查看: 1785|回复: 5
[LISP函数]:免币.一款CAD射击小游戏.不用安装LISP加载即可
发表于 2006-12-1 14:30:04 | 显示全部楼层 |阅读模式
它会在单独的图层显示,不影响图纸,是工作消遣的好方法.
加载后输入命令TROY.
不知是怎么回事,我上传不了,回贴时传了个附件,连我自已也下载不了,显示"找不到服务器"
我只好把程序粘到4楼.
发表于 2006-12-3 09:47:46 | 显示全部楼层
cad还有游戏,试试看
发表于 2006-12-3 11:43:06 | 显示全部楼层
程序呢?
我怎么没有看到呀?
请楼主检查一下。
先谢谢楼主
 楼主| 发表于 2006-12-4 17:15:15 | 显示全部楼层
*********************************游戏
                                        ; Program Name: Troy.lsp [Troy R4] - Asteroids AutoLISP game
                                        ; Created By:   Terry Miller (Email: terrycadd@yahoo.com)
                                        ;               (URL: http://web2.airmail.net/terrycad)
                                        ;               For the Internation version of this game, download Troy-I.lsp
                                        ;               from the above website.
                                        ; Date Created: 1-20-06
                                        ; Notes:        Troy is an Asteroids AutoLISP game driven by the grread function.
                                        ;               It can be run inside of an existing drawing. When it's finished,
                                        ;               it purges all entities, styles and layers it created. You have
                                        ;               three ships to use to shoot down as many Troys as possible. If
                                        ;               a Troy runs into your ship, it blows up your ship and you loose
                                        ;               10 points. Each Troy you blow up, you gain its value in points.
                                        ;               Use the mouse to keep the game moving. Pick the mouse to fire
                                        ;               at Troys. Each fire cost you 1 point. Press P to pause the game.
                                        ;               Press Q to quit the game before it ends, in order to purge all
                                        ;               entities, styles and layers it created. If you press the escape
                                        ;               key to abort the game, simply rerun Troy again and select the
                                        ;               Clear option. So do not press the escape key to abort the game.
                                        ; Disclaimer:   This program is free to download and share and learn from. It
                                        ;               contains many useful functions that may be applied else where.
                                        ;               Every effort on my part has been to create a grread game that
                                        ;               will run in most versions of AutoCAD, and when finished it will
                                        ;               return to the environment before it started.  Troy is now yours
                                        ;               to tweak, debug, add to, rename, use parts of, or create another
                                        ;               grread game from. It is now your responsibility when, and within
                                        ;               what drawings you should run it. If you are unsure of how it may
                                        ;               affect certain drawing environments, do a saveas before running
                                        ;               it. Do not save a drawing without running the Troy Clear option.
                                        ; Revision History
                                        ; Rev  By     Date    Description
                                        ; 1    TM   1-20-06   Initial version.
                                        ; 2    TM   6-20-06   Revised PurgeGroups function.
                                        ; 3    TM   6-24-06   Revised program to switch to the Model tab if there are
                                        ;                     viewports on the current Layout tab.
                                        ; 4    TM   6-26-06   Added Settings option to adjust number of Troys, speed of
                                        ;                     Troys and Color Scheme.
                                        ; c:Troy - Asteroids AutoLISP game
(defun c:Troy (/ Colors$ Loop Option$ Settings$)
  (initget "Intro Clear Settings Play")
  (if (not
        (setq Option$ (getkword
                        "\nTroy options [Intro/Clear/Settings/<Play>]: "
    (setq Option$ "Play")
  )                                        ;if
  (cond
    ((= Option$ "Clear")
     (TroyClear)
     (princ "\nTroy objects Cleared.")
    ((= Option$ "Settings")
     (initget "Troys Speed Colors Defaults")
     (if (not
           (setq
             Settings$ (getkword
                         "\nSettings [Troys/Speed/Colors/<Defaults>]: "
       (setq Settings$ "Defaults")
     )                                        ;if
     (cond
       ((= Settings$ "Troys")
        (setq Loop t)
        (while Loop
          (if (not (setq *MinTroys#*
                          (getint "\nMinimum number of Troys <5>: ")
            (setq *MinTroys#* 5)
          )                                ;if
          (if (not (setq *MaxTroys#*
                          (getint "\nMaximum number of Troys <10>: ")
            (setq *MaxTroys#* 10)
          )                                ;if
          (if (or (< *MinTroys#* 1) (<= *MaxTroys#* *MinTroys#*))
            (princ
              "\nThe maximum number must be greater than the minimum number,\nand the minimum number must be greater than 0."
            (setq Loop nil)
          )                                ;if
        )                                ;while
        (if (> *MaxTroys#* 20)
          (princ
            "\nIncreasing the maximum number of Troys may slow down the game."
        )                                ;if
       )                                ;case
       ((= Settings$ "Speed")
        (setq Loop t)
        (while Loop
          (if (not (setq *TroySpeed~*
                          (getreal
                            "\nAdjust speed of Troys\nEnter a number between 0.5 and 5.0 <1.0>: "
            (setq *TroySpeed~* 1.0)
          )                                ;if
          (if (or (< *TroySpeed~* 0.5) (> *TroySpeed~* 5.0))
            (princ
              "\nThe number must in the range of 0.5 to 5.0.\nThe larger the number the faster the Troys move."
            (setq Loop nil)
          )                                ;if
        )                                ;while
       )                                ;case
       ((= Settings$ "Colors")
        (initget "Bright Dim Ghost")
        (if (not (setq Colors$
                        (getkword "\nColor Scheme [<Bright>/Dim/Ghost]: ")
          (setq Colors$ "Bright")
        )                                ;if
        (setq *ColorScheme#*
               (cond
                 ((= Colors$ "Bright") 1)
                 ((= Colors$ "Dim") 2)
                 ((= Colors$ "Ghost") 3)
               )                        ;cond
        )                                ;setq
       )                                ;case
       ((= Settings$ "Defaults")
        (setq *MinTroys#* 5
              *MaxTroys#* 10
              *TroySpeed~* 1.0
              *ColorScheme#* 1
       )                                ;case
     )                                        ;cond
     (c:Troy)
    )                                        ;case
    (t (Troy Option$))
  )                                        ;if
  (princ)
)                                        ;defun c:Troy
                                        ; Troy - Troy main function
(defun Troy (Option$        /           AddArray:  Ang~         AxisPt
             BuildShip:        CenPt           ChangeArray:                 CirAng~
             CirEnt^        CirLimits~ CirPt1     CirPt2         Color1
             Color1_5        Color2           Color3     Color4         Color5
             Color6        Color7           Color8     Cnt#         Code#
             Counter#        CreateArray:              Dia1~         Dia2~
             Direction#        Dist~           Ent^              Ent1^         Ent2^
             Flame$        Flame^           FlameArray@                 HalfStep~
             Inc#        Inc1~           Inc2~      Increase~         Item
             Limit#        Loop           MainEnt^   MainList@         MainNum#
             NorthEast        NorthWest  Nth#              Nths@         Num#
             NumSteps#        Offset~           OldDirection#         Option$
             Passed        Pnts#           Points#    Previous@         Pt
             Pt1        Pt2           Pt3              Pt4         Pt5
             Pt6        Pt7           Pt8              Pt9         Pt10
             Pt11        Pt12           Radius~    Read@         Refresh:
             Rotate~        ShipName$  SouthEast  SouthWest         SS&
             StepDist~        SubList@   TextEnt^   Total#         TroyArray@
             Unit~        Value           ViewExtents@                 ViewSize~
             Xmin~        Xmax~           Ymin~      Ymax~
                                        ; AddArray: - Add new Troy entity specs to the TroyArray@ list
                                        ; Arguments: 1
                                        ;   StartPt = Specify starting point or nil
                                        ; Returns: A list of a new random Troy specs to be added to TroyArray@ list
  (defun AddArray: (StartPt / Ang~ Num#)
    (if        StartPt
      (setq CirPt1 StartPt)
      (setq CirPt1 (polar CenPt (* (GetRnd 6283) 0.001) CirLimits~))
    )                                        ;if
    (setq Num# (GetRnd 8))
    (setq StepDist~                        ;Determines Troys Speed
           (cond                        ;                                   Points Dia Units
             ((= Num# 0) (* Unit~ 0.100 *TroySpeed~*)) ;50     2.0
             ((= Num# 1) (* Unit~ 0.125 *TroySpeed~*)) ;75     2.5
             ((= Num# 2) (* Unit~ 0.150 *TroySpeed~*)) ;100    3.0
             ((= Num# 3) (* Unit~ 0.175 *TroySpeed~*)) ;125    3.5
             ((= Num# 4) (* Unit~ 0.200 *TroySpeed~*)) ;150    4.0
             ((= Num# 5) (* Unit~ 0.225 *TroySpeed~*)) ;175    4.5
             ((= Num# 6) (* Unit~ 0.250 *TroySpeed~*)) ;200    5.0
             ((= Num# 7) (* Unit~ 0.275 *TroySpeed~*)) ;225    5.5
             ((= Num# 8) (* Unit~ 0.300 *TroySpeed~*)) ;250    6.0
           )                                ;cond
    )                                        ;setq
    (setq HalfStep~ (/ StepDist~ 2.0))
    (setq Points# (+ (* Num# 25) 50))        ;50 to 250
    (setq Radius~ (/ (* Unit~ (* 0.1 (+ (+ (* Num# 5) 10) 10))) 2.0))
    (command "CIRCLE" CirPt1 Radius~)
    (setq Ent1^ (entlast))
    (command "CHPROP" Ent1^ "" "C" Color8 "")
    (command "HATCH"
             "AR-CONC"
             (* (getvar "VIEWSIZE") 0.0045)
             Ent1^
    (setq Ent2^ (entlast))
    (command "CHPROP" Ent2^ "" "C" Color8 "")
    (command "-GROUP" "C" (UniqueName) "" Ent1^ Ent2^ "")
    (setq CirEnt^ (entlast))
    (setq CirAng~ (+ (- (angle CirPt1 CenPt) (dtr 30))
                     (* (GetRnd 1047) 0.001)
    (setq CirPt2 (polar CirPt1 CirAng~ StepDist~))
    (setq Offset~ (+ (* Radius~ 2) (* Radius~ (GetRnd 10))))
    (setq Ang~ (atan (/ HalfStep~ Offset~)))
    (setq Pt (polar CirPt1 CirAng~ HalfStep~))
    (if        (< CirAng~ (angle CirPt1 CenPt))
      (setq AxisPt     (polar Pt (+ CirAng~ (dtr 90)) Offset~)
            Direction# 1
      (setq AxisPt     (polar Pt (- CirAng~ (dtr 90)) Offset~)
            Direction# -1
    )                                        ;if
    (setq NumSteps# (+ (GetRnd 10) 2))
    (list CirEnt^ CirPt1 CirPt2        AxisPt Radius~ Direction# NumSteps#
          Points#)
  )                                        ;defun AddArray:
                                        ; ChangeArray: - Change or Move entity in the TroyArray@ list
                                        ; Arguments: 1
                                        ;   List@ = A sublist within the TroyArray@ list
                                        ; Returns: Changes or Moves Troy entities in the TroyArray@ list
  (defun ChangeArray: (List@ / Ang~ Num#)
    (setq CirEnt^    (nth 0 List@)
          CirPt1     (nth 1 List@)
          CirPt2     (nth 2 List@)
          AxisPt     (nth 3 List@)
          Radius~    (nth 4 List@)
          Direction# (nth 5 List@)
          NumSteps#  (nth 6 List@)
          Points#    (nth 7 List@)
          StepDist~  (distance CirPt1 CirPt2)
          Ang~             (- (* pi 0.5) (acos (/ HalfStep~ (distance AxisPt CirPt2))))
    )                                        ;setq
    (command "MOVE" CirEnt^ "" CirPt1 CirPt2)
    (setq NumSteps# (1- NumSteps#))
    (if        (= NumSteps# 0)
      (progn
        (setq OldDirection# Direction#)
        (setq Num# (GetRnd 10))
        (if (> Num# 5)
          (setq Direction# 1)                ;ccw
          (setq Direction# -1)                ;cw
        )                                ;if
        (if (= OldDirection# 1)                ;ccw
          (if (= Direction# 1)                ;ccw
            (setq AxisPt (polar CirPt2 (angle CirPt2 AxisPt) Offset~))
            (setq AxisPt (polar CirPt2 (angle AxisPt CirPt2) Offset~))
          )                                ;if
          (if (= Direction# -1)                ;cw
          )                                ;if
        )                                ;if
        (setq Ang~ (- (* pi 0.5) (acos (/ HalfStep~ Offset~))))
          (setq        Pt (polar AxisPt
                          (+ (angle AxisPt CirPt2) (* Ang~ 2))
                          (- (angle AxisPt CirPt2) (* Ang~ 2))
        )                                ;if
        (setq CirPt1 CirPt2
              CirPt2 Pt
      )                                        ;progn
        (progn
          (setq        CirPt1 CirPt2
                CirPt2 Pt
        )                                ;progn
        (progn
          (setq        CirPt1 CirPt2
                CirPt2 Pt
        )                                ;progn
      )                                        ;if
    )                                        ;if
                                        ;(command "LINE" AxisPt CirPt1 ""); Uncomment to see Troys paths while debuging
                                        ;If you're tweaking or debugging this code, you've got to uncommend the above line
                                        ;at least once to see these patterns. Run Troy in the Intro or Play mode for about
                                        ;10 seconds then press the escape key to abruptly abort the game. Then turn off
                                        ;all layers except for the Troy layer, and do a zoom extents and print it.
          Points#)
  )                                        ;defun ChangeArray:
                                        ; CreateArray: - Creates the initial TroyArray@ list
                                        ; Arguments: 1
                                        ;   TowardCenter = 1 for toward center, else away from center
                                        ; Returns: Creates the initial TroyArray@ list moving in direction specified.
  (defun CreateArray: (TowardCenter)
    (setq TroyArray@ nil)
    (if        (= TowardCenter 1)
      (progn
        (setq Rotate~ (* (GetRnd 6283) 0.001))
        (repeat        10
          (setq        TroyArray@
                 (append
                   TroyArray@
                   (list
                     (AddArray: (polar CenPt Rotate~ CirLimits~))
          (setq Rotate~ (+ Rotate~ (/ pi 5.0)))
        )                                ;repeat
      )                                        ;progn
      (progn
              Dist~        (/ (distance NorthWest NorthEast) 7)
              Increase~        (/ (* Dist~ 3) 20.0)
        )                                ;setq
        (repeat        10
          (setq Pt (polar CenPt Rotate~ Dist~))
          (setq List@ (AddArray: Pt))
          (setq List@ (Switch_nth 1 2 List@))
          (setq List@ (Change_nth 5 (* (nth 5 List@) -1) List@))
          (setq TroyArray@ (append TroyArray@ (list List@)))
          (setq        Rotate~        (+ Rotate~ 0.897 (* (GetRnd 359) 0.001))
                Dist~        (+ Dist~ Increase~)
          )                                ;setq
        )                                ;repeat
      )                                        ;progn
    )                                        ;if
  )                                        ;defun CreateArray:
                                        ; BuildShip: - Draws Ships
                                        ; Arguments: 2
                                        ;   Num# = The number of ship created in the function BuildShip:
                                        ;   InsPt = Insertion base point of the ship
                                        ; Returns: Draws and makes a block of ship at the insertion point specified.
                                        ; Also creates the variables MainEnt^ and MainList@ of the ships specs.
  (defun BuildShip: (Num# InsPt / SS&)
    (if        (not (member Num# (list 0 1 2 3)))
      (setq Num# 1)
    (cond
      ((= Num# 0)                        ;Red Ship in Intro
       (setq Pt1  (polar InsPt (dtr 90) (* Unit~ 0.5))
             Pt1  (polar Pt1 pi (* Unit~ 0.875))
             Pt2  (polar Pt1 pi (* Unit~ 0.375))
             Pt2  (polar Pt2 (dtr 270) (* Unit~ 0.125))
             Pt3  (polar Pt2 pi (* Unit~ 0.25))
             Pt3  (polar Pt3 (dtr 270) (* Unit~ 0.125))
             Pt4  (polar Pt3 (dtr 270) (* Unit~ 0.75))
             Pt4  (polar Pt4 0 (* Unit~ 0.5))
             Pt5  (polar Pt4 0 (* Unit~ 1.25))
             Pt5  (polar Pt5 (dtr 270) (* Unit~ 0.5))
             Pt6  (polar InsPt 0 (* Unit~ 2.5))
             Pt7  (polar Pt6 (dtr 90) (* Unit~ 0.5))
             Pt7  (polar Pt7 pi Unit~)
             Pt8  (polar Pt7 pi (* Unit~ 0.5))
             Pt8  (polar Pt8 (dtr 90) (* Unit~ 0.125))
             Pt9  (polar Pt3 0 (* Unit~ 0.5))
             Pt10 (polar InsPt (dtr 270) (* Unit~ 0.25))
             Pt11 (polar Pt9 0 (* Unit~ 2.25))
             Pt12 (polar InsPt (dtr 90) Unit~)
       )                                ;setq
       (setq SS& (ssadd))
       (command "COLOR" Color1)                ;Red
       (command "ARC" Pt1 Pt2 Pt3)
       (ssadd (entlast) SS&)
       (command "ARC" Pt3 Pt4 Pt5)
       (command "ARC" "" Pt6)
       (command "ARC" Pt6 Pt7 Pt8)
       (command "COLOR" Color4)                ;Cyan
       (command "ARC" Pt9 Pt10 Pt11)
       (command "ARC" Pt11 Pt12 Pt9)
       (command "COLOR" "BYLAYER")
       (setq ShipName$ (UniqueName))
       (command "BLOCK" ShipName$ InsPt SS& "")
       (command "INSERT" ShipName$ InsPt 1 1 0)
       (setq MainEnt^ (entlast))
       (setq MainList@ (entget MainEnt^))
      )                                        ;case
      ((= Num# 1)                        ;Green Ship
       (setq Pt        (polar InsPt pi Unit~)
             Pt        (polar Pt (dtr 90) (* Unit~ 0.5))
       (command        "PLINE"
                Pt
                (polar Pt (dtr 270) Unit~)
                (polar InsPt 0 (* Unit~ 2))
                "C"
       (command "CHPROP" "L" "" "C" Color3 "") ;Green
       (command "BLOCK" ShipName$ InsPt "L" "")
      )                                        ;case
      ((= Num# 2)                        ;Cyan Ship
             Pt1 (polar Pt (dtr 270) Unit~)
             Pt4 (polar Pt1 (dtr 90) (* Unit~ 2))
             Pt         (polar InsPt 0 Unit~)
             Pt2 (polar Pt (dtr 270) (* Unit~ 0.5))
             Pt3 (polar Pt2 (dtr 90) Unit~)
       )                                ;setq
       (command        "PLINE"
                (polar InsPt pi (* Unit~ 0.5))
                Pt1
                (polar InsPt (dtr 270) (* Unit~ 0.5))
                Pt2
                Pt3
                Pt4
                "C"
       )                                ;command
       (command "CHPROP" "L" "" "C" Color4 "") ;Cyan
      )                                        ;case
      ((= Num# 3)                        ;Magenta Ship
             Pt1 (polar Pt (dtr 270) (* Unit~ 0.5))
             Pt4 (polar Pt1 (dtr 90) Unit~)
             Pt2 (polar Pt1 0 (* Unit~ 1.5))
             Pt3 (polar Pt4 0 (* Unit~ 1.5))
       )                                ;setq
       (command        "PLINE"
                InsPt
                Pt1
                (polar InsPt (dtr 270) Unit~)
                Pt2
                Pt3
                Pt4
                "C"
       )                                ;command
       (command "CHPROP" "L" "" "C" Color6 "") ;Magenta
      )                                        ;case
    )                                        ;cond
    (princ)
  )                                        ;defun BuildShip:
                                        ; Refresh: - Erases Troy entities and creates a new TroyArray@ list
  (defun Refresh: ()
    (setq SS& (ssget "x" (list '(8 . "Troy"))))
    (command "ERASE" SS& "")
    (setq FlameArray@ nil
          TroyArray@  nil
          Counter#    0
          MainNum#    (1+ MainNum#)
    (CreateArray: (GetRnd 1))
    (princ)
  )                                        ;defun Refresh:
                                        ; Start of Main Function
  (if (not *MinTroys#*)
  (if (not *MaxTroys#*)
  (if (not *TroySpeed~*)
  (if (not *ColorScheme#*)
    (setq *ColorScheme#* 1)
  (if (not *Speed#)
    (Speed)
  (if (not *Clayer$*)
    (setq *Clayer$* (getvar "CLAYER"))
  (if (not *Osmode#*)
    (setq *Osmode#* (getvar "OSMODE"))
  (if (not *TextStyle$*)
    (setq *TextStyle$* (getvar "TEXTSTYLE"))
  (if (not *TextSize~*)
    (setq *TextSize~* (getvar "TEXTSIZE"))
  (setvar "BLIPMODE" 0)
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 0)
  (setvar "GRIDMODE" 0)
  (graphscr)
  (if (>= (atoi (getvar "ACADVER")) 15)
    (progn
      (if (not *CTab$*)
        (setq *CTab$* (getvar "CTAB"))
      (if (/= (getvar "CTAB") "Model")
        (progn
          (command "PSPACE")
          (if (setq SS&        (ssget "x"
                               (list '(-4 . "<AND")
                                     '(0 . "VIEWPORT")
                                     (cons 410 (getvar "CTAB"))
                                     '(-4 . "AND>")
            (if        (> (sslength SS&) 1)
              (command "LAYOUT" "S" "Model")
            )                                ;if
          )                                ;if
        )                                ;progn
      )                                        ;if
      (setq *TroyTab$* (getvar "CTAB"))
    )                                        ;progn
  )                                        ;if
  (if (tblsearch "LAYER" "Troy")
    (command "LAYER" "T" "Troy"        "U" "Troy" "ON"        "Troy" "M" "Troy" "")
    (command "LAYER" "M" "Troy" "")
  )                                        ;if
  (if (setq SS& (ssget "x" (list '(8 . "Troy"))))
  )                                        ;if
  (setq ViewExtents@ (ViewExtents))
  (command "ZOOM" "W" (car ViewExtents@) (cadr ViewExtents@))
  (setq        Xmin~           (car (nth 0 ViewExtents@))
        Ymax~           (cadr (nth 0 ViewExtents@))
        Xmax~           (car (nth 1 ViewExtents@))
        Ymin~           (cadr (nth 1 ViewExtents@))
        NorthWest  (car ViewExtents@)
        SouthEast  (cadr ViewExtents@)
        SouthWest  (list Xmin~ Ymin~)
        NorthEast  (list Xmax~ Ymax~)
        CenPt           (getvar "VIEWCTR")
        ViewSize~  (getvar "VIEWSIZE")
        Unit~           (/ (getvar "VIEWSIZE") 50.0)
        Limit#           (1+ (fix (/ (distance CenPt (car ViewExtents@)) Unit~)))
        CirLimits~ (* (+ Limit# 3) Unit~)
        North           (polar CenPt
                          (dtr 90)
                          (+ (* Unit~ 3) (/ (getvar "VIEWSIZE") 2.0))
        South           (polar CenPt
                          (dtr 270)
        East           (polar CenPt
                          0
                          (+ (* Unit~ 3) (/ (distance NorthWest NorthEast) 2.0))
        West           (polar CenPt
                          pi
  )                                        ;setq
                                        ; Customize Color Schemes as desired and add to top menu in c:Troy
  (cond
    ((= *ColorScheme#* 1)                ;  Bright colors
     (setq Color1 1                        ;Red      Red ship
           Color1_5 30                        ;Orange   Exploding Troys
           Color2 2                        ;Yellow   Bonus points
           Color3 3                        ;Green    1st ship
           Color4 4                        ;Cyan     2nd ship
           Color5 5                        ;Blue     Letter O in TroyIntro
           Color6 6                        ;Magenta  3rd ship
           Color7 7                        ;White    Not used
           Color8 33                        ;Grey     Troys
     )                                        ;setq
    )                                        ;case
    ((= *ColorScheme#* 2)                ;  Dim colors
     (setq Color1 12                        ;Red      Red ship
           Color1_5 32                        ;Orange   Exploding Troys
           Color2 52                        ;Yellow   Bonus points
           Color3 86                        ;Green    1st ship
           Color4 152                        ;Cyan     2nd ship
           Color5 162                        ;Blue     Letter O in TroyIntro
           Color6 192                        ;Magenta  3rd ship
           Color8 250                        ;Grey     Troys
     )                                        ;setq
    )                                        ;case
    ((= *ColorScheme#* 3)                ;  Ghost colors
     (setq Color1 250                        ;Red      Red ship
           Color1_5 250                        ;Orange   Exploding Troys
           Color2 250                        ;Yellow   Bonus points
           Color3 250                        ;Green    1st ship
           Color4 250                        ;Cyan     2nd ship
           Color5 250                        ;Blue     Letter O in TroyIntro
           Color6 250                        ;Magenta  3rd ship
           Color7 250                        ;White    Not used
     )                                        ;setq
    )                                        ;case
  )                                        ;cond
                                        ; Create Flame$ block
  (setq SS& (ssadd))
  (setq Pt SouthEast)
  (command "COLOR" Color2)                ;Yellow
  (command "LINE" Pt (setq Pt (polar Pt 0 Unit~)) "")
  (setq Flame$ (UniqueName))
  (command "BLOCK" Flame$ SouthEast SS& "")
  (if (= Option$ "Intro")
    (TroyIntro)
                                        ;(command "RECTANG" (car ViewExtents@)(cadr ViewExtents@)); Uncomment while debuging
                                        ;(command "CIRCLE" CenPt CirLimits~); Uncomment while debuging
                                        ; Build Ship 1
  (BuildShip: 1 CenPt)
                                        ; Create first Troys
  (command "STYLE" "Troy" "ROMANS" "0.0" "0.75" "" "" "" "")
                                        ; Start of grread Loop
  (setq        Loop t
        Counter# 0
        Total# 100
        MainNum# 1
  (setq Previous@ (list 5 (polar CenPt 0 Unit~)))
                                        ;Start the Loop moving
  (princ (strcat "\nCommand:\nTotal: " (itoa Total#) "\n"))
  (while Loop
                                        ; Read the mouse movements and picks
    (if        (not (setq Read@ (grread t 8)))
      (setq Read@ Previous@)
    )                                        ;if
    (setq Code# (nth 0 Read@))
    (setq Value (nth 1 Read@))
    (cond
      ((= Code# 3)                        ; Fire if picked
       (setq Ang~ (angle CenPt Value)
             Pt1  (polar CenPt Ang~ (* Unit~ 2))
             Pt2  (polar Pt1 Ang~ Unit~)
       )                                ;setq
       (command "INSERT" Flame$ Pt1 1 1 (rtd Ang~))
       (setq FlameArray@
              (append FlameArray@
                      (list (list (entlast) Pt1 Pt2 Ang~))
       (setq Total# (1- Total#))
      )                                        ;case
      ((= Code# 5)                        ; Rotate if moved
       (setq Previous@ Read@)
       (setq Ang~ (angle CenPt Value))
       (setq MainList@ (entmod (subst (cons 50 Ang~)
                                      (assoc 50 MainList@)
                                      MainList@
      )                                        ;case
      ((= Code# 2)                        ; Key was pressed
       (cond
         ((or (= Value 80) (= Value 112)) ;P or p then pause
          (getpoint "\nTroy paused.  Pick mouse to continue. ")
         )                                ;case
         ((or (= Value 81) (= Value 113)) ;Q or q then quit
          (setq Loop nil)
         )                                ;case
         (t
          (princ
            "\nMove mouse to rotate ship, pick mouse to fire, press P to Pause, or Q to quit."
          (princ (strcat "\nTotal: " (itoa Total#) "\n"))
         )                                ;case
       )                                ;case
      )                                        ;case
    )                                        ;cond
                                        ; Move flame objects
    (if        FlameArray@
      (progn
        (setq Cnt# 0
              Nths@ nil
        (foreach List@ FlameArray@
          (setq        Flame^ (nth 0 List@)
                Pt1    (nth 1 List@)
                Pt2    (nth 2 List@)
                Ang~   (nth 3 List@)
          )                                ;setq
          (if
            (or        (and (> (car Pt2) (car East)) (> (car Pt2) (car Pt1)))
                (and (< (car Pt2) (car West)) (< (car Pt2) (car Pt1)))
                (and (> (cadr Pt2) (cadr North))
                     (> (cadr Pt2) (cadr Pt1))
                (and (< (cadr Pt2) (cadr South))
                     (< (cadr Pt2) (cadr Pt1))
            )                                ;or
             (progn
               (command "ERASE" Flame^ "")
               (setq Nths@ (append Nths@ (list Cnt#)))
             )                                ;progn
             (progn
               (command "MOVE" Flame^ "" Pt1 Pt2)
               (setq Pt1 Pt2
                     Pt2 (polar Pt2 Ang~ Unit~)
               (setq List@ (list Flame^ Pt1 Pt2 Ang~))
               (setq FlameArray@ (Change_nth Cnt# List@ FlameArray@))
             )                                ;progn
          )                                ;if
          (setq Cnt# (1+ Cnt#))
        )                                ;foreach
        (if Nths@
          (setq FlameArray@ (Remove_nths Nths@ FlameArray@))
        )                                ;if
      )                                        ;progn
    )                                        ;if
                                        ; Check if Troys are hit
    (setq Cnt# 0
          Nths@        nil
    (foreach List@ TroyArray@                ; Troy list
      (if FlameArray@                        ; Flame list
        (progn
          )                                ;setq
          (setq        Num# 0
                Num@ nil
          (foreach SubList@ FlameArray@
            (setq Flame^ (nth 0 SubList@)
                  Pt2         (nth 2 SubList@)
            )                                ;setq
            (if        (and (> (car Pt2) (+ Xmin~ Radius~))
                     (< (car Pt2) (- Xmax~ Radius~))
                     (> (cadr Pt2) (+ Ymin~ Radius~))
                     (< (cadr Pt2) (- Ymax~ Radius~))
              (if (<= (distance Pt2 CirPt1) Radius~)
                (progn
                  (command "ERASE" CirEnt^ Flame^ "")
                  (setq Num@ (append Num@ (list Num#)))
                  (command "TEXT" "M" CirPt1 Unit~ 0 (itoa Points#))
                  (command "CHPROP" "L" "" "C" Color2 "")
                  (setq TextEnt^ (entlast))
                  (setq Total# (+ Total# Points#))
                  (princ
                  (command "COLOR" Color1_5)
                  (setq        Dia1~ (* Radius~ 2)
                        Dia2~ (* Radius~ 3)
                        Ang~  (dtr 270)
                        Pnts# 7
                  (repeat 3
                    (StarBurst CirPt1 Dia1~ Dia2~ Pnts# Ang~)
                    (delay 0.125)
                    (setq Dia2~        (* Radius~ 3.5)
                          Ang~        (+ Ang~ (/ (* pi 2) (* Pnts# 3)))
                    (command "ERASE" (entlast) "")
                    (delay 0.125)
                    (setq Dia2~        (* Radius~ 3)
                          Ang~        (dtr 90)
                    (delay 0.125)
                          Ang~        (- Ang~ (/ (* pi 2) (* Pnts# 3)))
                    (delay 0.125)
                          Ang~        (dtr 270)
                    (delay 0.125)
                    (delay 0.125)
                          Ang~        (dtr 90)
                    (delay 0.125)
                    (delay 0.125)
                          Ang~        (dtr 270)
                  )                        ;repeat
                  (command "ERASE" TextEnt^ "")
                )                        ;progn
              )                                ;if
            )                                ;if
            (setq Num# (1+ Num#))
          )                                ;foreach
          (if Num@
            (setq FlameArray@ (Remove_nths Num@ FlameArray@))
          )                                ;if
        )                                ;progn
      )                                        ;if
      (if TroyArray@
        (setq TroyArray@
               (Change_nth Cnt# (ChangeArray: List@) TroyArray@)
        (CreateArray: 1)
      )                                        ;if
    )                                        ;foreach
    (if        Nths@
      (setq TroyArray@ (Remove_nths Nths@ TroyArray@))
    )                                        ;if
    (if        (not TroyArray@)
      (CreateArray: 1)
    )                                        ;if
                                        ; Erase Troys that are out of limits
    (setq Cnt# 0)
      )                                        ;setq
      (if (or (and (> (car CirPt1) (car East))
                   (> (car CirPt2) (car CirPt1))
              (and (< (car CirPt1) (car West))
                   (< (car CirPt2) (car CirPt1))
              (and (> (cadr CirPt1) (cadr North))
                   (> (cadr CirPt2) (cadr CirPt1))
              (and (< (cadr CirPt1) (cadr South))
                   (< (cadr CirPt2) (cadr CirPt1))
          )                                ;or
        (progn
          (command "ERASE" CirEnt^ "")
          (setq TroyArray@ (Change_nth Cnt# (AddArray: nil) TroyArray@))
          (setq Counter# (1+ Counter#))
          (if (= Counter# 3)                ;Add Troys per Counter#
            (progn
              (setq Counter# 0)
              (if (< (length TroyArray@) *MaxTroys#*)
                (setq TroyArray@
                       (append TroyArray@ (list (AddArray: nil)))
              )                                ;if
            )                                ;progn
          )                                ;if
        )                                ;progn
      )                                        ;if
    )                                        ;foreach
                                        ; Check if Troys ran into Ship or total points is <= 0
    (setq Cnt# 0
          Passed t
    (while Passed
      (setq List@   (nth Cnt# TroyArray@)
      )                                        ;setq
      (if (or (< (distance CenPt CirPt1) (+ Radius~ (* Unit~ 2.5)))
              (<= Total# 0)
        (progn
          (command "ERASE" MainEnt^ "")
          (cond
            ((= MainNum# 1) (setq Color# Color3)) ;Green
            ((= MainNum# 2) (setq Color# Color4)) ;Cyan
            ((= MainNum# 3) (setq Color# Color6)) ;Magenta
          )                                ;cond
          (command "COLOR" Color#)
          (setq        Dia1~ 1
                Dia2~ 4
                Ang~  (dtr 270)
                Inc#  0
                Inc1~ 0.125
                Inc2~ 0.375
          (repeat 20
            (if        (= Inc# 11)
              (setq Inc1~ -0.125
                    Inc2~ -0.375
            (StarBurst CenPt (* Unit~ Dia1~) (* Unit~ Dia2~) 5 Ang~)
            (delay 0.5)
            (setq Dia1~        (+ Dia1~ Inc1~)
                  Dia2~        (+ Dia2~ Inc2~)
            (setq Ang~ (+ Ang~ (/ (* pi 2) 3)))
            (setq Inc# (1+ Inc#))
          )                                ;repeat
          (setq Total# (- Total# 10))
          (if (<= Total# 0)
            (progn
              (setq MainNum# 3)
              (princ "\nCommand:\nTotal: 0")
            )                                ;progn
          )                                ;if
          (cond
            ((= MainNum# 1)                ; Build Ship 2
             (Refresh:)
             (BuildShip: 2 CenPt)
            )                                ;case
            ((= MainNum# 2)                ; Build Ship 3
             (Refresh:)
             (BuildShip: 3 CenPt)
            )                                ;case
            ((= MainNum# 3)                ; Finished!
             (setq Passed nil
                   Loop        nil
            )                                ;case
          )                                ;cond
          (setq Passed nil)
        )                                ;progn
      )                                        ;if
      (if (> Cnt# (1- (length TroyArray@)))
        (setq Passed nil)
      )                                        ;if
    )                                        ;while
    (if        (< (length TroyArray@) *MinTroys#*)
      (setq TroyArray@ (append TroyArray@ (list (AddArray: nil))))
    )                                        ;if
    (if        (or (/= (getvar "VIEWCTR") CenPt)
            (/= (getvar "VIEWSIZE") ViewSize~)
    )                                        ;if
  )                                        ;while
  (TroyClear)
  (princ
    (strcat "\nCommand:\nTotal: " (itoa Total#) " Finished!")
  (princ)
)                                        ;defun Troy
                                        ; TroyIntro - Introduction
(defun TroyIntro (/            Color#    Divisions#          Fire#
                  Fourth#   Inc~      Increase~        Ltr#          Move#
                  O-Ang~    O-Cnt#    O-Ent^        O-Ins          O-List@
                  O-Pt            O-Pts@    O-Size~        Path#          Path@
                  Path1@    Path2@    Path3@        Path4@          R-Ang~
                  R-Cen            R-Cnt#    R-Ent^        R-Ins          R-List@
                  R-Pt            R-Pts@    R-Size~        Rotate~          Rnd#
                  RndLtr@   Sevenths  Step~        T-Ang~          T-Cen
                  T-Cnt#    T-Ent^    T-Ins        T-List@          T-Pt
                  T-Pts@    T-Size~   Tl-Ang~        TxSize~          TxSizeInc~
                  TxSizeMax~              TxSizeMin~          Y-Ang~
                  Y-Cnt#    Y-Ent^    Y-Ins        Y-List@          Y-Pt
                  Y-Pts@    Y-Size~
  (princ "\nTroy Intro.\n")
  (command "STYLE" "Troy" "ROMAND" "0.0" "1" "" "" "" "")
  (setq        T-Pt           (polar CenPt pi (* Unit~ 4.5))
        R-Pt           (polar CenPt pi (* Unit~ 1.5))
        O-Pt           (polar CenPt 0 (* Unit~ 1.5))
        Y-Pt           (polar CenPt 0 (* Unit~ 4.5))
        TxSizeMax~ (* Unit~ 3)
        TxSizeMin~ (* Unit~ 0.5)
        Inc~           (* Unit~ 2)                ;Speed of letters
        Pt0           (polar R-Pt
                          (- (angle R-Pt SouthWest) 0.009)
                          (distance R-Pt SouthWest)
        Pt           (polar R-Pt (angle R-Pt Pt0) (/ (distance R-Pt Pt0) 2.0))
        Pt           (polar Pt
                          (+ (angle R-Pt Pt0) (* pi 0.5))
                          (/ (distance R-Pt Pt0) 7.0)
        R-Cen           (Center3Pt R-Pt Pt Pt0)
        Radius~           (distance R-Pt R-Cen)
        Ang~           (* (- (* pi 0.5) (acos (/ (/ Inc~ 2.0) Radius~))) 2)
        Inc#           (fix        (/ (- (angle R-Cen R-Pt) (angle R-Cen SouthWest)) Ang~)
        Pt0           (polar T-Pt
                          (- (angle T-Pt NorthWest) 0.043)
        Pt           (polar T-Pt (angle T-Pt Pt0) (/ (distance R-Pt Pt0) 2.0))
        Pt           (polar Pt
                          (+ (angle T-Pt Pt0) (* pi 0.5))
        T-Cen           (Center3Pt T-Pt Pt Pt0)
        TxSizeInc~ (/ (- TxSizeMax~ TxSizeMin~) (float Inc#))
        TxSize~           TxSizeMax~
        T-Pts@           (list T-Pt)
        R-Pts@           (list R-Pt)
        O-Pts@           (list O-Pt)
        Y-Pts@           (list Y-Pt)
        T-Ang~           0
  )                                        ;setq
  (repeat Inc#
    (setq T-Pt          (polar T-Cen (- (angle T-Cen T-Pt) Ang~) Radius~)
          T-Pts@  (append T-Pts@ (list T-Pt))
          R-Pt          (polar R-Cen (- (angle R-Cen R-Pt) Ang~) Radius~)
          R-Pts@  (append R-Pts@ (list R-Pt))
          O-Pt          (polar CenPt (angle R-Pt CenPt) (distance R-Pt CenPt))
          O-Pts@  (append O-Pts@ (list O-Pt))
          Y-Pt          (polar CenPt (angle T-Pt CenPt) (distance T-Pt CenPt))
          Y-Pts@  (append Y-Pts@ (list Y-Pt))
          T-Ang~  (- T-Ang~ (dtr 30))
          TxSize~ (- TxSize~ TxSizeInc~)
    )                                        ;setq
  )                                        ;repeat
  (setq        T-Pts@        (reverse T-Pts@)
        R-Pts@        (reverse R-Pts@)
        O-Pts@        (reverse O-Pts@)
        Y-Pts@        (reverse Y-Pts@)
        R-Ang~        T-Ang~
        O-Ang~        T-Ang~
        Y-Ang~        T-Ang~
        T-Size~        TxSize~
        R-Size~        TxSize~
        O-Size~        TxSize~
        Y-Size~        TxSize~
        T-Cnt#        0
        R-Cnt#        0
        O-Cnt#        0
        Y-Cnt#        0
        Fourth#        (/ Inc# 4)
  )                                        ;setq
  (setq        T-Pt        (last T-Pts@)
        R-Pt        (last R-Pts@)
        O-Pt        (last O-Pts@)
        Y-Pt        (last Y-Pts@)
        RndLtr@        (list 0)
  (while (/= (length RndLtr@) 5)
    (setq Rnd# (1+ (GetRnd 3)))
    (cond
      ((= Rnd# 1) (setq Pt T-Pt))
      ((= Rnd# 2) (setq Pt R-Pt))
      ((= Rnd# 3) (setq Pt O-Pt))
      ((= Rnd# 4) (setq Pt Y-Pt))
    )                                        ;cond
    (if        (not (member Pt RndLtr@))
      (setq RndLtr@ (append RndLtr@ (list Pt)))
    )                                        ;if
  )                                        ;while
        Dist~          (/ (distance NorthWest NorthEast) 10)
  )                                        ;setq
  (repeat 20
    )                                        ;setq
  )                                        ;repeat
  (setq        Step~           (* Unit~ 1.5)        ;Speed of red ship
        Pt1           (polar SouthWest
                          (dtr 90)
                          (/ (distance SouthWest NorthWest) 6.0)
        Pt2           (polar Pt1 0 (/ (distance SouthWest SouthEast) 3.0))
        Pt           (polar Pt1 0 (/ (distance Pt1 Pt2) 2.0))
        Pt           (polar Pt (dtr 90) (* Unit~ 2))
        Pt           (Center3Pt Pt1 Pt Pt2)
        Radius~           (distance Pt Pt1)
        Tl-Ang~           (- (angle Pt Pt1) (angle Pt Pt2))
        Ang~           (* 2 (- (* pi 0.5) (acos (/ (* Step~ 0.5) Radius~))))
        Divisions# (fix (1+ (/ Tl-Ang~ Ang~)))
        Pt2           (polar Pt (- (angle Pt Pt1) (* Ang~ Divisions#)) Radius~)
  )                                        ;setq
  (setq Path1@ (list Pt1))
  (repeat Divisions#
    (setq Pt1 (polar Pt (- (angle Pt Pt1) Ang~) Radius~))
    (setq Path1@ (append Path1@ (list Pt1)))
  )                                        ;repeat
  (setq Pt (polar Pt (angle Pt Pt2) (* Radius~ 2)))
  (repeat (fix (1+ (/ Divisions# 2.0)))
    (setq Pt1 (polar Pt (+ (angle Pt Pt1) Ang~) Radius~))
    (if        (< (angle Pt Pt1) (dtr 270))
    )                                        ;if
  )                                        ;repeat
  (setq        Pt1           (last Path1@)
        Pt2           (inters Pt1 (polar Pt1 0 Unit~) NorthEast SouthEast nil)
        Ang~           (atan (/ 1 2.0))
        Radius~           (* (distance Pt1 Pt2) (tan Ang~))
        Pt           (polar Pt1 (dtr 90) Radius~)
        Tl-Ang~           (atan (/ (distance Pt1 Pt2) Radius~))
  )                                        ;setq
  (repeat Divisions#
  )                                        ;repeat
  (setq        Pt           Pt2
        Tl-Ang~           (- (angle Pt Pt1) (* pi 0.5))
  )                                        ;setq
  (repeat Divisions#
    (setq Pt2 Pt1)
    (if        (> (angle Pt Pt1) (* pi 0.5))
    )                                        ;if
  )                                        ;repeat
  (setq Ang~ (angle Pt2 Pt1))
  (repeat 5
    (setq Pt1 (polar Pt1 Ang~ Step~))
  )                                        ;repeat
  (setq Ang~ (angle (nth 1 Path1@) (nth 0 Path1@)))
  (repeat 5
    (setq Pt (polar (nth 0 Path1@) Ang~ Step~))
    (setq Path1@ (Insert_nth 0 Pt Path1@))
  )                                        ;repeat
  (foreach Item        Path1@
    (setq Pt2 (MirrorPt Item CenPt 0))
    (setq Path2@ (append Path2@ (list Pt2)))
    (setq Pt3 (MirrorPt Item CenPt (dtr 90)))
    (setq Path3@ (append Path3@ (list Pt3)))
    (setq Pt4 (MirrorPt Pt3 CenPt 0))
    (setq Path4@ (append Path4@ (list Pt4)))
  )                                        ;foreach
  (setq Path# (1+ (GetRnd 3)))
  (cond
    ((= Path# 1) (setq Path@ Path1@))
    ((= Path# 2) (setq Path@ Path2@))
    ((= Path# 3) (setq Path@ Path3@))
    ((= Path# 4) (setq Path@ Path4@))
  )                                        ;cond
                                        ; First Loop
  (setq Loop t)
  (while Loop
    (if        (<= T-Cnt# Inc#)
      (if (= T-Cnt# 0)
        (progn
          (command "TEXT"
                   "M"
                   (nth T-Cnt# T-Pts@)
                   T-Size~
                   (rtd T-Ang~)
                   "T"
          (setq T-Ent^ (entlast))
          (command "CHPROP" T-Ent^ "" "C" Color3 "") ;Green
          (setq        T-List@        (entget T-Ent^)
                T-Size~        (+ T-Size~ TxSizeInc~)
                T-Ang~        (+ T-Ang~ (dtr 30))
                T-Cnt#        (1+ T-Cnt#)
                T-Ins        (nth T-Cnt# T-Pts@)
          )                                ;setq
        )                                ;progn
        (progn
          (setq        T-List@        (entmod        (subst (cons 50 T-Ang~)
                                       (assoc 50 T-List@)
                                       T-List@
          (setq        T-List@
                 (entmod
                   (subst (cons 11 T-Ins) (assoc 11 T-List@) T-List@)
          (setq        T-List@        (entmod        (subst (cons 40 T-Size~)
                                       (assoc 40 T-List@)
                                       T-List@
          (setq        T-Size~        (+ T-Size~ TxSizeInc~)
                T-Cnt#        (1+ T-Cnt#)
          )                                ;setq
            (setq T-Ins (nth T-Cnt# T-Pts@))
        )                                ;progn
      )                                        ;if
    )                                        ;if
    (if        (>= T-Cnt# Fourth#)
      (if (<= R-Cnt# Inc#)
        (if (= R-Cnt# 0)
          (progn
            (command "TEXT"
                     "M"
                     (nth R-Cnt# R-Pts@)
                     R-Size~
                     (rtd R-Ang~)
                     "R"
            (setq R-Ent^ (entlast))
            (command "CHPROP" R-Ent^ "" "C" Color4 "") ;Cyan
            (setq R-List@ (entget R-Ent^)
                  R-Size~ (+ R-Size~ TxSizeInc~)
                  R-Ang~  (+ R-Ang~ (dtr 30))
                  R-Cnt#  (1+ R-Cnt#)
                  R-Ins          (nth R-Cnt# R-Pts@)
            )                                ;setq
          )                                ;progn
          (progn
            (setq R-List@ (entmod (subst (cons 50 R-Ang~)
                                         (assoc 50 R-List@)
                                         R-List@
            (setq R-List@ (entmod (subst (cons 11 R-Ins)
                                         (assoc 11 R-List@)
                                         R-List@
            (setq R-List@ (entmod (subst (cons 40 R-Size~)
                                         (assoc 40 R-List@)
                                         R-List@
            (setq R-Size~ (+ R-Size~ TxSizeInc~)
                  R-Cnt#  (1+ R-Cnt#)
            )                                ;setq
              (setq R-Ins (nth R-Cnt# R-Pts@))
          )                                ;progn
        )                                ;if
      )                                        ;if
    )                                        ;if
    (if        (>= R-Cnt# Fourth#)
      (if (<= O-Cnt# Inc#)
        (if (= O-Cnt# 0)
          (progn
            (command "TEXT"
                     "M"
                     (nth O-Cnt# O-Pts@)
                     O-Size~
                     (rtd O-Ang~)
                     "O"
            (setq O-Ent^ (entlast))
            (command "CHPROP" O-Ent^ "" "C" Color5 "") ;Blue
            (setq O-List@ (entget O-Ent^)
                  O-Size~ (+ O-Size~ TxSizeInc~)
                  O-Ang~  (+ O-Ang~ (dtr 30))
                  O-Cnt#  (1+ O-Cnt#)
                  O-Ins          (nth O-Cnt# O-Pts@)
            )                                ;setq
          )                                ;progn
          (progn
            (setq O-List@ (entmod (subst (cons 50 O-Ang~)
                                         (assoc 50 O-List@)
                                         O-List@
            (setq O-List@ (entmod (subst (cons 11 O-Ins)
                                         (assoc 11 O-List@)
                                         O-List@
            (setq O-List@ (entmod (subst (cons 40 O-Size~)
                                         (assoc 40 O-List@)
                                         O-List@
            (setq O-Size~ (+ O-Size~ TxSizeInc~)
                  O-Cnt#  (1+ O-Cnt#)
            )                                ;setq
              (setq O-Ins (nth O-Cnt# O-Pts@))
          )                                ;progn
        )                                ;if
      )                                        ;if
    )                                        ;if
    (if        (>= O-Cnt# Fourth#)
      (if (<= Y-Cnt# Inc#)
        (if (= Y-Cnt# 0)
          (progn
            (command "TEXT"
                     "M"
                     (nth Y-Cnt# Y-Pts@)
                     Y-Size~
                     (rtd Y-Ang~)
                     "Y"
            (setq Y-Ent^ (entlast))
            (command "CHPROP" Y-Ent^ "" "C" Color6 "") ;Magenta
            (setq Y-List@ (entget Y-Ent^)
                  Y-Size~ (+ Y-Size~ TxSizeInc~)
                  Y-Ang~  (+ Y-Ang~ (dtr 30))
                  Y-Cnt#  (1+ Y-Cnt#)
                  Y-Ins          (nth Y-Cnt# Y-Pts@)
            )                                ;setq
          )                                ;progn
          (progn
            (setq Y-List@ (entmod (subst (cons 50 Y-Ang~)
                                         (assoc 50 Y-List@)
                                         Y-List@
            (setq Y-List@ (entmod (subst (cons 11 Y-Ins)
                                         (assoc 11 Y-List@)
                                         Y-List@
            (setq Y-List@ (entmod (subst (cons 40 Y-Size~)
                                         (assoc 40 Y-List@)
                                         Y-List@
            (setq Y-Size~ (+ Y-Size~ TxSizeInc~)
                  Y-Cnt#  (1+ Y-Cnt#)
            )                                ;setq
              (setq Y-Ins (nth Y-Cnt# Y-Pts@))
          )                                ;progn
        )                                ;if
      )                                        ;if
    )                                        ;if
    (setq Cnt# 0)
      )                                        ;setq
      (if (> (distance CenPt CirPt1) CirLimits~)
        (progn
        )                                ;progn
        (setq TroyArray@
      )                                        ;if
    )                                        ;foreach
    (delay 0.15)                        ;Speed of Loop
    (if        (> Y-Cnt# Inc#)
      (setq Loop nil)
    )                                        ;if
  )                                        ;while
                                        ; Second Loop
  (setq        Loop          t
        Move#          0
        Ltr#          0
        Sevenths# (/ (length Path@) 7)
        Fire#          (1+ Sevenths#)
  (BuildShip: 0 (nth 0 Path@))
  (if (> Path# 2)
    (setq MainList@
           (entmod
             (subst (cons 42 -1.0) (assoc 42 MainList@) MainList@)
  )                                        ;if
  (while Loop
                                        ; Move Ship
    (setq Pt1  (nth Move# Path@)
          Pt2  (nth (1+ Move#) Path@)
          Ang~ (angle Pt1 Pt2)
    )                                        ;setq
                                        ;(command "LINE" Pt1 Pt2 "");Uncomment while debuging
    (setq MainList@
           (entmod
             (subst (cons 50 Ang~) (assoc 50 MainList@) MainList@)
    (setq
      MainList@        (entmod
                  (subst (cons 10 Pt1) (assoc 10 MainList@) MainList@)
                                        ; Fire at Troy Letters
    (setq Fire# (1+ Fire#))
    (if        (= Fire# (fix (* Sevenths# 2.5)))
      (setq Fire# Sevenths#)
    )                                        ;First time
    (if        (= Fire# Sevenths#)                ;Fire in these intervals
      (progn
        (setq Fire# 0
              Ltr#  (1+ Ltr#)
        (if (member Ltr# (list 1 2 3 4))
          (progn
            (setq Pt   (nth Ltr# RndLtr@)
                  Ang~ (angle Pt1 Pt)
                  Pt1  (polar Pt1 Ang~ (* Unit~ 2))
            )                                ;setq
            (setq FlameArray@
                   (append FlameArray@
          )                                ;progn
        )                                ;if
      )                                        ;progn
    )                                        ;if
    (if        FlameArray@
      (progn
        (setq Cnt# 0
              Nth# nil
                Pt1    (nth 1 List@)
                Pt2    (nth 2 List@)
                Ang~   (nth 3 List@)
          )                                ;setq
          (if
            )                                ;or
             (progn
               (setq Nth# Cnt#)
             )                                ;progn
             (progn
               (setq Pt1 Pt2
             )                                ;progn
          )                                ;if
        )                                ;foreach
        (if Nth#
          (setq FlameArray@ (Delete_nth Nth# FlameArray@))
        )                                ;if
      )                                        ;progn
    )                                        ;if
                                        ; Check to see if Troy Letters are hit
    (if        FlameArray@
      (progn
        (setq Num# 0)
          (setq        Ent^ (nth 0 List@)
                Pt2  (nth 2 List@)
                Pt   nil
          )                                ;setq
          (cond
            ((<= (distance Pt2 T-Pt) Unit~)
             (command "ERASE" T-Ent^ Ent^ "")
             (setq FlameArray@ (Delete_nth Num# FlameArray@))
             (setq Pt          T-Pt
                   T-Pt          SouthWest
                   Color# Color3
             )                                ;Green
            )                                ;case
            ((<= (distance Pt2 R-Pt) Unit~)
             (command "ERASE" R-Ent^ Ent^ "")
             (setq Pt          R-Pt
                   R-Pt          SouthWest
                   Color# Color4
             )                                ;Cyan
            )                                ;case
            ((<= (distance Pt2 O-Pt) Unit~)
             (command "ERASE" O-Ent^ Ent^ "")
             (setq Pt          O-Pt
                   O-Pt          SouthWest
                   Color# Color5
             )                                ;Blue
            )                                ;case
            ((<= (distance Pt2 Y-Pt) Unit~)
             (command "ERASE" Y-Ent^ Ent^ "")
             (setq Pt          Y-Pt
                   Y-Pt          SouthWest
                   Color# Color6
             )                                ;Magenta
            )                                ;case
          )                                ;cond
                                        ; Explode Letter
          (if Pt
            (progn
              (setq Dia1~ 0.5
                    Dia2~ 3
                    Ang~  (* (GetRnd 6283) 0.001)
                    Inc#  0
                    Inc1~ 0.125
                    Inc2~ 0.375
              (repeat 10
                (if (= Inc# 6)
                  (setq        Inc1~ -0.125
                        Inc2~ -0.375
                (StarBurst Pt
                           (* Unit~ Dia1~)
                           (* Unit~ Dia2~)
                           (+ (GetRnd 5) 5)
                           Ang~
                (delay 0.125)
                (setq Ang~ (* (GetRnd 6283) 0.001))
              )                                ;repeat
            )                                ;progn
          )                                ;if
        )                                ;foreach
      )                                        ;progn
    )                                        ;if
    (setq Cnt# 0)
      )                                        ;setq
        (progn
        )                                ;progn
        (setq TroyArray@
      )                                        ;if
    )                                        ;foreach
    (setq Move# (1+ Move#))
    (if        (= Move# (1- (length Path@)))
      (setq Loop nil)
    )                                        ;if
  )                                        ;while
  (princ)
)                                        ;defun TroyIntro
                                        ; TroyClear - Troy clear function
(defun TroyClear (/ Block$ Passed SS&)
  (if *TroyTab$*
    (command "LAYOUT" "S" *TroyTab$*)
  (if *Clayer$*
    (setvar "CLAYER" *Clayer$*)
  (if *Osmode#*
    (setvar "OSMODE" *Osmode#*)
  (if *TextStyle$*
    (setvar "TEXTSTYLE" *TextStyle$*)
  (if *TextSize~*
    (setvar "TEXTSIZE" *TextSize~*)
  )                                        ;if
  (setq Block$ (strcat (substr (UniqueName) 1 5) "*"))
  (foreach Item        (GetBlockList)
    (if        (wcmatch Item Block$)
      (setq Passed t)
  )                                        ;foreach
  (if Passed
    (command "PURGE" "BL" Block$ "N")
    (command "PURGE" "LA" "Troy" "N")
  (if (tblsearch "STYLE" "Troy")
    (command "PURGE" "ST" "Troy" "N")
  (setq        *Clayer$* nil
        *Osmode#* nil
        *TextStyle$* nil
        *TextSize~* nil
  (PurgeGroups)
  (if *CTab$*
    (progn (command "LAYOUT" "S" *CTab$*)
           (setq *CTab$* nil
                 *TroyTab$* nil
  )                                        ;if
  (repeat 45 (princ (strcat "\n" (chr 160))))
  (princ)
)                                        ;defun TroyClear
                                        ; Start of Troy Support Utility Functions
                                        ; acos
                                        ; Arguments: 1
                                        ;   x = real number between 0 and 1. May be passed as the sum of dividing two
                                        ;       sides of a right triangle.
                                        ; Returns: acos of x, the radian degrees between sides of a right triangle
(defun acos (x)
  (atan (/ (sqrt (- 1 (* x x))) x))
)                                        ;defun acos
                                        ; asin
                                        ; Arguments: 1
                                        ;   sine = real number between -1 to 1
                                        ; Returns: arcsin of sine
(defun asin (sine / cosine)
  (setq cosine (sqrt (- 1.0 (expt sine 2))))
  (if (zerop cosine)
    (setq cosine 0.000000000000000000000000000001)
  )                                        ;if
  (atan (/ sine cosine))
)                                        ;defun asin
                                        ; Center3Pt - Center point of 3 points on a circle
                                        ; Arguments: 3
                                        ;   Pt1 = First point
                                        ;   Pt2 = Second point
                                        ;   Pt3 = Third point
                                        ; Returns: Center point of 3 points on a circle
(defun Center3Pt (Pt1 Pt2 Pt3 / Pt Pt4 Pt5 Pt6 Pt7)
  (setq        Pt4 (polar Pt1 (angle Pt1 Pt2) (/ (distance Pt1 Pt2) 2.0))
        Pt5 (polar Pt4 (+ (angle Pt1 Pt2) (* pi 0.5)) 1)
        Pt6 (polar Pt2 (angle Pt2 Pt3) (/ (distance Pt2 Pt3) 2.0))
        Pt7 (polar Pt6 (+ (angle Pt2 Pt3) (* pi 0.5)) 1)
        Pt  (inters Pt4 Pt5 Pt6 Pt7 nil)
  )                                        ;setq
)                                        ;defun Center3Pt
                                        ; Change_nth - Changes the nth item in a list with a new item value.
                                        ; Arguments: 3
                                        ;   Num# = Nth number in list to change
                                        ;   Value = New item value to change to
                                        ;   OldList@ = List to change item value
                                        ; Returns: A list with the nth item value changed.
(defun Change_nth (Num# Value OldList@ / Cnt# Item NewList@ NewValue)
  (if (and (= (type Num#) 'int) (= (type OldList@) 'list))
    (progn
      (setq Cnt# 0)
      (foreach Item OldList@
        (if (= Cnt# Num#)
          (setq NewValue Value)
          (setq NewValue Item)
        )                                ;if
        (if NewList@
          (setq NewList@ (append NewList@ (list NewValue)))
          (setq NewList@ (list NewValue))
        )                                ;if
      )                                        ;foreach
    )                                        ;progn
    (setq NewList@ OldList@)
  )                                        ;if
  NewList@
)                                        ;defun Change_nth
                                        ; delay - time delay function
                                        ; Arguments: 1
                                        ;   Percent~ - Percentage of *Speed# variable
                                        ; Returns: time delay
(defun delay (Percent~ / Number~)
  (if (not *Speed#)
    (Speed)
  (repeat (fix (* *Speed# Percent~)) (setq Number~ pi))
  (princ)
)                                        ;defun delay
                                        ; Delete_nth - Deletes the nth item from a list.
                                        ; Arguments: 2
                                        ;   Num# = Nth number in list to delete
                                        ;   OldList@ = List to delete the nth item
                                        ; Returns: A list with the nth item deleted.
(defun Delete_nth (Num# OldList@ / Cnt# Item NewList@)
    (progn
      (setq Cnt# 0)
        (if (/= Cnt# Num#)
          (if NewList@
            (setq NewList@ (append NewList@ (list Item)))
            (setq NewList@ (list Item))
          )                                ;if
        )                                ;if
      )                                        ;foreach
    )                                        ;progn
  )                                        ;if
  NewList@
)                                        ;defun Delete_nth
                                        ; dtr - Degrees to Radians.
                                        ; Arguments: 1
                                        ;   Deg~ = Degrees
                                        ; Syntax: (dtr Deg~)
                                        ; Returns: Value in radians.
(defun dtr (Deg~)
  (* pi (/ Deg~ 180.0))
)                                        ;defun dtr
                                        ; GetBlockList
(defun GetBlockList (/ BlockList@ Block$)
  (if (setq Block$ (cdr (assoc 2 (tblnext "BLOCK" t))))
    (progn
      (setq BlockList@ (append BlockList@ (list Block$)))
      (while (setq Block$ (cdr (assoc 2 (tblnext "BLOCK"))))
      )                                        ;while
    )                                        ;progn
    (setq BlockList@ (list ""))
  )                                        ;if
  (Acad_StrlSort BlockList@)
)                                        ;defun GetBlockList
                                        ; GetRnd - Generates a random number
                                        ; Arguments: 1
                                        ;   Num# = Maximum random integer number range greater than or less than 0.
                                        ; Returns: Random integer number between 0 and Num#.
(defun GetRnd (Num# / MaxNum# PiDate$ RndNum# Minus Loop)
  (if (or (/= (type Num#) 'INT) (= Num# 0))
    (progn
      (princ
        "\nSyntax: (GetRnd Num#) Num# = Maximum random integer number range\ngreater than or less than 0."
      (exit)
    )                                        ;progn
  )                                        ;if
  (if (< Num# 0)
    (setq MaxNum# (abs (1- Num#))
          Minus          t
    (setq MaxNum# (1+ Num#))
  )                                        ;if
  (if (not *RndNum*)
    (setq *RndNum* 10000)
  (setq Loop t)
  (while Loop
    (if        (or (null *int*) (> *int* 100))
      (setq *int* 1)
      (setq *int* (1+ *int*))
    )                                        ;if
    (setq PiDate$ (rtos (* (getvar "cdate") (* pi *int*)) 2 8))
    (cond
      ((>= MaxNum# 10000)
       (setq RndNum#
              (fix
                (* (atof (substr PiDate$ 13 5)) (* MaxNum# 0.00001))
      ((>= MaxNum# 1000)
       (setq RndNum#
              (fix (* (atof (substr PiDate$ 14 4)) (* MaxNum# 0.0001))
      ((>= MaxNum# 100)
       (setq RndNum#
              (fix (* (atof (substr PiDate$ 15 3)) (* MaxNum# 0.001))
      ((>= MaxNum# 10)
       (setq RndNum#
              (fix (* (atof (substr PiDate$ 16 2)) (* MaxNum# 0.01)))
      ((>= MaxNum# 1)
       (setq RndNum#
              (fix (* (atof (substr PiDate$ 17 1)) (* MaxNum# 0.1)))
      (t (setq RndNum# 0))
    )                                        ;cond
    (if        (/= RndNum# *RndNum*)
      (setq Loop nil)
    )                                        ;if
  )                                        ;while
  (setq *RndNum* RndNum#)
  (if Minus
    (setq RndNum# (* RndNum# -1))
  )                                        ;if
  RndNum#
)                                        ;defun GetRnd
                                        ; Insert_nth - Inserts a new item value into the nth number in list.
                                        ; Arguments: 3
                                        ;   Num# = Nth number in list to insert item value
                                        ;   Value = Item value to insert
                                        ;   OldList@ = List to insert item value
                                        ; Returns: A list with the new item value inserted.
(defun Insert_nth (Num# Value OldList@ / Cnt# Item NewList@)
    (progn
      (setq Cnt# 0)
        (if (= Cnt# Num#)
          (progn
            (if        NewList@
              (setq NewList@ (append NewList@ (list Value)))
              (setq NewList@ (list Value))
            )                                ;if
            (if        NewList@
            )                                ;if
          )                                ;progn
          (if NewList@
          )                                ;if
        )                                ;if
      )                                        ;foreach
      (if (>= Num# (length OldList@))
        (if NewList@
        )                                ;if
      )                                        ;if
    )                                        ;progn
  )                                        ;if
  NewList@
)                                        ;defun Insert_nth
                                        ; MirrorPt - Mirror point
                                        ; Arguments: 3
                                        ;   Pt = Point to mirror
                                        ;   BasePt = Base point
                                        ;   Angle~ = Mirror angle in radians
                                        ; Returns: Returns location of mirrored point
(defun MirrorPt        (Pt BasePt Angle~ / Pt1)
  (if (> Angle~ pi)
    (setq Angle~ (- Angle~ pi))
  )                                        ;if
  (setq        Pt1 (inters Pt
                    (polar Pt (+ Angle~ (* pi 0.5)) 1)
                    BasePt
                    (polar BasePt Angle~ 1)
                    nil
        Pt1 (polar Pt1 (angle Pt Pt1) (distance Pt Pt1))
  )                                        ;setq
)                                        ;defun MirrorPt
                                        ; Move_nth - Moves the nth Num1# item value to the nth Num2# location in a list.
                                        ; Arguments: 3
                                        ;   Num1# = Nth number in list to move item value
                                        ;   Num2# = Nth number in list to move item value of nth Num1# into
                                        ;   OldList@ = List to move item values
                                        ; Returns: A list with two item values moved.
(defun Move_nth
       (Num1# Num2# OldList@ / Cnt# Item NewList@ Num1Value Valid)
  (if (and (= (type Num1#) 'int)
           (= (type Num2#) 'int)
    (setq Valid t)
  )                                        ;if
  (if (and Valid
           (< Num1# (length OldList@))
           (< Num2# (length OldList@))
           (/= Num1# Num2#)
      )                                        ;and
    (progn
      (setq Cnt# 0)
      (setq Num1Value (nth Num1# OldList@))
        (if (/= Cnt# Num1#)
          (if (< Num1# Num2#)
            (if        (/= Cnt# Num2#)
              (if NewList@
              )                                ;if
              (progn
                (if NewList@
                )                        ;if
                (if NewList@
                  (setq NewList@ (append NewList@ (list Num1Value)))
                  (setq NewList@ (list Num1Value))
                )                        ;if
              )                                ;progn
            )                                ;if
            (if        (/= Cnt# Num2#)
              (if NewList@
              )                                ;if
              (progn
                (if NewList@
                )                        ;if
                (if NewList@
                )                        ;if
              )                                ;progn
            )                                ;if
          )                                ;if
        )                                ;if
      )                                        ;foreach
    )                                        ;progn
  )                                        ;if
  NewList@
)                                        ;defun Move_nth
                                        ; PurgeGroups - Purge Unused Groups
(defun PurgeGroups (/                 AllGroups@   Cnt#           Dictionary^
                    EntFirst^         EntList@     FirstGroup$  Group^
                    GroupName$         Item              Previous$           Pt
                    SS&                 UsedGroups@
  (setq        Pt (polar (getvar "VIEWCTR")
                  (* pi 1.5)
  (command "LINE" Pt (polar Pt (* pi 1.5) 0.00000001) "")
  (setq EntFirst^ (entlast))
  (setq FirstGroup$ (UniqueName))
  (command "-GROUP" "C" FirstGroup$ "" EntFirst^ "")
  (setq EntList@ (entget EntFirst^))
  (setq Group^ (cdr (assoc 330 EntList@)))
  (setq EntList@ (entget Group^))
  (setq Dictionary^ (cdr (assoc 330 EntList@)))
  (setq EntList@ (entget Dictionary^))
  (foreach Item        EntList@
    (if        (= (car Item) 3)
      (if (not (member (cdr Item) AllGroups@))
        (setq AllGroups@ (append AllGroups@ (list (cdr Item))))
      )                                        ;if
    )                                        ;if
  )                                        ;foreach
  (setq SS& (ssget "X"))
  (setq Cnt# 0)
  (repeat (sslength SS&)
    (setq EntList@ (entget (ssname SS& Cnt#)))
    (if        (= (cdr (assoc 102 EntList@)) "{ACAD_REACTORS")
      (progn
        (if (setq Dictionary^ (cdr (assoc 330 EntList@)))
          (progn
            (setq Previous$ "")
              (setq Item (cdr Item))
              (if (equal Item Group^)
                (setq GroupName$ Previous$)
              )                                ;if
              (setq Previous$ Item)
            )                                ;foreach
            (if        (not (member GroupName$ UsedGroups@))
              (setq UsedGroups@ (append UsedGroups@ (list GroupName$)))
            )                                ;if
          )                                ;progn
        )                                ;if
      )                                        ;progn
    )                                        ;if
  )                                        ;repeat
  (foreach GroupName$ AllGroups@
      (command "-GROUP" "E" GroupName$)
    )                                        ;if
  )                                        ;foreach
  (command "-GROUP" "E" FirstGroup$)
  (command "ERASE" EntFirst^ "")
  (princ)
)                                        ;defun PurgeGroups
                                        ; Remove_nths - Removes the RemoveList@ of nths from a list.
                                        ; Arguments: 2
                                        ;   RemoveList@ = List of nths to remove
                                        ;   OldList@ = List to remove the list of nths from
                                        ; Returns: A list with the list of nths removed.
(defun Remove_nths (RemoveList@ OldList@ / Cnt# Item NewList@)
  (setq Cnt# 0)
    (if        (not (member Cnt# RemoveList@))
    )                                        ;if
  )                                        ;foreach
  NewList@
)                                        ;defun Remove_nths
                                        ; rtd - Radians to degrees
                                        ; Arguments: 1
                                        ;   Rad~ = radians
                                        ; Syntax: (rtd R)
                                        ; Returns: value in degrees.
(defun rtd (Rad~)
  (* 180.0 (/ Rad~ pi))
)                                        ;defun rtd
                                        ; Speed - Determines the computer processing speed and sets the global variable
                                        ; *speed# which may be used in delay loops.
(defun Speed (/ Cdate~ Cnt# NewSecond# OldSecond#)
  (setq Cdate~ (getvar "CDATE"))
  (setq        NewSecond#
         (fix (* (- (* (- Cdate~ (fix Cdate~)) 100000)
                    (fix (* (- Cdate~ (fix Cdate~)) 100000))
                 10
  (repeat 2
    (setq Cnt# 0)
    (setq OldSecond# NewSecond#)
    (while (= NewSecond# OldSecond#)
      (setq NewSecond#
                     10
    )                                        ;while
  )                                        ;repeat
  (setq *Speed# Cnt#)
  (princ)
)                                        ;defun Speed
                                        ; StarBurst - Draws a starburst shape
                                        ; Arguments: 5
                                        ;   CenPt = Center of starburst
                                        ;   Dia1~ = Inside diameter
                                        ;   Dia2~ = Outside diameter
                                        ;   Sides# = Number of points
                                        ;   StartAng~ = Radian angle of first point
                                        ; Returns: Draws a starburst shape
(defun StarBurst (CenPt           Dia1~    Dia2~    Sides#   StartAng~
                  /           Ang~            Ang1~    List@    List1@   List2@
                  List3@   Cnt1#    Cnt2#    Pt
  (setq Ang~ (/ pi Sides#))
  (setq Ang1~ (+ StartAng~ (/ Ang~ 2.0)))
  (repeat (* Sides# 2)
    (setq Pt (polar CenPt Ang1~ (/ Dia1~ 2.0)))
    (setq List1@ (append List1@ (list Pt)))
    (setq Ang1~ (+ Ang1~ Ang~))
  )                                        ;repeat
  (setq Ang1~ (+ StartAng~ Ang~))
  (repeat Sides#
    (setq Pt (polar CenPt Ang1~ (/ (+ Dia1~ Dia2~) 4.0)))
    (setq List2@ (append List2@ (list Pt)))
    (setq Ang1~ (+ Ang1~ (* Ang~ 2)))
  )                                        ;repeat
  (setq Ang1~ StartAng~)
  (repeat Sides#
    (setq Pt (polar CenPt Ang1~ (/ Dia2~ 2.0)))
    (setq List3@ (append List3@ (list Pt)))
  )                                        ;repeat
  (setq        Cnt1# 0
        Cnt2# 0
  (repeat Sides#
    (setq List@ (append List@ (list (nth Cnt1# List3@))))
    (setq List@ (append List@ (list (nth Cnt2# List1@))))
    (setq Cnt2# (1+ Cnt2#))
    (setq List@ (append List@ (list (nth Cnt1# List2@))))
    (setq Cnt1# (1+ Cnt1#))
  )                                        ;repeat
  (setq List@ (append List@ (list (nth 0 List3@))))
  (command "PLINE" (foreach Pt List@ (command Pt)))
  (princ)
)                                        ;defun StarBurst
                                        ; Switch_nth - Switches the nth Num1# and Num2# item values in a list.
                                        ; Arguments: 3
                                        ;   Num1# = nth number in list to switch with nth Num2#
                                        ;   Num2# = nth number in list to switch with nth Num1#
                                        ;   OldList@ = List to switch item values
                                        ; Returns: A list with two item values switched.
(defun Switch_nth
       (Num1# Num2# OldList@ / Cnt# Item NewList@ NewValue Valid)
    (setq Valid t)
  )                                        ;if
  (if (and Valid
           (/= Num1# Num2#)
      )                                        ;and
    (progn
      (setq Cnt# 0)
        (cond
          ((= Cnt# Num1#) (setq NewValue (nth Num2# OldList@)))
          ((= Cnt# Num2#) (setq NewValue (nth Num1# OldList@)))
          (t (setq NewValue Item))
        )                                ;cond
        (if NewList@
        )                                ;if
      )                                        ;foreach
    )                                        ;progn
  )                                        ;if
  NewList@
)                                        ;defun Switch_nth
                                        ; tan - Tangent of radian degrees
                                        ; Arguments: 1
                                        ;   radians = Radian degrees
                                        ; Returns: Tangent of radian degrees
(defun tan (radians)
  (/ (sin radians) (cos radians))
)                                        ;defun tan
                                        ; UniqueName - Creates a unique name for temp blocks and groups
(defun UniqueName (/ Loop Name$)
  (setq Loop t)
  (while Loop
    (setq Name$ (rtos (getvar "CDATE") 2 8))
    (setq Name$ (strcat (substr Name$ 4 5) (substr Name$ 10 8)))
    (if        (/= Name$ *UniqueName$)
      (setq *UniqueName$ Name$
            Loop nil
    )                                        ;if
  )                                        ;while
  *UniqueName$
)                                        ;defun UniqueName
                                        ; ViewExtents
                                        ; Returns: List of upper left and lower right points of current view
(defun ViewExtents (/ A B C D X)
  (setq        B (getvar "VIEWSIZE")
        A (* B
             (/ (car (getvar "SCREENSIZE")) (cadr (getvar "SCREENSIZE")))
        X (trans (getvar "VIEWCTR") 1 2)
        C (trans (list (- (car X) (/ A 2.0)) (+ (cadr X) (/ B 2.0)))
                 2
                 1
        D (trans (list (+ (car X) (/ A 2.0)) (- (cadr X) (/ B 2.0)))
                 2
                 1
  )                                        ;setq
  (list C D)
)                                        ;defun ViewExtents
(princ)
已领礼包: 59个
发表于 2006-12-5 00:45:32 | 显示全部楼层
程序有错误
发表于 2006-12-5 08:22:51 | 显示全部楼层
程序运行确实有错误
可以到
重新下载这个troy
这个程序确实编的挺厉害的
这个网站还有好些好程序,特殊而不落俗套
GMT+8, 2026-10-19 00:00 , Processed in 0.638704 second(s), 42 queries , Gzip On.
