查看: 2087|回复: 0
AutoCAD Visual LISP Technical Newsletter - November 1999
发表于 2002-1-7 02:15:10 | 显示全部楼层 |阅读模式
This document is part of    Visual Lisp Newsletter Archive
/Note: the URLs in this posting may be broken into several lines by the
transmission media. Please make sure that you have the full URL before
trying to access it./
/Note: Have you missed a Newsletter issue? Visit our Newsletter archive at
the following URL:/
http://adn.autodesk.com/techsupp/docs/newsletters.htm
Dear Visual LISP developer,
Table of Contents
(1) R14->R2000 LDATA ACCESSIBILITY
(2) Reactors in Visual LISP
(3) Debugging Visual LISP code
(4) New or updated solutions
Into AutoCAD 2000, you may try loading an R14 drawing with ldata. But
unfortunately you'll be denied to access to R14's ldata while using
vlax-ldata-*** functions. This is due to a version incompatibility.
The workaround is provided at the following solution URL which contains
an attachment.
/cgi-bin/solution.pl?SID=45315
After you have downloaded the attachment and extracted it's files, move
the files ldataproxy.dll and ldata.arx into the same directory of your
machine's AutoCAD 2000 executable. You will see in the demonstrative
LISP file, checkforldata.lsp, the lines:
(if (null ldata-activate) (arxload "ldata.arx") )
(ldata-activate "EN81LIFTA")
The ldata.arx implements an external lisp function: ldata-activate. This
function takes as an argument the base filename (without extension) of the
compiled R14 Visual LISP ARX application. This will recover the proxy
information and allow the vlax-ldata-*** functions to work as expected.
While in R2000, if you run the function (chkforLdata) on the R14 drawing
included, you will observe a dump of the R14-generated ldata information.
Note: The R14 ldata will not withstand a round-trip of saves. If you save
the drawing in A2000 format, next time you open the dwg, you don't need to
execute the procedure. If you save the DWG back to R14 format, though, you
won't be able to access the LDATA info anymore in R14.
Visual LISP not only makes program development easier and faster, it also
provides new functionality to AutoLISP applications. For example, you can
attach reactors to entities in the AutoCAD drawing window, allowing your
application to respond to user actions on these entities.
A reactor is an object you attach to AutoCAD drawing objects in order to have
AutoCAD notify your application when events you are interested in occur. For
example, if a user moves an entity that your application has attached a
reactor to, your application will receive notification that the entity has
moved. If you design it to do so, your application can react to this
notification with appropriate actions, such as moving other entities
associated with the one moved, or perhaps updating a text tag that records
revision information on the altered drawing feature.
A reactor communicates with your application by calling a function you have
associated with the reactor. Such a function is referred to as a callback
function. There isn't anything particularly unusual about reactor callback
functions, they are like other functions you write with Visual LISP. They
become callback functions when you attach them to reactor events.
There are many types of AutoCAD reactors. Each reactor type responds to one
or more AutoCAD events. The different types of reactors are grouped into
the following categories:
+ Database Reactors
  Database reactors notify your application when specific events occur to
  the drawing database, such as when an object has been added to the
  database.
+ Document Reactors
  Document reactors notify your application of a change to the current
  drawing document, such as opening a new drawing document, activating a
  different document window, and changing a document's lock status.
+ Editor Reactors
  Editor reactors notify you each time an AutoCAD command is invoked;
  a drawing opens, closes, or is saved;
  a DXF file is imported or exported;
  or a system variable changes value.
+ Linker Reactors
  Linker reactors notify your application every time an ARX application is
  loaded or unloaded.
+ Object Reactors
  Object reactors notify you each time a specific object is changed, copied,
  or deleted.
With the exception of Editor reactors, there is one type of reactor for each
reactor category.
Reactors may be transient or persistent. Transient reactors are lost when a
drawing closes; this is the default reactor mode. Persistent reactors are
saved with the drawing and exist when the drawing is next opened.
Use the vlr-pers function to make a reactor persistent. To remove persistence
from a reactor and make it transient, use vlr-pers-release. Each function
takes a Reactor object as its only argument.
HOW TO MONITOR AERIAL VIEW USAGE WITH VISUAL LISP
/cgi-bin/solution.pl?SID=7578
MAKING REACTORS PERSISTENT IN A DRAWING
/cgi-bin/solution.pl?SID=10858
In AutoCAD 2000 functions are no longer lists. You will need to use the
Visual LISP IDE to locate the point of failure in your code. While it may
require some work learning about these IDE debug features, you'll find that
it's a much better environment to debug lisp code than that old command line
dump.
What you need to do to enable this facility (since the default is as you know
otherwise), will be to open the Visual LISP IDE at the beginning of your
AutoCAD session (type VLIDE at the command line), and go to the Debug Pulldown
menu in the IDE, and Select the 'Break On Error'. Then load your lisp code and
run it. When an error in your code occurs, you'll be put back into the Visual
LISP IDE, all you'll need to do to see which line caused the error is to
select the 'Last Break' option on the Debug Toolbar, or the
'Last Break Source' on the Debug pulldown.
There's many more powerful tools available to debug your lisp code using the
Visual LISP IDE, please refer to the Visual LISP Developer's Guide
See Chapter 3 -- Debugging Programs
for more information on using the IDE and it's debug features.
CREATING AND MANIPULATING XRECORDS USING AUTOLISP
/cgi-bin/solution.pl?SID=16132
(COMMAND) FUNCTION DOES NOT WORK WITH NEW AND OPEN
/cgi-bin/solution.pl?SID=29417
HOW TO IDENTIFY UNREFERENCED LAYERS IN LISP?
/cgi-bin/solution.pl?SID=30528
CREATION & MANIPULATION OF GROUPS USING AUTOLISP IN R14
/cgi-bin/solution.pl?SID=44942
USING THE SELECTION SET SELECT METHOD IN VISUAL LISP
/cgi-bin/solution.pl?SID=12298
USING A VB ACTIVEX DLL FROM VISUAL LISP OR VB(A)
/cgi-bin/solution.pl?SID=15992
CONSTUCTING Visual LISP LWPOLYLINE VIA ACTIVEX
/cgi-bin/solution.pl?SID=16152
EXTENSION DICTIONARY TO ASSOCIATE OBJECTS
/cgi-bin/solution.pl?SID=21716
HOW TO OPEN A NEW DRAWING IN VISUAL LISP
/cgi-bin/solution.pl?SID=30445
ATTRIBUTE DIALOG IS NOT DISPLAYING WHEN ATTDIA=1
/cgi-bin/solution.pl?SID=32444
HOW DO I REPLACE THE PLOTTER AND PLOTID SYSTEM VARIABLES
/cgi-bin/solution.pl?SID=41173
USING LISP TO FILTER SPECIFIC EXTENDED ENTITY DATA
/cgi-bin/solution.pl?SID=44434
WHAT IS THE OBJECT THAT VLAX-LDATA-XXX MANIPULATED?
/cgi-bin/solution.pl?SID=44984
USING LISP TO MODIFY THE ACAD SYSTEM VARIABLE
/cgi-bin/solution.pl?SID=45047
USING AN ARX ACTIVEX SERVER TO UPDATE THE BLOCK DESCRIPTION FROM LISP
/cgi-bin/solution.pl?SID=45070
ACAD.LSP & ACADDOC.LSP DO NOT LOAD IN DOCUMENT CREATED BY (COMMAND "NEW")
/cgi-bin/solution.pl?SID=45180
USING AN ARX ACTIVEX SERVER TO DETERMINE THE LOADED LISP FILES
/cgi-bin/solution.pl?SID=45186
WORKAROUND LOAD FAILURE ACAD.LSP/ACADDOC.LSP WHEN USING COMMAND NEW/OPEN
/cgi-bin/solution.pl?SID=45304
To subscribe or unsubscribe, go to
     You received this message as a result of your registration
     on the ADN List Server subscription page.  If you no longer wish
     to receive these messages, read the next section, How to use this
     mailing list.
     How to use this mailing list:
     You may unsubscribe from this e-mail newsletter, or subscribe to
     a variety of other informative e-mail newsletters, by returning
     to the ADN List Server subscription page at
     and changing your subscription preferences.
     Alternatively, from the subscribed account you can send an e-mail to
     <Majordomo-partnersys@autodesk.com> with the following command in the
     body of your email message:
     unsubscribe <list-name>
     Autodesk Developer Network (ADN) information and events:
     For information on all ADN topics, please visit:
       http://www.autodesk.com/adn
     THIS DOCUMENT IS PROVIDED FOR INFORMATIONAL PURPOSES ONLY.  The
     information contained in this document represents the current view of
     Autodesk Inc. on the issues discussed as of the date of publication.
     Because Autodesk must respond to change in market conditions, it
     should not be interpreted to be a commitment on the part of Autodesk
     and Autodesk cannot guarantee the accuracy of any information
     presented after the date of publication.
     INFORMATION PROVIDED IN THIS DOCUMENT IS PROVIDED 'AS IS' WITHOUT
     WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
     LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
     PARTICULAR PURPOSE AND FREEDOM FROM INFRINGEMENT.
     The user assumes the entire risk as to the accuracy and the use of
     this document. This  document may be copied and distributed subject to
     the following conditions:
     1.   All text must be copied without modification and all pages must
          be included
     2.   All copies must contain Autodesk's copyright notice and any other
          notices provided therein
     3.   This document may not be distributed for profit
GMT+8, 2026-11-22 08:53 , Processed in 0.198050 second(s), 11 queries , Gzip On, File On.
