查看: 1673|回复: 4
不能收钱?
发表于 2009-1-11 15:45:22 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. (defun th-get-ldata (data / thdata lst)
  3.   (t2-catch '(lambda ()
  4.                (setq thdata (vlax-ldata-get "thdict" data))
  5.                (setq lst (txt-str-split thdata "|"))
  6.              )
  7.   )
  8. )
  9. (defun th-put-ldata (data lst / str)
  10.   (t2-catch '(lambda ()
  11.                (setq str (th-str-unparse lst "|"))
  12.                (vlax-ldata-put "thdict" data str)
  13.              )
  14.   )
  15. )
  16. (defun t2-get-ldata (data / thdata lst)
  17.   (t2-catch '(lambda ()
  18.                (setq thdata (vl-registry-read "HKEY_CURRENT_USER\\Software\\Autodesk\\THCAD"
  19.                                               data
  20.                             )
  21.                )
  22.                (setq lst (txt-str-split thdata "|"))
  23.              )
  24.   )
  25. )
  26. (defun t2-put-ldata (data lst / str)
  27.   (t2-catch '(lambda ()
  28.                (setq str (th-str-unparse lst "|"))
  29.                (vl-registry-write "HKEY_CURRENT_USER\\Software\\Autodesk\\THCAD"
  30.                                   data str
  31.                )
  32.              )
  33.   )
  34. )
  35. (defun txt-str-split (str x / lst n str-n xlen)
  36.   (setq xlen (strlen x))
  37.   (while (setq n (vl-string-search x str))
  38.     (setq str-n (substr str 1 n))
  39.     (if (/= str-n "")
  40.       (setq lst (cons str-n lst))
  41.     )
  42.     (setq str (substr str (+ 1 xlen n)))
  43.   )
  44.   (if (/= str "")
  45.     (setq lst (cons str lst))
  46.   )
  47.   (reverse lst)
  48. )
  49. (defun th-str-unparse (lst delimiter)
  50.   (t2-catch '(lambda ()
  51.                (apply
  52.                  'strcat
  53.                  (mapcar
  54.                    '(lambda (x)
  55.                       (strcat x delimiter)
  56.                     )
  57.                    lst
  58.                  )
  59.                )
  60.              )
  61.   )
  62. )
  63. (defun t2-catch (lambda-expression / catch:err)
  64.   (setq catch:err (vl-catch-all-apply lambda-expression))
  65.   (if (vl-catch-all-error-p catch:err)
  66.     (prompt (strcat "\n" (vl-catch-all-error-message catch:err)
  67.                     "\n执行表达式: " (vl-princ-to-string lambda-expression)
  68.                     "时出错.\n\n"
  69.             )
  70.     )
  71.     catch:err
  72.   )
  73. )
  74.   [/FONT]
测试:
  2. 命令: !lst ("aeo" "wkai" "zml" "eachy" "xyp1964" "露水" "狂刀" "都是牛人" "oye" "晓东不管事"
  3. "最近偶尔冒泡")
  4. 命令: (t2-put-ldata "thdata" lst)
  5. "aeo|wkai|zml|eachy|xyp1964|露水|狂刀|都是牛人|oye|晓东不管事|最近偶尔冒泡|"
  6. 命令: (th-put-ldata "thdata" lst)
  7. "aeo|wkai|zml|eachy|xyp1964|露水|狂刀|都是牛人|oye|晓东不管事|最近偶尔冒泡|"
  8. 命令: (th-get-ldata "thdata")
  9. ("aeo" "wkai" "zml" "eachy" "xyp1964" "露水" "狂刀" "都是牛人" "oye" "晓东不管事" "最近偶尔冒泡")
  10. 命令: (t2-get-ldata "thdata")
  11. ("aeo" "wkai" "zml" "eachy" "xyp1964" "露水" "狂刀" "都是牛人" "oye" "晓东不管事" "最近偶尔冒泡")
  12.   [/FONT]
复制代码
发表于 2009-1-11 18:48:33 | 显示全部楼层
Put-data 最好有个 Key,这样一个 Dict 下可以记录多个数据
发表于 2009-1-11 20:18:32 | 显示全部楼层
现在就是将多个数据存在表里,再转化为字符串。取出时再将字串转化为表的。
发表于 2009-1-11 20:33:00 | 显示全部楼层
我的意思是
  1. Thdict -> "key1" -> string1
  2.        -> "key2" -> string2
  3.        -> "key3" -> string3
复制代码
发表于 2009-1-11 21:02:38 | 显示全部楼层
多谢二位老师,正需要用到词典存储数据,学习了。再请教一下,您这个方式储存的数据的大小有限制吗?我想用关联表的形式将我应用程序中的一些数据保存在图中,总表里有很多子表,数据量可能很大的,会有限制吗?有些资料说任意不限,最多可达2GB,您这个是不是也能这样呢? 还有Free-Lancer 大侠说的 多个key 又如何实现呢?
GMT+8, 2026-11-22 08:29 , Processed in 4.200161 second(s), 8 queries , Gzip On, File On.
