查看: 739|回复: 1
[VBA函数]:如何在ucs中用vba画直线?
发表于 2003-6-14 16:51:58 | 显示全部楼层 |阅读模式
我画的直线都是在wcs中
怎么才能在我定义的某个ucs中画呢?
发表于 2003-6-16 08:58:12 | 显示全部楼层
Re: [VBA函数]:如何在ucs中用vba画直线?
最初由 ibluesky 发布
[B]我画的直线都是在wcs中
怎么才能在我定义的某个ucs中画呢? [/B]
这是坐标转换的帮助信息
  1.   [FONT=courier new]
  2. RetVal = object.TranslateCoordinates(OriginalPoint, From, To, Disp[, OCSNormal])
  3. Object
  4. Utility
  5. The object or objects this method applies to.
  6. OriginalPoint
  7. Variant (three-element array of doubles); input-only
  8. The 3D WCS coordinates specifying the original coordinates to be translated. This parameter can be treated as a point or a displacement vector depending on the value of Disp.
  9. From
  10. AcCoordinateSystem enum; input-only
  11. The coordinate system from which the point originates.
  12. acWorld
  13. acUCS
  14. acOCS
  15. acDisplayDCS
  16. acPaperSpaceDCS
  17. To
  18. AcCoordinateSystem enum; input-only
  19. The coordinate system to which the point will be converted.
  20. acWorld
  21. acUCS
  22. acOCS
  23. acDisplayDCS
  24. acPaperSpaceDCS
  25. Disp
  26. Integer; input-only
  27. A displacement vector flag.
  28. TRUE: OriginalPoint is treated as a displacement vector.
  29. FALSE: OriginalPoint is treated as a point.
  30. OCSNormal
  31. Variant (three-element array of doubles); input-only;optional
  32. The normal for the OCS.
  33. RetVal
  34. Variant (three-element array of doubles)
  35. The translated 3D coordinate.
  36. Remarks
  37. You cannot directly translate a coordinate from one OCS to another OCS. To do this, first translate the coordinate from one OCS to an intermediary coordinate system such as the WCS. Then translate that coordinate into the second OCS.
  38. To translate a point on a Polyline or LightWeightPolyline object from OCS to WCS:
  39. 1. Get the X and Y coordinates of the OCS point from the Coordinate or Coordinates property.
  40. 2. Get the Z coordinate of the OCS point from the Elevation property.
  41. 3. Get the normal for the polyline from the Normal property.
  42. 4. Call TranslateCoordinates using the X, Y, Z coordinates and the Normal.
  43.   [/FONT]
GMT+8, 2026-11-22 10:36 , Processed in 0.355844 second(s), 12 queries , Gzip On, File On.
