查看: 979|回复: 2
[其他]:外企高薪诚聘钢结构设计工程师
发表于 2007-1-25 12:18:17 | 显示全部楼层 |阅读模式
OCG company: we are professional HR consultancy located in Shanghai. Our client is a famous international company with office in Shanghai. Currently, we are appointed to search qualified candidate for the following position. We work for our clients and therefore our service for you is free of charge.
结构设计工程师/Structure Design Engineer
职位描述:
职位描述/Description:
1.用UG NX 3.0对钻杆3-D组装和其它组成部分进行参数化实体造型/Solid and parametric modeling derrick stem 3-D assembly and other components using UG NX 3.0
2.与结构分析工程师合作实现钢连接详图设计/Work with structure analysis engineer to realize steel detail connection design
3.钻塔设备的3-D 设计/3-D Design on supports for equipment in derrick
4.2-D UG 绘制 /2-D UG drafting.
要求/Requirement:
•土木结构/机械工程学士以上学位/B. S degree or above in Civil structural/Mechanical engineering
•3年以上UG NX工作经验/Minimum 3 years of working experience with UG NX
•有钢结构设计经验者优先/Steel structure design experience is an advantage.
•很强的技术技能,对机械工程有很深的理解/Strong technical skills and mechanical engineering sense
•在UG 3D模型方面具有很强的分析问题和解决问题的能力/Strong analytical and problem solving skills in UG 3D modeling
•具备良好的沟通技巧、积极主动并具备良好的团队合作精神/Good communication skills, initiative and teamwork spirits
•熟练掌握英语者优先/Good command of English preferable
Structural Engineer
Qualification and Duties;
The Structural Engineer would be required to make engineering drawings/calculations and develop the design of large steel oilfield drilling rig structures. Must be capable of developing reliable, cost effective minimum weight steel structures.
Education: Bachelor in marine/structure/engineering. Junior College with good experience is also acceptable.
Experience: 3 ~ 4 years working experience in offshore/onshore steel structure or ship design.
Familiar with welded and bolted steel structures.
Be fluent in the English language, both written and spoken.
Capable of producing high quality design reports and engineering documentation in English.
Must be willing to accept some traveling.
月薪平均10,000 RMB, 视个人能力而定,但绝对高于市场平均水平.
有兴趣的请将个人中英文建立付照片电邮至:
info@olivecoach.com,  xiaoliyun@yahoo.com, olivecoach@126.com
上海欧立文企业管理咨询有限公司 胡小姐
Thanks and Regards
Cherry Hu
Olive Coach Group Co., Ltd.
Tel: 021-6417 2614
     021-6417 2842
Fax: 021-6416 2842
Email: info@olivecoach.com
初次光临,请大家多关照, 我们的招聘是真诚的,否则不会想浪费我们自己的时间,并浪费大家的时间, 请有才能的人联系我们. 谢谢大家.
发表于 2007-1-27 09:22:43 | 显示全部楼层
真的假的,可惜要求太高,基本上没有符合要求的
已领礼包: 6809个
发表于 2007-1-27 16:00:51 | 显示全部楼层
这种层次水平就月薪10,000 RMB,建议阁下到西非去招聘!!
GMT+8, 2026-11-3 00:40 , Processed in 0.409929 second(s), 36 queries , Gzip On.
