查看: 1725|回复: 4
[LISP程序]:多义线的顶点坐标
发表于 2008-1-3 13:25:50 | 显示全部楼层 |阅读模式
矩形有四个顶点,我想依次取出!定义为p1,p2,p3,p4
(setq p (getpoint "选取点位置:")
(command "boudary"  p "")
(setq ent1 (entget (entlast)))
取出p1,p2,p3,p4
然后(entdel (entlast))
发表于 2008-1-3 13:40:26 | 显示全部楼层
返回多段线第n点的坐标
[PHP](defun dc-getpoint (ename n)
  (setq obj (vlax-ename->vla-object ename))
  (setq        plist (vlax-safearray->list
                (vlax-variant-value
                  (vla-get-coordinates obj)
  (list (nth (* n 2) plist) (nth (1+ (* n 2)) plist))
)[/PHP]
发表于 2008-1-4 12:48:29 | 显示全部楼层
  1.   [FONT=courier new]
  2. (defun th-get-allvertexs (ename / n ptlist)
  3.   (foreach n (entget ename)
  4.     (if (= 10 (car n))
  5.       (setq ptlist (cons (cdr n) ptlist))
  6.     )
  7.   )
  8.   (reverse ptlist)
  9. )
  10.   [/FONT]
发表于 2008-1-4 21:02:17 | 显示全部楼层
[php]
;;;取得pline所有等顶点
(vl-remove-if-not
'(lambda(x) (if (= 10 (car x) )(list x)))
  (entget (car (entsel)))
[/php]
发表于 2008-1-6 05:15:45 | 显示全部楼层
直接使用内部函数:
(acet-geom-vertex-list poly)
GMT+8, 2026-11-22 11:26 , Processed in 0.429748 second(s), 18 queries , Gzip On, File On.
