查看: 1449|回复: 9
[编程申请]:保存文件为今天时间
已领礼包: 8个
发表于 2008-2-21 17:11:51 | 显示全部楼层 |阅读模式
文件保存时,文件名加上电脑系统时间,
如【2008-02-21】****.dwg,
如果是下次打开次文件,结束保存时,能自动修改文件的时间。
如【2008-02-05】****.dwg
已领礼包: 208个
发表于 2008-2-21 22:33:22 | 显示全部楼层
[php]
;;保存时按时间更改名字保存
(defun c:ss ( / date dwgtitled hz newname oldname path);!!!时间名保存
  (setq DWGTITLED (getvar "DWGTITLED")) ;指出当前图形是否已命名
  (if (= DWGTITLED 0)
    (ALERT "请先保存文件")
    (progn
      (setq path (getvar "DWGPREFIX")
            oldname (vl-filename-base (getvar "DWGNAME"))
          (setq date (menucmd "M=$(edtime,$(getvar,date),YY-MO-DD)"))
          (vl-mkdir (strcat path "bak"))
         (if (wcmatch oldname "*`[##-##-##`]#")
         (if (wcmatch oldname (strcat "*`[" date "`]#") );判断是不是当前日期.
           (progn
              (setq hz (substr oldname (strlen oldname) 1));后缀
              (if (/= "9" hz)
              (progn
              (setq newname (vl-string-right-trim hz oldname))
              (setq hz (itoa (+ (atoi hz) 1)));后缀增1
              (setq newname (strcat newname hz))
              (command "_.saveas" "" (strcat path newname ))
              (vl-file-copy   (strcat path oldname ".dwg")
(strcat path "bak\\\\" oldname ".dwg") nil)
              (vl-file-delete (strcat path oldname ".dwg"))
              (vl-file-delete (strcat path oldname ".dwl"))
              (vl-file-delete (strcat path newname ".dwl"))
             );end progn
             (command "_.qsave")
           (progn
             (setq newname (substr oldname 1 (- (strlen oldname) 11)));前缀
             ;(setq newname (strcat path newname "[" date "]1" ))
             (command "_.saveas" "" (strcat path newname "[" date "]1" ))
             (vl-file-delete (strcat path newname "[" date "]1" ".dwl"))
             (vl-file-copy   (strcat path oldname ".dwg") (strcat path "bak\\" oldname ".dwg") nil)
           );end if
            (progn
             (command "_.saveas" "" (strcat path oldname "[" date "]1" ))
             (vl-file-delete (strcat path oldname "[" date "]1" ".dwl"))
  (princ)
[/php]
发表于 2008-2-25 09:02:40 | 显示全部楼层
这也有一个
提供了带注释的源码
有兴趣的可以看看
好象原来程序的框架也是源于xshrimp
http://www.tstmr.com/tmr/dispbbs ... ;ID=1074&page=5
发表于 2008-2-25 20:38:10 | 显示全部楼层
错误: 输入中的点位置不正确
发表于 2008-2-26 12:01:14 | 显示全部楼层
改一下路径就行了
发表于 2008-2-26 20:05:18 | 显示全部楼层
改生么路径?
发表于 2008-3-5 11:24:54 | 显示全部楼层
依然是“错误: 输入中的点位置不正确”
不晓得是咋个回事,敢问5楼的具体镇江?
已领礼包: 208个
发表于 2008-3-5 19:55:19 | 显示全部楼层
修改了.这个是论坛php代码的bug!
发表于 2008-3-15 19:49:27 | 显示全部楼层
2楼的怎么显示“未知命令”
发表于 2008-4-13 11:47:00 | 显示全部楼层
2楼的怎么显示“未知................”
GMT+8, 2026-10-19 00:00 , Processed in 0.580030 second(s), 50 queries , Gzip On.
