查看: 1352|回复: 7
[下载]:AutoCAD文本上下标
发表于 2008-4-24 08:20:47 | 显示全部楼层 |阅读模式
AutoCAD文本上下标.rar
发表于 2008-4-27 03:36:30 | 显示全部楼层
不错,可我没币
发表于 2008-5-7 14:14:56 | 显示全部楼层
3Q
发表于 2008-5-19 15:26:30 | 显示全部楼层
也来凑热闹,学习学习
发表于 2008-5-25 21:17:43 | 显示全部楼层
还有这样的程序,下来试试,谢谢
发表于 2008-5-28 09:54:05 | 显示全部楼层
;;;文本上下标
(defun c:wbsxb()
   (vl-load-com)
   (setq cm (getvar "cmdecho") om (getvar "osmode"))
   (setvar "cmdecho" 0) (setvar "osmode" 0)
   (initget "1 2")
   (setq bz (getkword "\n请输入标记类型[1 上标,  2 下标]:"))
   (if (= bz "1") (setq tsf "\n请输入上标:") (setq tsf "\n请输入下标:" ))
   (while (setq qb (car (entsel "\n请选择文本:")))
       (setq sb (getstring tsf)    db (entget qb)
      zg  (cdr (assoc 40 db))
      zfc (cdr (assoc 1 db))            pt (cdr (assoc 10 db))
      wb  (cons 1 (strcat "\\A1;" zfc "{\\H0.7x;\\S" sb "^;}"))
       (if (= bz "2") (setq wb  (cons 1 (strcat "\\A1;" zfc "{\\H0.7x;\\S^" sb ";}"))))
       (if (= (cdr (assoc 0 db)) "TEXT")
           (progn
       (setq pt (mapcar '+ (list 0.2 zg 0) pt))
              (entmake
           (list  '(0 . "MTEXT") '(100 . "AcDbEntity") '(67 . 0) '(100 . "AcDbMText")
                   (cons 10 pt) wb
       (command "_matchprop" qb (entlast) "")
       (entdel qb)
           (progn (setq db (subst wb (assoc 1 db) db)) (entmod db))
   (setvar "cmdecho" cm) (setvar "osmode" om) (princ)
发表于 2008-5-30 19:25:09 | 显示全部楼层
谢谢,正在寻找中。
发表于 2008-6-3 22:38:26 | 显示全部楼层
不就是公差标注吗?
GMT+8, 2026-11-22 09:24 , Processed in 0.458100 second(s), 24 queries , Gzip On, File On.
