查看: 1813|回复: 7
[求助] [求助]:我的DCL就是不能取值!!!
发表于 2008-2-3 11:05:44 | 显示全部楼层 |阅读模式
什么也看不到!
 楼主| 发表于 2008-2-3 21:03:51 | 显示全部楼层
不好意思没有弄明白,发帖的按钮用法
  1.   [FONT=courier new]
  2. ( defun c:WL()
  3.    (setq weldDialog (load_dialog "I:\\寒假作业\\DCL\\weld"))
  4.    (new_dialog "weld" weldDialog)
  5.    (action_tile "pipeNo" "(setq pipe (get_tile "pipeNo"))")
  6.
  7.    (start_dialog)
  8.    (princ pipe)
  9.
  10. )
  11.   [/FONT]
  2. weld:dialog {
  3.     label = "焊口标记程序" ;
  4.     :boxed_column {
  5.         label = "管线参数" ;
  6.         :edit_box {
  7.             key = "pipeNo" ;
  8.             label = "管线号" ;
  9.         }
  10.         ok_cancel;
  11.         :row {
  12.             :edit_box {
  13.                 alignment = left ;
  14.                 edit_width = 8 ;
  15.                 key = "pipeOutsideDiameter" ;
  16.                 label = "管道外径" ;
  17.             }
  18.             :edit_box {
  19.                 alignment = right ;
  20.                 edit_width = 4 ;
  21.                 fixed_height = true ;
  22.                 key = "pipeWallThickness" ;
  23.                 label = "壁厚" ;
  24.             }
  25.         }
  26.         :radio_row {
  27.             :edit_box {
  28.                 alignment = left ;
  29.                 edit_width = 8 ;
  30.                 key = "welderNo" ;
  31.                 label = "焊工号           " ;
  32.             }
  33.             :edit_box {
  34.                 alignment = right ;
  35.                 edit_width = 4 ;
  36.                 key = "radiographicProportion" ;
  37.                 label = "探伤比例" ;
  38.             }
  39.         }
  40.     }
  41.     :boxed_column {
  42.         label = "标记设定" ;
  43.         :row {
  44.             alignment = left ;
  45.             :edit_box {
  46.                 alignment = left ;
  47.                 edit_width = 8 ;
  48.                 key = "beginNo" ;
  49.                 label = "起始序号" ;
  50.             }
  51.             :radio_button {
  52.                 alignment = left ;
  53.                 key = "marker" ;
  54.                 label = "标记符号" ;
  55.                 width = 8 ;
  56.             }
  57.         }
  58.         :row {
  59.             alignment = left ;
  60.             :popup_list {
  61.                 edit_width = 7 ;
  62.                 key = "font" ;
  63.                 label = "字体            " ;
  64.                 list = "宋体\n仿宋\n楷体\n魏体" ;
  65.             }
  66.             :edit_box {
  67.                 edit_limit = 8 ;
  68.                 key = "Height" ;
  69.                 label = "字号" ;
  70.             }
  71.         }
  72.         :row {
  73.             alignment = left ;
  74.             :edit_box {
  75.                 edit_width = 8 ;
  76.                 key = "markerSize" ;
  77.                 label = "标记大小" ;
  78.             }
  79.             :radio_button {
  80.                 key = "proportion" ;
  81.                 label = "锁定比例" ;
  82.             }
  83.         }
  84.     }
  85.     :boxed_column {
  86.         label = "修改管线" ;
  87.         :popup_list {
  88.             key = "completePipeNo" ;
  89.         }
  90.         :button {
  91.             key = "currently" ;
  92.             label = "管线数据置当前" ;
  93.         }
  94.     }
  95. }
  96.   [/FONT]
已领礼包: 12496个
发表于 2008-2-4 12:22:01 | 显示全部楼层
改成:
(action_tile "pipeNo" "(setq pipe (get_tile \"pipeNo\"))")
发表于 2008-2-4 17:56:10 | 显示全部楼层
学习一下。。。
 楼主| 发表于 2008-2-4 23:29:28 | 显示全部楼层
为什么会使这样呢!!!高手能不能解释一下原因呢
发表于 2008-2-5 21:17:07 | 显示全部楼层
\起转义作用,没有的话,lisp被认成字串+变量+字串,不是你所希望的
 楼主| 发表于 2008-2-6 00:33:26 | 显示全部楼层
还有个问题,在DCL界面打开的情况下,能不能实现数据的实时更新,比如说,我点按钮,按钮所执行的程序是在文本框输入数据!!!
已领礼包: 12496个
发表于 2008-2-6 11:10:58 | 显示全部楼层
当然可以。不过是打开另一个对话框。具体要看你的详细要求,最好给个程序框架。
GMT+8, 2026-11-7 09:46 , Processed in 1.156058 second(s), 46 queries , Gzip On.
