查看: 1810|回复: 2
[编程申请]:如何实现对闭合的曲线(如圆,椭圆)进行交点打段
发表于 2008-12-24 15:08:19 | 显示全部楼层 |阅读模式
有不能从一点打段一闭合曲线的问题
发表于 2008-12-25 00:22:41 | 显示全部楼层
[PHP]
;;;  CAD2006 & CAD2009 测试通过
;;;  功能:打断某点处任意个对象
;;;  对象:LINE、XLINE、RAY、LWPOLYLINE、POLYLINE、SPLINE、CIRCLE、ARC、ELLIPSE
(DEFUN C:XX        (/ pt sl loop E OBJ num ECHO OS)
  (SETQ        pt         (GETPOINT "\n指定断点:")
                sl         (SSGET        "C"
                                        pt
                                        pt
                                        '((0 . "*LINE,CIRCLE,ARC,ELLIPSE,SPLINE,RAY"))
                loop (IF (NULL sl)
                           0
                           (SSLENGTH sl)
                num         -1
                ECHO (GETVAR "CMDECHO")
                OS         (GETVAR "OSMODE")
  (SETVAR "OSMODE" 0)
  (SETVAR "CMDECHO" 0)
  (REPEAT loop
        (SETQ E (SSNAME sl (SETQ num (1+ num))))
        (COMMAND "BREAK"
                         E
                         pt
                         (IF (AND (MEMBER (CDR (ASSOC 0 (ENTGET E)))
                                                          '("CIRCLE" "ELLIPSE" "SPLINE")
                                          (= (VLAX-CURVE-ISCLOSED E) T)
                           (VLAX-CURVE-GETPOINTATDIST
                                 E
                                 (+ (VLAX-CURVE-GETDISTATPOINT E pt) 0.001)
  (SETVAR "OSMODE" OS)
  (SETVAR "CMDECHO" ECHO)
  (PRINC)
[/PHP]
发表于 2009-1-4 22:34:30 | 显示全部楼层
http://www.theswamp.org/index.php?topic=10370.0
GMT+8, 2026-11-22 08:42 , Processed in 0.179020 second(s), 14 queries , Gzip On, File On.
