查看: 1787|回复: 2
[求助] [求助]:怎样获得块中的直线的端点坐标
发表于 2009-2-11 09:05:53 | 显示全部楼层 |阅读模式
我要的效果是选择一个块,获得选中点所在直线的端点坐标,这个直线是指块里的一条直线,
谢谢各位高手
发表于 2009-2-11 13:58:17 | 显示全部楼层
  1.   [FONT=courier new]
  2. (defun thacadobj ()
  3.   (cond
  4.     (%$*thacadobj*$%)
  5.     (setq %$*thacadobj*$% (vlax-get-acad-object))
  6.   )
  7. )
  8. (defun thactdoc ()
  9.   (cond
  10.     (%$*thactdoc*$%)
  11.     (setq %$*thactdoc*$% (vla-get-activedocument (thacadobj)))
  12.   )
  13. )
  14. (defun th-subentsel (msg / mvar obj utilobj)
  15.   (setq utilobj (vla-get-utility (thactdoc))
  16.         mvar (vlax-make-variant (strcat "\n" msg ":"))
  17.   )
  18.   (vl-catch-all-apply '(lambda ()
  19.                          (vla-getsubentity utilobj 'obj 'pt 'tm 'cd mvar)
  20.                        )
  21.   )
  22.   obj
  23. )
  24. (defun th-get-dxf (g e)
  25.   (cond
  26.     ((= 'ename (type e))
  27.       (cdr (assoc g (entget e)))
  28.     )
  29.     ((= 'list (type e))
  30.       (cdr (assoc g e))
  31.     )
  32.   )
  33. )
  34. (defun c:test (/ e)
  35.   (setq e (vlax-vla-object->ename (th-subentsel "\n请点击块中LINE:")))
  36.   (if (= (th-get-dxf 0 e) "LINE")
  37.     (list (th-get-dxf 10 e) (th-get-dxf 11 e))
  38.     (progn
  39.       (prompt "\n点击段为非LINE")
  40.       (princ)
  41.     )
  42.   )
  43. )
  44.   [/FONT]
发表于 2016-4-11 15:35:19 | 显示全部楼层
:lol果断收藏了!
GMT+8, 2026-11-22 11:40 , Processed in 0.639552 second(s), 14 queries , Gzip On, File On.
