查看: 1301|回复: 4
[LISP程序]:请求POLYLINE转变为LWPOLYLINE的函数
发表于 2003-6-19 20:14:35 | 显示全部楼层 |阅读模式
将所选择的POLYLINE转变为LWPOLYLINE,适用于R14,先谢谢了。
已领礼包: 593个
发表于 2003-6-19 23:01:12 | 显示全部楼层
Re: [LISP程序]:请求POLYLINE转变为LWPOLYLINE的函数
最初由 心梦相随 发布
[B]将所选择的POLYLINE转变为LWPOLYLINE,适用于R14,先谢谢了。 [/B]
不用编程,CAD有标准命令的。
  1. Converts 2D polylines and associative hatches to the optimized Release 14 format
  2. 2D polylines and associative hatches are created in Release 14 using an optimized format that saves memory and disk space.
  3. Use CONVERT to update hatches or polylines created in previous versions of AutoCAD.
  4. Command line: convert
  5. Hatch / Polyline / < All >: Enter h for hatches, p for polylines, or a for both
  6. Select / < All >:  Enter s to select objects or a to convert
  7. all objects in the drawing
  8. AutoCAD displays one or both of the following messages.
  9. number hatch objects converted
  10. number 2d polyline objects converted
  11. Hatches do not update automatically when a drawing from a previous release is opened in Release 14. Hatch pattern rotation
  12. information may not update properly if the UCS has changed since the hatch was created. When updating hatches with
  13. CONVERT, it is recommended that you use the Select option so you can check your results.
  14. In most cases, polylines do not need to be updated with CONVERT. By default, the PLINETYPE system variable specifies that
  15. polylines update automatically when an older drawing is opened. Polylines might be created in the old format by
  16. third-party applications,
  17. and they might be contained in an older drawing that was inserted as a block and then exploded.
  18. Note: Polylines containing curve-fit or splined segments always retain the old format, as do polylines that store extended entity
  19. data on their vertices. AutoCAD's editing commands make no distinction between the two formats.
发表于 2003-6-25 16:39:30 | 显示全部楼层
Command: CONVERTPOLY
Convert to Heavy/Light<Light>:
Select objects: 1 found
Select objects:
1 polylines converted.
发表于 2003-6-27 08:49:33 | 显示全部楼层
能解释一下POLYLINE 与LWPOLYLINE的区别吗?
发表于 2003-6-27 08:56:51 | 显示全部楼层
(setq ss (ssget "x" '((0 . "polyline")))
         n 0)
   (if (/= nil ss)
      (progn
         (xdrx_pbarbegin "&Otilde;&yacute;&Ocirc;&Uacute;&acute;&brvbar;&Agrave;íPolyline:" (sslength ss))
         (repeat (sslength ss)
            (xdrx_pbarsetpos n)
            (setq ename (ssname ss n)
                  elist (entget ename)
                  n (1+ n)
            (xdrx_polyline_ConvertFrom ename))
           (xdrx_pbarend))
GMT+8, 2026-11-4 02:10 , Processed in 0.842889 second(s), 40 queries , Gzip On.
