查看: 5643|回复: 19
[原创]:cad2004绿色版增加vba
已领礼包: 208个
发表于 2007-7-2 20:00:56 | 显示全部楼层 |阅读模式
网络上流传的cad2004绿色版缺少vba
研究了一下原版的cad2004
增加了添加vba的批处理文件.自动寻找cad2004的安装目录.
批处理文件如下.
color 3
rem xshrimp 2007.7.2
rem reg query HKCU\Software\Autodesk\AutoCAD\R16.0\ACAD-201:804 /v RoamableRootFolder>1.txt
rem for /f "skip=4 tokens=2 delims=SZ" %%a in (1.txt) do @set cadpath=%%a
for /f "skip=4 tokens=2 delims=SZ" %%a in ('reg query HKCU\Software\Autodesk\AutoCAD\R16.0\ACAD-201:804 /v RoamableRootFolder') do @set cadpath=%%a
set oldpath=%CD%
cd /d %cadpath%
set cadpath=%CD%
cd /d %oldpath%
copy vb6chs.dll %windir%\system32
copy AcVba.arx      "%cadpath%" /y
copy AcVbaRes.dll "%cadpath%" /y
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA" /v "DESCRIPTION" /t REG_SZ /d "AcVBA Command Module"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA" /v "LOADCTRLS" /t REG_DWORD     /d 13    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA" /v "LOADER" /t REG_SZ /d "%cadpath%\AcVBA.arx"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "-VBALOAD" /t REG_SZ /d "-VBALOAD"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "-VBARUN" /t REG_SZ /d "-VBARUN"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBAIDE" /t REG_SZ /d "VBAIDE"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBALOAD" /t REG_SZ /d "VBALOAD"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBAMAN" /t REG_SZ /d "VBAMAN"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBANEW" /t REG_SZ /d "VBANEW"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBAPREF" /t REG_SZ /d "VBAPREF"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBARUN" /t REG_SZ /d "VBARUN"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBASTMT" /t REG_SZ /d "VBASTMT"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Commands" /v "VBAUNLOAD" /t REG_SZ /d "VBAUNLOAD"    /f
reg add "HKLM\SOFTWARE\Autodesk\AutoCAD\R16.0\ACAD-201:804\Applications\AcadVBA\Groups" /v "ACAD_VBA" /t REG_SZ /d "ACAD_VBA"    /f
其他下载地址.
http://groups.google.com/group/gpscad
解压缩后运行安装.bat文件即可.
[iframe h=400 w=600]http://groups.google.com/group/gpscad/files[/iframe]
发表于 2007-7-2 20:13:06 | 显示全部楼层
增加这个东西有什么功用没?
发表于 2007-7-2 21:32:42 | 显示全部楼层
cad2006有绿色版么?
已领礼包: 208个
 楼主| 发表于 2007-7-2 22:25:38 | 显示全部楼层
cad2006有绿色版的.
发表于 2007-7-2 23:47:57 | 显示全部楼层
好啊!这个问题困扰我好长时间了今个终有大虾解决.多谢了.
发表于 2007-7-3 20:53:15 | 显示全部楼层
vba干什么用,我是cad的老菜
发表于 2007-7-3 21:00:23 | 显示全部楼层
vba是vb语言的一个小分支。
发表于 2007-7-3 21:21:54 | 显示全部楼层
所提供的附件及连接都不能下载!
已领礼包: 208个
 楼主| 发表于 2007-7-4 09:53:55 | 显示全部楼层
google的要在ie窗口中再确定一下就可以下载了.
不行的话.
直接用ie打开网站
去下载
发表于 2007-7-4 10:47:47 | 显示全部楼层
老大还是重发,或放到网络硬盘里吧!论坛有点问题载不下来哇!
不行呀我装好cad还是显示要我用光盘重新安装vba支持
发表于 2008-11-9 18:00:07 | 显示全部楼层
zhenghao yaoyong
发表于 2008-11-9 18:26:16 | 显示全部楼层
好东西,谢谢搂住
发表于 2008-11-27 18:54:18 | 显示全部楼层
cad2006有绿色版的.
发表于 2008-12-10 22:18:08 | 显示全部楼层
谢谢,希望能解决问题!
发表于 2009-11-6 16:03:50 | 显示全部楼层
下不来啊,币不够,急
GMT+8, 2026-11-6 02:38 , Processed in 0.496810 second(s), 60 queries , Gzip On.
