查看: 1696|回复: 4
[求助] [求助]:怎样删掉列表中的值?
发表于 2007-10-11 08:58:59 | 显示全部楼层 |阅读模式
求教,假设有一个列表‘(“A” “B" "C" "D")
有没有办法删掉其中一个,把它变成'(“A” “C” “D”)呢?
发表于 2007-10-11 14:34:26 | 显示全部楼层
(vl-remove "B" '("A" "B" "C" "D"))
 楼主| 发表于 2007-11-4 11:28:29 | 显示全部楼层
好用呢,谢谢
发表于 2007-11-8 18:37:12 | 显示全部楼层
这样作有一个弊端,若表中有两个相同的直,都会被删除掉
(vl-remove "B" '("A" "B" "C" "B" "D"))
返回("A" "C" "D")
发表于 2007-11-8 21:09:59 | 显示全部楼层
  1.   [FONT=courier new]
  2. (defun txt1-delnth (idx lst / nlst cnt elem)
  3.   (setq nlst '()
  4.         cnt 0
  5.   )
  6.   (foreach elem lst
  7.     (if (/= cnt idx)
  8.       (setq nlst (cons elem nlst))
  9.     )
  10.     (setq cnt (1+ cnt))
  11.   )
  12.   (reverse nlst)
  13. )
  14.   [/FONT]
GMT+8, 2026-11-22 08:21 , Processed in 0.330483 second(s), 16 queries , Gzip On, File On.
