查看: 2078|回复: 5
[求助]:cad2006在sp2下无法安装
发表于 2008-3-28 17:27:14 | 显示全部楼层 |阅读模式
[3/28/2008 13:34:03] === Installation started on 416-72 by zhlin ===
[3/28/2008 13:34:04] [Info] Windows Installer upgrade is not required
[3/28/2008 13:34:04]   System Version = 3.1.4000.4039
[3/28/2008 13:34:04] Installation skipped: MSI Runtime 3.0
[3/28/2008 13:34:04] [Info] .NET Framework Runtime upgrade is not required
[3/28/2008 13:34:04]   System Version = 2.0.50727.42
[3/28/2008 13:34:04] Installation skipped: .NET Framework Runtime 1.1
[3/28/2008 13:34:04] Installation started: .NET Framework Runtime 1.1 Language Pack
[3/28/2008 13:34:04]   Command = "support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[3/28/2008 13:34:07] Installation succeeded: .NET Framework Runtime 1.1 Language Pack
[3/28/2008 13:34:07] [Info] .NET Framework Runtime upgrade is not required
[3/28/2008 13:34:07]   System Version = 2.0.50727.42
[3/28/2008 13:34:07] Installation skipped: .NET Framework Runtime 1.1 SP1
[3/28/2008 13:34:07] [Info] MDAC upgrade is not required
[3/28/2008 13:34:07]   System Version = 2.81.1117.0
[3/28/2008 13:34:07] Installation skipped: MDAC 2.7
[3/28/2008 13:34:07] Installation started: Autodesk DWF Viewer
[3/28/2008 13:34:07]   Command = "support\aev\DWFViewerSetup.exe" /u2 /q2
[3/28/2008 13:34:08] [Error: 11] 试图加载格式不正确的程序。
[3/28/2008 13:34:08] Installation failed: Autodesk DWF Viewer
[3/28/2008 13:34:08] [Info] Failure is ignored
[3/28/2008 13:34:08] Installation started: Flash
[3/28/2008 13:34:08]   Command = "support\flash\Silent Install Flash Player 7 AX.exe" /q
[3/28/2008 13:34:11] [Error: 1] 函数不正确。
[3/28/2008 13:34:11] Installation failed: Flash
[3/28/2008 13:34:11] [Info] Failure is ignored
[3/28/2008 13:34:11] Installation started: AutoCAD 2006
[3/28/2008 13:34:11]   Command = msiexec /i "acad.msi" /L*v C:\DOCUME~1\zhlin\LOCALS~1\Temp\AcadInstall.log
[3/28/2008 13:36:04] [Error: 1603] 安装时发生严重错误
[3/28/2008 13:36:04] Installation failed: AutoCAD 2006
[3/28/2008 13:36:04] Installation aborted
[3/28/2008 13:44:52] === Installation ended ===
发表于 2008-3-28 21:22:09 | 显示全部楼层
应该是你的安装文件损坏了吧,我这里安装得很好。
 楼主| 发表于 2008-3-29 10:11:22 | 显示全部楼层
应该不是,以前安装过。你帮不了我。
发表于 2008-3-30 13:08:16 | 显示全部楼层
看一下这个Log文件的内容。
发表于 2008-3-30 13:47:05 | 显示全部楼层
好像是NET Framework Runtime的问题,单独安装一个新版本……
发表于 2008-3-30 19:21:29 | 显示全部楼层
我的CAD2006在XP SP2下装得好好的,可能是系统精简了的问题
GMT+8, 2026-11-22 07:52 , Processed in 0.273201 second(s), 20 queries , Gzip On, File On.
