查看: 1487|回复: 2
[公告]:AutoCAD 2008 Service Pack 1 Beta 出来了!
发表于 2007-7-24 23:29:09 | 显示全部楼层 |阅读模式
刚收到一封信,是AutoDesk的,说AutoCAD 2008 Beta1 出来了,要求测试。
倒,也太快了吧!
以下是信件内容
Dear ACAD Futures Member,
We have now released for testing the AutoCAD 2008 and AutoCAD LT 2008 Service Pack 1. This Service Pack was created as a direct result of detailed information from customers who used the Customer Error Reporting Utility or who reported issues to Autodesk support or MyFeedback. Please continue to provide feedback and send the CER reports.
Service Pack 1 beta is for the following Autodesk products running on all supported operating systems and languages.
32-bit Product Service Pack
AutoCAD 2008
AutoCAD LT 2008
AutoCAD Revit® Architecture Suite 2008 1
AutoCAD Revit® Structure Suite 2008 1
64-bit Product Service Pack
AutoCAD 2008
AutoCAD Revit Architecture Suite 2008 1
AutoCAD Revit Structure Suite 2008 1
1 Apply the patch only if the installation contains AutoCAD 2008
发表于 2007-7-25 07:12:26 | 显示全部楼层
开香槟,庆祝一下!希望早日能见到SP1的下载,最好是不要重新注册,现在中国啥子涨价,就工资不涨。老美应该体谅一下中国的打工仔!
发表于 2007-7-27 11:46:03 | 显示全部楼层
嗯,不要重新注册就好。
GMT+8, 2026-11-22 09:39 , Processed in 0.298219 second(s), 14 queries , Gzip On, File On.
