查看: 1700|回复: 0
[PDF] Broadgun pdfMachine Ultimate 14.87 PDF文件创建工具
发表于 2016-4-8 08:45:57 | 显示全部楼层 |阅读模式
BroadGunPDFMachine是一个用来快速创建PDF文件格式的强力工具,支持对PDF文件的编辑功能!可以快速的创建体积小的PDF文件,支持对PDF文件进行128BIt加密功能。
Broadgun pdfMachine Ultimate是一款PDF文件生成工具,可以很轻松地创建高质量的PDF文件。有以下特点:易于安装;简单易用,只需点击一下鼠标
Broadgun pdfMachine Ultimate 14.x| 14.3 MB
Broadgun Software is committed to delivering superior pdf software products that can be customized to meet your specific requirements. pdfMachine is ** and fast, with no complicated options and is a native Windows print driver. If you know how to print from an application then you can use pdfMachine!
PDF enabled software is a vital component for every desktop. PDF or Portable Document Format is a widely used file format originally developed by Adobe. This format is rapidly becoming the defacto standard for publishing on the web.
Our pdf writer pdfMachine converts a print stream from an application directly into a PDF. Once you have installed the pdf writer, open your document that you want to convert, then click "print", select the "Broadgun pdfMachine printer" and that's it!
pdfMachine ultimate contains of the base functionality of 'pdfMachine pro' plus:
* 'Word Mail Merge' allows you to use Microsoft Word Mail Merge to send bulk emails with customised PDF attachments to each recipient.
* Parameter parsing - control the PDF generation pipeline from instructions embedded into the content of the document.
The Benefits of PDF:
Integrity:
PDF documents generated by pdfMachine, when printed or viewed, maintain the integrity of all formatting in the original document. PDF files preserve documents formats independent of software, hardware, or operating system used to generate the original file. They can be opened, read and printed by many free PDF readers available on the web, and viewed on operating systems such as Windows, MacOS, and Unix variants.
Technology:
PDF format is the best document format for long-term digital archival. Often software becomes obsolete, rendering some documents unreadable by current technology. Widely published formats, such as PDF, are more future proof that proprietary formats such as MS Word. In 50 years time, even if PDF's are not used anymore, all you need is the PDF specification and you can have a viewer developed to read your documents.
Searchable:
PDF has the ability to store text in a searchable form.
Browsers:
PDF files can be viewed within Netscape and Internet Explorer. These files can then be saved for off-line use or printed. This makes for easy use within an intranet or website.
Colour and Size:
PDF files enable sharp, colour-precise printing on most printers with precise onscreen colour match regardless of monitor brand. Users can magnify documents up to 800% without the loss of clarity in text or graphics. PDF files can be optimized and are often smaller than conventional document formats.
pdfMachine features:
* Print to create PDF
* PDF Editing
* Open any PDF
* Comment PDF
* Multilingual font support
* Mail Integration
* Small File Sizes
* PDF Stationery
* Textural watermarks
* Security Encryption
* Active URLs
* Hyperlinks
* N-Up Printing
* MS Office Integration
* MS IE Integration
* Network Installations
* Bookmark Editing
* Word Mail Merge
* Digital Signatures
* Parameter parsing
* Scanning Support
* Custom toolbar
* Terminal Server
* Set Next Action
* Set Document properties
* Multiple Print Profiles / Multiple Printers
* Windows XP/Vista x64 drivers
* File embedding/attaching
* PDF/A
Home page - http://www.pdfmachine.com/
Download 百度云
[/url]
GMT+8, 2026-11-22 08:00 , Processed in 0.319516 second(s), 11 queries , Gzip On, File On.
