查看: 1357|回复: 0
[教学]:从Autolisp到vlisp的转换
发表于 2002-5-25 09:58:45 | 显示全部楼层 |阅读模式
许多人以为activex方式很麻烦。
很简单。
看下面的代码,从现在开始,可以告别entget,不用记dxf组码了。
  1. [FONT=courier new]
  2. (defun point->list (point)
  3.   (vlax-safearray->list (vlax-variant-value point))
  4. )
  5. (defun c:test()
  6.   (setq line (car (entsel)))
  7.   (setq line (vlax-ename->vla-object line))
  8.   (setq objectname (vla-get-objectname line))
  9.   (setq startpoint (vla-get-startpoint line))
  10.   (setq endpoint (vla-get-endpoint line))
  11.   (setq layername (vla-get-layer line))
  12.   (setq len (vla-get-length line))
  13.   (setq thickness (vla-get-thickness line))
  14.   (princ "\nObject Name: ")(princ objectname)
  15.   (princ "\nStart Point: ")(princ (point->list startpoint))
  16.   (princ "\nEnd Point:   ")(princ (point->list endpoint))
  17.   (princ "\nLayer:       ")(princ layername)
  18.   (princ "\nLine Length: ")(princ len)
  19.   (princ "\nThickness:   ")(princ thickness)
  20.   (princ)
  21. )
  22. [/FONT]
GMT+8, 2026-11-3 12:28 , Processed in 0.427846 second(s), 30 queries , Gzip On.
