查看: 1300|回复: 9
[VBA程序]:如何实现选择
发表于 2003-6-14 11:11:46 | 显示全部楼层 |阅读模式
如何用程序实现操作CAD图纸放大缩小,自动选择整个图纸
发表于 2003-6-14 14:50:53 | 显示全部楼层
  1.   [FONT=courier new]
  2. Sub SelAll()
  3.     On Error Resume Next
  4.     Dim mySel As AcadSelectionSet
  5.
  6.     ThisDrawing.SelectionSets("tempSel").Delete
  7.     Set mySel = ThisDrawing.SelectionSets.Add("tempSel")
  8.
  9.     mySel.Select acSelectionSetAll
  10.     mySel.Highlight True
  11.
  12.
  13. End Sub
  14. Sub Example_ZoomAll()
  15.     ' This example creates several objects in model space and
  16.     ' then performs a variety of zooms on the drawing.
  17.
  18.     ' Create a Ray object in model space
  19.     Dim rayObj As AcadRay
  20.     Dim basePoint(0 To 2) As Double
  21.     Dim SecondPoint(0 To 2) As Double
  22.     basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
  23.     SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
  24.     Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
  25.
  26.     ' Create a polyline object in model space
  27.     Dim plineObj As AcadLWPolyline
  28.     Dim points(0 To 5) As Double
  29.     points(0) = 3: points(1) = 7
  30.     points(2) = 9: points(3) = 2
  31.     points(4) = 3: points(5) = 5
  32.     Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
  33.     plineObj.Closed = True
  34.     ' Create a line object in model space
  35.     Dim lineObj As AcadLine
  36.     Dim startPoint(0 To 2) As Double
  37.     Dim endPoint(0 To 2) As Double
  38.     startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
  39.     endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
  40.     Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
  41.
  42.     ' Create a circle object in model space
  43.     Dim circObj As AcadCircle
  44.     Dim centerPt(0 To 2) As Double
  45.     Dim radius As Double
  46.     centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0
  47.     radius = 3
  48.     Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
  49.     ' Create an ellipse object in model space
  50.     Dim ellObj As AcadEllipse
  51.     Dim majAxis(0 To 2) As Double
  52.     Dim center(0 To 2) As Double
  53.     Dim radRatio As Double
  54.     center(0) = 5#: center(1) = 5#: center(2) = 0#
  55.     majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
  56.     radRatio = 0.3
  57.     Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
  58. ' ZoomAll
  59.     MsgBox "Perform a ZoomAll", , "ZoomWindow Example"
  60.     ZoomAll
  61.
  62. ' ZoomWindow
  63.     MsgBox "Perform a ZoomWindow using the following coordinates:" & vbCrLf & _
  64.            "1.3, 7.8, 0" & vbCrLf & _
  65.            "13.7, -2.6, 0", , "ZoomWindow Example"
  66.
  67.     Dim point1(0 To 2) As Double
  68.     Dim point2(0 To 2) As Double
  69.     point1(0) = 1.3: point1(1) = 7.8: point1(2) = 0
  70.     point2(0) = 13.7: point2(1) = -2.6: point2(2) = 0
  71.     ZoomWindow point1, point2
  72.
  73. ' ZoomScaled
  74.     MsgBox "Perform a ZoomScaled using:" & vbCrLf & _
  75.            "Scale Type: acZoomScaledRelative" & vbCrLf & _
  76.            "Scale Factor: 2", , "ZoomWindow Example"
  77.     Dim scalefactor As Double
  78.     Dim scaletype As Integer
  79.     scalefactor = 2
  80.     scaletype = acZoomScaledRelative
  81.     ZoomScaled scalefactor, scaletype
  82.
  83. ' ZoomExtents
  84.     MsgBox "Perform a ZoomExtents", , "ZoomWindow Example"
  85.     ZoomExtents
  86.
  87. ' ZoomPickWindow
  88.     MsgBox "Perform a ZoomPickWindow", , "ZoomWindow Example"
  89.     ZoomPickWindow
  90.
  91. ' ZoomCenter
  92.     MsgBox "Perform a ZoomCenter using:" & vbCrLf & _
  93.            "Center 3, 3, 0" & vbCrLf & _
  94.            "Magnification: 10", , "ZoomWindow Example"
  95.     Dim zcenter(0 To 2) As Double
  96.     Dim magnification As Double
  97.     zcenter(0) = 3: zcenter(1) = 3: zcenter(2) = 0
  98.     magnification = 10
  99.     ZoomCenter zcenter, magnification
  100.
  101. End Sub
  102.   [/FONT]
发表于 2003-6-14 15:29:26 | 显示全部楼层
Sub SelAll()
End Sub
请Laoyao网友仔细讲讲“Hightlight”属性!我的英文太差了。
发表于 2003-6-14 16:38:47 | 显示全部楼层
HELP原文。
Sets the highlight status for the given object, or for all objects in a given selection set。
设定所给OBJECT或SELECTIONSET中所有OBJECT为高亮模式(就是选中后的成为虚线状的样子:6 )。
例
    ActiveDocument.ModelSpace.Item(1).Highlight True
    ActiveDocument.SelectionSets(1).Highlight True
发表于 2003-6-14 18:53:02 | 显示全部楼层
最初由 Laoyao 发布
[B]HELP原文。
例... [/B]
谢谢!
这几行写的比我的方法(见那个水库的贴子)好,又学一招!
再次感谢Laoyao,向Laoyao学习!!!
已领礼包: 181个
发表于 2003-6-16 20:39:21 | 显示全部楼层
在程序中应该尽量少用On Error Resume Next,因为它有可能屏蔽之后产生的错误,使调试因难.
好的方法是先遍历整个选择集,如果选择集不存在,那么就创建一个.
当然如果这种方法繁杂的话,也可以单独编写一个过程或者函数来设置选择集.而在这段代码中加入错误处理机制,尽量避免将错误带到代码外的语句.
发表于 2003-6-19 15:51:44 | 显示全部楼层
经验之谈,可以解决很多没名的错误
发表于 2003-11-14 11:26:56 | 显示全部楼层
有时候ON ERROR不是很有用的,可以省不少源程序!
发表于 2003-11-20 20:15:48 | 显示全部楼层
不过如果VB中不用on error ,又是发生错误时就突然退出了,用了代码又大大增加了,每个sub都要加一段错误陷阱代码。
谁有什么好办法吗?能省点代码的。方便好用的。
发表于 2003-11-20 21:01:16 | 显示全部楼层
关于选择的操作,我转贴几个例程:(转自明经通道 )
  2. ' 不断提示选择一个对象直到获取了对象或用户取消操作
  3. Public Sub GetEntityEx(ent As Object, pickedPoint, Optional Prompt)
  4.     On Error Resume Next
  5. StartLoop:
  6.     acadApp.ActiveDocument.Utility.GetEntity ent, pt, Prompt
  7.     If Err Then
  8.         If acadApp.ActiveDocument.GetVariable("errno") = 7 Then
  9.             Err.Clear
  10.             GoTo StartLoop
  11.         Else
  12.             Err.Raise vbObjectError + 5, , "用户取消操作"
  13.         End If
  14.     End If
  15. End Sub
  16. ' 返回一个空白选择集
  17. ' 它也可消除烦人的“选择集已经存在”问题
  18. Public Function CreateSelectionSet(Optional ssName As String = "ss") As AcadSelectionSet
  19.     Dim ss As AcadSelectionSet
  20.
  21.     On Error Resume Next
  22.     Set ss = ThisDrawing.SelectionSets(ssName)
  23.     If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
  24.     ss.Clear
  25.     Set CreateSelectionSet = ss
  26. End Function
  27. ' 对象选择,可实现先选择后操作和先操作后选择
  28. ' 作者:郑立楷
  29. Function GetSelSet() As AcadSelectionSet
  30.     Dim ss As AcadSelectionSet
  31.     Dim ssName As String
  32.     ssName = "PICKFIRST"
  33.     On Error Resume Next
  34.     Set ss = ThisDrawing.SelectionSets.Add(ssName)
  35.     If Err Then
  36.         Set ss = ThisDrawing.SelectionSets(ssName)
  37.         ss.Delete
  38.     End If
  39.     Set ss = ThisDrawing.PickfirstSelectionSet
  40.     If ss.Count = 0 Then
  41.         Set ss = ThisDrawing.SelectionSets(ssName)
  42.         If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
  43.         ss.Clear
  44.         ss.SelectOnScreen
  45.     End If
  46.     Set GetSelSet = ss
  47. End Function
  48. [/FONT]
GMT+8, 2026-11-3 06:20 , Processed in 0.508185 second(s), 50 queries , Gzip On.
