查看: 1092|回复: 2
[VBA程序]:暴力破解Word密码
发表于 2003-6-17 17:02:36 | 显示全部楼层 |阅读模式
以下为程序内容
Private Sub cmdopendoc_Click()
  Dim wd As New Word.Application
  Dim strpath As String
  Dim pass As String
  Dim J, K, Pass_long As Integer
  Dim Max_num, Min_num, I As Long
  strpath = File1.Path & "\" & File1.FileName
  On Error Resume Next
  '程序开始
  Pass_long = Val(Text2.Text)
  Max_num = 10 ^ Val(Text2.Text)
  Min_num = 10 ^ (Val(Text2.Text) - 1)
  Flag = 0
  For K = 0 To Pass_long - 1
    Max_num = 10 ^ (Pass_long - K)
    Min_num = 10 ^ (Pass_long - (K + 1))
    For J = 0 To Pass_long - 1
      cmdopendoc.MousePointer = 11
      For I = IIf(Pass_long - K = 1, 0, Min_num) + J To Max_num Step Pass_long
        Text1.Text = pass
        Text1.Refresh
        pass = String(K, "0") & I
        Flag = wd.Documents.Open(FileName:=strpath, passworddocument:=pass)
        '如果解密成功,打开文档,显示密码,退出过程
        If Flag <> 0 Then
          Label1.Caption = "文档密码"
          Label1.Refresh
          Text1.Text = pass
          wd.Visible = True
          cmdopendoc.MousePointer = 0
          Exit Sub
        End If
      Next I
    Next J
  Next K
  MsgBox "密码位数不对,请重新输入"
End Sub
Private Sub cmdquit_Click()
  End
End Sub
Private Sub Dir1_Change()
  File1.Path = Dir1.Path
End Sub
Private Sub Drive1_Change()
  Dir1.Path = Drive1.Drive
End Sub
Private Sub File1_DblClick()
  Call cmdopendoc_Click
End Sub
发表于 2003-6-21 22:02:06 | 显示全部楼层
是不是真的有用?居然将WORD的密码也解了!
发表于 2003-6-28 21:33:20 | 显示全部楼层
真的可以吗,我试试。
GMT+8, 2026-11-22 10:36 , Processed in 0.509946 second(s), 14 queries , Gzip On, File On.
