查看: 2000|回复: 3
[求助]:vs2005+objectarx2007 如何实现关闭wipeout边
发表于 2009-6-20 15:26:15 | 显示全部楼层 |阅读模式
我创建wipeout的代码如下:
static AcDbObjectId PostToModelSpace(AcDbEntity *pEnt)
                AcDbBlockTable *pBlockTable;
                acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable,AcDb::kForRead);
                AcDbBlockTableRecord *pBlockTableRecord;
                pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
                AcDbObjectId entId;
                Acad::ErrorStatus es=pBlockTableRecord->appendAcDbEntity(entId,pEnt);
                pBlockTable->close();
                pBlockTableRecord->close();
                pEnt->close();
                return entId;
        static void trans3DTo2D(AcGePoint3dArray& arr3d, AcGePoint2dArray& arr2d)
                for(int i = 0; i < arr3d.length(); i++)
                        AcGePoint3d pt3d = arr3d.at(i);
                        AcGePoint2d pt2d(pt3d.x, pt3d.y);
                        arr2d.append(pt2d);
        static void wptest()
                AcGePoint3d pt1;
                AcGePoint3dArray cbPtAry;
                pt1[0] = 300; pt1[1] = 300; pt1[2] = 0;
                cbPtAry.append(pt1);
                pt1[0] = 700; pt1[1] = 300; pt1[2] = 0;
                pt1[0] = 700; pt1[1] = 100; pt1[2] = 0;
                pt1[0] = 300; pt1[1] = 100; pt1[2] = 0;
                pt1[0] = 300;pt1[1] = 300;pt1[2] = 0;
                // TODO: Implement the command
                AcRxClass* pClass = AcRxClass::cast(acrxClassDictionary->at(L"AcDbWipeout"));
                AcDbEntity *pWipeOut=(AcDbEntity *)pClass->create();
                AcDbRasterImage *pImage = AcDbRasterImage::cast(pWipeOut);
                // Set clip boundary
                AcGePoint3d origin;
                //AcGeVector3d u;
                //AcGeVector3d v;
                AcGeVector3d u(400,0,0);
                AcGeVector3d v(0,400,0);
                pImage->getOrientation(origin, u, v);
                pImage->setOrientation(origin, u, v);
                pImage->setClipBoundaryToWholeImage();
                AcGeMatrix3d PixelToModel,ModelToPixel;
                pImage->getPixelToModelTransform(PixelToModel);
                ModelToPixel=PixelToModel.invert();
                for(int i=0;i< cbPtAry.length();i++)
                        cbPtAry.transformBy(ModelToPixel);
                AcGePoint2dArray poly2d;
                //XdGeUtils::trans3DTo2D(&cbPtAry,poly2d);
                trans3DTo2D(cbPtAry,poly2d);
                pImage->setClipBoundary(AcDbRasterImage::kPoly,poly2d);
                pImage->setDisplayOpt(AcDbRasterImage::kTransparent,Adesk::kTrue);
                pImage->setDisplayOpt(AcDbRasterImage::kShow,Adesk::kFalse );
                pWipeOut=(AcDbEntity *)pImage;
                //if(PostToModelSpace(pImage)==Acad::eOk)
                //if(appendToModelSpace(pWipeOut)==Acad::eOk)
                PostToModelSpace(pImage);
                pImage->close();
                //pWipeOut->close();
                acutPrintf(L"\nYes,append");
        // - GJwipeout._WO command (do not rename)
        static void GJwipeout_WO(void)
                // Add your code for command GJwipeout._WO here
                wptest();
我知道用cad的wipeout+F命令可以关闭边框,但我想通过程序实现,请各位大虾不吝赐教!
发表于 2009-6-24 19:42:40 | 显示全部楼层
我也用过这样的问题
发表于 2009-6-27 15:35:30 | 显示全部楼层
下个东西还要回复,尽要大家说费话
发表于 2009-7-6 16:29:16 | 显示全部楼层
AcDbDatabase的命名对象字典中,与“ACAD_WIPEOUT_VARS”为主键的对象中保存着“AcDbWipeout”对象是否显示边框的标记变量,这个变量的DXF组码为70,对应的变量类型为16位短整型,把这个变量的值设为1就显示边框,设为0则隐藏边框。
如果采用特殊手段修改了这个变量,则需要手动刷新这个数据库中所有AcDbWipeout对象。
呵呵,说的已经是非常详细了,你可以自己试验一下。
GMT+8, 2026-11-3 20:15 , Processed in 0.711294 second(s), 38 queries , Gzip On.
