查看: 1661|回复: 3
[求助]:怎么画螺旋线
发表于 2007-2-7 09:44:44 | 显示全部楼层 |阅读模式
3Dspiral.lsp 可畫2D和3D渦線
发表于 2007-2-7 09:48:29 | 显示全部楼层
2007中有画螺旋线的命令。
 楼主| 发表于 2007-2-8 13:58:56 | 显示全部楼层
我用的是2004版本。1楼的图片看不着。
发表于 2007-2-8 19:00:24 | 显示全部楼层
Sub Example_Add3DPoly()
Dim polyObj As Acad3DPolyline
Dim points() As Double
Dim a, n As Integer
Dim R1, R2, H As Double
Dim pa As Variant
Const PI = 3.1415926535
pa = ThisDrawing.Utility.GetPoint(, "请输入基点:")
R1 = ThisDrawing.Utility.GetDistance(pa, "请输入起点半径:")
R2 = ThisDrawing.Utility.GetDistance(pa, "请输入终点半径:")
H = ThisDrawing.Utility.GetDistance(pa, "请总高度:")
n = ThisDrawing.Utility.GetReal("请输入匝数:")
ReDim points(0 To 3 * 360 * n + 2) As Double
For a = 0 To 3 * 360 * n Step 3
points(a) = pa(0) + (R1 + (a / 3) * (R2 - R1) / 360 / n) _
* Cos(2 * PI * (a / 3) / 360)
points(a + 1) = pa(1) + (R1 + (a / 3) * (R2 - R1) / 360 / n) _
* Sin(2 * PI * (a / 3) / 360)
points(a + 2) = pa(2) + H * (a / 3) / 360 / n
Next
Set polyObj = ThisDrawing.ModelSpace.Add3DPoly(points)
ZoomExtents
End Sub
GMT+8, 2026-11-22 09:38 , Processed in 0.423133 second(s), 16 queries , Gzip On, File On.
