查看: 1408|回复: 0
[求助]:在VB6.0中调用AutoCAD2004出错
发表于 2006-12-7 10:30:48 | 显示全部楼层 |阅读模式
出错信息:
出错提示:
Public Sub 连接AutoCAD()
On Error Resume Next
Set AcadApp = GetObject(, "AutoCAD.Application")
If Err Then
  Err.Clear
  Set AcadApp = CreateObject("AutoCAD.Application")
End If
Acad.Visible = True
End Sub
Private Sub Command1_Click()
Dim DwgName As String
If Right(App.Path, 1) = "\" Then
DwgName = App.Path & "2-1.dwg"
End If
Acad.Documents.Open DwgName——————此句出错
End Sub
GMT+8, 2026-11-2 22:52 , Processed in 0.613583 second(s), 33 queries , Gzip On.
