text rotation.
The program is designed to operate as efficiently as possible, with minimal prompts: upon issuing the command syntax AT at the AutoCAD command-line, the user is prompted only for a selection of text objects.
Following a valid selection, the program will proceed to align each item in the set using its text alignment point, with each item equispaced by a factor of the text height; this spacing factor may be altered using the parameter noted at the top of the program code.
The program assumes that all selected text objects have the same height & rotation and will align the text objects in a direction perpendicular to the rotation angle of an arbitrary text object in the set.
Finally, the program will operate successfully with text objects constructed in any UCS plane.
文件名称:AlignTextV1-3.lsp
下载次数:30  文件大小:3.71 KB
评分
参与人数 2D豆 +7 收起 理由
ScmTools + 3 很给力!经验
XDSoft + 4 资料分享奖!
查看全部评分
本帖被以下淘专辑推荐:
GMT+8, 2026-11-22 07:51 , Processed in 0.224039 second(s), 20 queries , Gzip On, File On.
