- UID
- 1
- 积分
- 16123
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-3
- 最后登录
- 1970-1-1
ActiveX/VBA Technical Newsletter - October 1999
This document is part of AutoCAD VB(A) Newsletter Archive
Dear AutoCAD ActiveX/VBA Developer,
/Note: the URL in this posting may be broken into several lines by the
transmission media. Please make sure that you have the full URL before
trying to access it./
Table of Contents
1. Introduction
2. COM Automation Presentation by Albert Szilvasy
3. Have you seen our enhanced Solution Searching capability?
4. An Example Solution
5. Some Interesting New Solutions
1. Introduction
We had two Developer Conferences since the last newsletter. One in
Europe and one in Asia/Pacific. The presentation material can be found
at the following URL:
http://adn.autodesk.com/techsupp/utilitiesconferences.htm
As an ActiveX/VBA developer you will be very interested in the
"COM Automation by Albert Szilvasy" presentation next to the
Asia/Pacific Developer Days 1999 at the following URL:
If you haven't used VBA/ActiveX yet then this presentation is a very
convincing demonstration as to why you should learn VBA/ActiveX.
In addition to the presentation there are a number of tools, utilities
and code samples to drive the point home. If you are an experienced
developer you will see just how pervasive this technology has become
over the past few years. The great news is you can leverage your existing
knowledge to create new kinds of applications. The latest versions of the
utilities and tools developed by the Developer Consulting Group are also
available in this download.
By the time you read this you should have received the ADN General Newsletter.
We have sent this newsletter to all our members because it contains new
information on how we have restructured our Solution Searching capability.
This is just too good to miss. For more details see the ADN General Newsletter.
For a sneak preview of how good this is, select the following URL:
/search/newsearch.htm
Have you visited our solutions before? If not here is an example of what one
of our many solutions looks like. This particular solution demonstrates the
following:
HOW TO EXTRACT AN XREF PATH FROM ITS BLOCK DEFINITION
/cgi-bin/solution.pl?SID=43016
Here is the text of the Solution 43016
Question:
How to obtain the path information of an Xref which is attached to a drawing
but has no references in ModelSpace/PaperSpace?
Answer
It is an unfortunate omission that the Xref path can not be obtained from the
AcadBlock object directly. This has been logged as a wishlist item. The
workaround is to create a temporary reference to the Xref to access the path
property.
Sub xrefpath()
Dim obj As Object
Dim pt(0 To 2) As Double
For Each obj In ThisDrawing.Blocks
If obj.IsXRef Then
'Obtain the ObjectID of the inserted block.
objid = ThisDrawing.ModelSpace.InsertBlock(pt, obj.Name, 1, 1, 1,
0).ObjectID
'With the help of the ObjectID get to the Object(External reference)
'so that you can extract the path information.
Set oRef = ThisDrawing.ObjectIdToObject(objid)
MsgBox oRef.Path
oRef.Delete
End If
Next obj
End Sub
FORMING A SELECTION SET OF ENTITIES ALONG WITH THEIR PICKED POINTS
/cgi-bin/solution.pl?SID=44354
ACCESSING LDATA VALUES FROM VBA
/cgi-bin/solution.pl?SID=44952
To subscribe or unsubscribe, go to
http://adn.autodesk.com/techsupp/docs/newsletters.htm
You received this message as a result of your registration
on the ADN List Server subscription page. If you no longer wish
to receive these messages, read the next section, How to use this
mailing list.
How to use this mailing list:
You may unsubscribe from this e-mail newsletter, or subscribe to
a variety of other informative e-mail newsletters, by returning
to the ADN List Server subscription page at
and changing your subscription preferences.
Alternatively, from the subscribed account you can send an e-mail to
<Majordomo-partnersys@autodesk.com> with the following command in the
body of your email message:
unsubscribe <list-name>
Autodesk Developer Network (ADN) information and events:
For information on all ADN topics, please visit:
http://www.autodesk.com/adn
THIS DOCUMENT IS PROVIDED FOR INFORMATIONAL PURPOSES ONLY. The
information contained in this document represents the current view of
Autodesk Inc. on the issues discussed as of the date of publication.
Because Autodesk must respond to change in market conditions, it
should not be interpreted to be a commitment on the part of Autodesk
and Autodesk cannot guarantee the accuracy of any information
presented after the date of publication.
INFORMATION PROVIDED IN THIS DOCUMENT IS PROVIDED 'AS IS' WITHOUT
WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE AND FREEDOM FROM INFRINGEMENT.
The user assumes the entire risk as to the accuracy and the use of
this document. This document may be copied and distributed subject to
the following conditions:
1. All text must be copied without modification and all pages must
be included
2. All copies must contain Autodesk's copyright notice and any other
notices provided therein
3. This document may not be distributed for profit
