- UID
- 1
- 积分
- 16123
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-3
- 最后登录
- 1970-1-1
AutoCAD Visual LISP Technical Newsletter - March 2000
This document is part of Visual Lisp Newsletter Archive
/Note: Have you missed a Newsletter issue? Visit our Newsletter archive at
the following URL:/
http://adn.autodesk.com/techsupp/docs/newsletters.htm
Dear Visual LISP developer,
Table of Contents
(1) VL *ERROR* HANDLER THAT PREVENTS FUNCTION CANCELLATION
(2) ARX FUNCTION EXPOSURE WITHIN A SEPARATE NAMESPACE VLX
(3) USING LISP TO READ AN ACCESS DATABASE VIA ADO
(4) CASCADING PULLDOWN SUBMENU TERMINATOR IS NOT WRITTEN TO MNS FILE
(5) New or updated solutions
With the advent of the Multiple Document Environment, and the resultant
Multiple Document Namespaces, Visual LISP introduced the
Separate-NameSpace VLX.
That's compiled lisp code which runs outside the current document
namespace, and in it's own code name-space.
This new feature adds more power, and different coding requirements
beyond those necessary for lisp routines that run in a drawing.
In addition to the essential documentation here in the:
Visual Lisp Developer's Guide -> Chapter 4 -- Building Applications ->
Designing for a Multiple Document Environment ->
Running an Application in Its Own Namespace,
and here:
Visual Lisp Developer's Guide -> Appendix A
-- AutoLISP Function Synopsis -> VLX Namespace Functions
We have created a few solutions which demonstrate using SNS VLX's.
(1) 19037 - VL *ERROR* HANDLER THAT PREVENTS FUNCTION CANCELLATION
Ever want lisp to handle an error, yet still keep processing code instead
of dying ?
Here's a solution that provides example code using a SNS
(Separate NameSpace) VLX to do just that:
/cgi-bin/solution.pl?SID=19037
(2) 47496 - ARX FUNCTION EXPOSURE WITHIN A SEPARATE NAMESPACE VLX
In a SNS (Separate NameSpace) VLX the (vl-arx-import) function is required,
to expose ARX function(s) to your VLX code. See this solution for more
information:
/cgi-bin/solution.pl?SID=47496
Looking for a way to use Microsoft's ADO COM database technology with
Visual Lisp ? Here's some example code that demonstrates this:
/cgi-bin/solution.pl?SID=48677
(4) 45782 - CASCADING PULLDOWN SUBMENU TERMINATOR IS NOT WRITTEN TO MNS FILE
Wishing to create an on-the-fly pulldown menu, using the new ActiveX Menu
API's? It's not hard, but creating a complex pulldown menu via code does
seem a bit daunting when you first try it. This solution demonstrates how
to put all the pulldown menu parts together, and provides a critical
demonstration of the EndSubMenuLevel Property for cascading pulldown menus.
/cgi-bin/solution.pl?SID=45782
ACCUST: USING ENTMAKE TO CREATE LWPOLYLINES
/cgi-bin/solution.pl?SID=37860
HOW TO DEFINE LISP CODE FOR AN UNDO OF A MENU SELECTION
/cgi-bin/solution.pl?SID=44795
(COMMAND "_REGEN") LEAVES AN UNDO GROUP ACTIVE
/cgi-bin/solution.pl?SID=44937
HOW TO DELETE A DATABASE LINK WITH VISUAL LISP
/cgi-bin/solution.pl?SID=45169
NO DIALOG DISPLAYS WHEN I RUN A COMMAND VIA LISP OR A SCRIPT
/cgi-bin/solution.pl?SID=45187
ENTMOD OF OLD STYLE HATCHING CAUSES AUTOCAD TO CRASH
/cgi-bin/solution.pl?SID=45644
HOW TO SPECIFY A UNC PATH NAME IN LISP
/cgi-bin/solution.pl?SID=45762
RTOS DOES NOT RETURN DECIMALS AS SPECIFIED
/cgi-bin/solution.pl?SID=45865
DOES LISP CONSIDER '/' AS DIVIDE OPERATOR IN DISTOF FUNCTION?
/cgi-bin/solution.pl?SID=47637
USING LISP TO FIND OUT THE VERSION OF A DWG?
/cgi-bin/solution.pl?SID=48199
HOW CAN I USE LAYOUTLIST FUNCTION IN A SEPARATE NAMESPACE VLX?
/cgi-bin/solution.pl?SID=48898
HOW TO SET A POLYLINE'S WIDTH USING ACTIVEX?
/cgi-bin/solution.pl?SID=49217
To subscribe or unsubscribe, go to
You received this message as a result of your registration
on the ADN List Server subscription page. If you no longer wish
to receive these messages, read the next section, How to use this
mailing list.
How to use this mailing list:
You may unsubscribe from this e-mail newsletter, or subscribe to
a variety of other informative e-mail newsletters, by returning
to the ADN List Server subscription page at
and changing your subscription preferences.
Alternatively, from the subscribed account you can send an e-mail to
<Majordomo-partnersys@autodesk.com> with the following command in the
body of your email message:
unsubscribe <list-name>
Autodesk Developer Network (ADN) information and events:
For information on all ADN topics, please visit:
http://www.autodesk.com/adn
THIS DOCUMENT IS PROVIDED FOR INFORMATIONAL PURPOSES ONLY. The
information contained in this document represents the current view of
Autodesk Inc. on the issues discussed as of the date of publication.
Because Autodesk must respond to change in market conditions, it
should not be interpreted to be a commitment on the part of Autodesk
and Autodesk cannot guarantee the accuracy of any information
presented after the date of publication.
INFORMATION PROVIDED IN THIS DOCUMENT IS PROVIDED 'AS IS' WITHOUT
WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE AND FREEDOM FROM INFRINGEMENT.
The user assumes the entire risk as to the accuracy and the use of
this document. This document may be copied and distributed subject to
the following conditions:
1. All text must be copied without modification and all pages must
be included
2. All copies must contain Autodesk's copyright notice and any other
notices provided therein
3. This document may not be distributed for profit |
