查看: 1770|回复: 3
[编程申请]:麻烦大家帮我看看这个程序
已领礼包: 838个
发表于 2007-10-7 22:29:44 | 显示全部楼层 |阅读模式
麻烦大家帮我看看这个程序
(defun c:75 (/)
(setvar "cmdecho" 1)
(setq a1 (getpoint "\n第一点")
a2 (getpoint "\n第二点")
ang (* (/ (angle a1 a2) pi) 180)
dist (rtos (/ (distance a1 a2) 1) 2 0)
dist1 (strcat "de75"  ","dist "m" )
a3 (getpoint "文字插入点")
(command "text" a3 "7" ang dist1)
(while (not (SETQ ss (ssget (LIST (cons 0 "text"))))))
  (setq        n  -1
        s1 (ssname ss 0)
(princ (xyp-get-DXF 41 s1))
  (setq th (UREAL 1 "" "新宽度因子为" 0.75))
  (while (setq s1 (ssname ss (setq n (1+ n))))
    (princ ".")
    (xyp-SubUpd s1 41 th)
(princ)
需要定义字体的宽度,不过,上面这个勉强可以用,不好用,每次都要选择
还有文字的位置能否直接放在所选择的两个点的中间,文字采用中对齐,文字距离直线需留出来一定距离
如果可以直接选择线段直接标注需要的东西应该怎么做啊
以上程序是根据大家的程序拼出来的,希望不会冒犯各位高手
发表于 2007-10-7 22:56:43 | 显示全部楼层
  1. (vl-load-com)
  2. (defun c:75 (/ p1 p2 midp txt ms)
  3.   (setvar "cmdecho" 1)
  4.   (setq        ms (vla-get-modelspace
  5.              (vla-get-activedocument (vlax-get-acad-object))
  6.            )
  7.   )
  8.   (while (and (setq p1 (getpoint "\n第一点"))
  9.               (setq p2 (getpoint p1 "\n第二点"))
  10.          )
  11.     (setq midp (vlax-3d-point
  12.                  (mapcar '(lambda (x y) (* (+ x y) 0.5)) p1 p2)
  13.                )
  14.           txt  (vla-addtext
  15.                  ms
  16.                  (strcat "de75"
  17.                          ","
  18.                          (rtos (distance p1 p2) 2 0)
  19.                          "m"
  20.                  )
  21.                  midp
  22.                  7.
  23.                )
  24.     )
  25.     (vla-put-alignment txt acAlignmentBottomCenter)
  26.     (vla-put-TextAlignmentPoint txt midp)
  27.     (vla-put-scalefactor txt 0.75)
  28.     (vla-put-rotation txt (angle p1 p2))
  29.   )
  30.   (vlax-release-object ms)
  31.   (princ)
  32. )
已领礼包: 838个
 楼主| 发表于 2007-10-8 14:44:31 | 显示全部楼层
谢谢,很好用,那能不能写一个选择线段直接标注的,就是不用选择两点了,不知能否批量处理,就是选择所有线段全部标注上文字,我有大量的这样的工作,恳请高手帮忙
发表于 2013-9-3 16:52:17 | 显示全部楼层
谢谢楼主分享,支持源码!
GMT+8, 2026-11-3 18:32 , Processed in 0.443447 second(s), 38 queries , Gzip On.
