查看: 1936|回复: 2
[求助] [求助]:如何删除双向偏移后的原实体
发表于 2008-10-23 18:45:02 | 显示全部楼层 |阅读模式
以下是我从论坛上找到的双向偏移的代码,经过修改后变为每次选中后当问到偏移距离时直接按右键默认为0.101,并删除原实体,现不知如何实现删除原实体,恳请哪位高手帮我完善下。
;;;|双向偏移 SNSJ 2004.3.8
(defun ptlay (x y)  (vla-put-layer(car(vlax-safearray->list(vlax-variant-value x)))y))
(defun c:2os (/ getds obj lynm)
  (vl-load-com)
  (setq lynm (getstring "\n输入想要偏移的层名:"))
  (and (= "" lynm) (setq lynm (getvar "clayer")))
  (if (null (tblsearch "layer" lynm))
    (vl-cmdf ".layer" "n" lynm "")
  (initget 2)
  (setq getds (getdist (strcat "\n输入偏移距离<默认为0.101>:")))
  (if (null getds) (setq getds 0.101));
  (setvar "OFFSETDIST" getds)
  (if (ssget '((0 . "Arc,Circle,Ellipse,*Line")))
    (vlax-for obj (vla-get-activeselectionset
                    (vla-get-activedocument (vlax-get-acad-object))
      (ptlay (vla-offset obj getds) lynm)
      (ptlay (vla-offset obj (* getds -1)) lynm)
    (vlax-release-object obj)
  (princ)
已领礼包: 9341个
发表于 2008-10-24 09:01:12 | 显示全部楼层
(defun c:2os () ;;(/ getds obj lynm)
(vl-load-com)
(initget 2)
(vla-ERASE obj )  ;;将原有实体删除
(princ)
 楼主| 发表于 2008-10-24 19:42:29 | 显示全部楼层
谢谢了,现在方便多了,再不用一个个去删除了。
GMT+8, 2026-11-7 06:49 , Processed in 0.406712 second(s), 36 queries , Gzip On.
