查看: 2172|回复: 2
[编程申请]:根据已知的pl线的长度,设置特定的高度,自动画出等高的矩形,矩形的
发表于 2009-9-12 14:48:40 | 显示全部楼层 |阅读模式
根据已知的pl线的长度,设置特定的高度,自动画出等高的矩形,矩形的宽就是pl线的长度。见图,希望哪位大哥帮忙给个lisp的代码,万分感谢,谢谢。
发表于 2009-9-13 07:59:10 | 显示全部楼层
[php](defun c:tt ()
  (CMDLA0)
  (defun main-pro ()
    (setq e1  (entsel "\n多段线: ")
          s1  (car e1)
          ptn (xyp-get-Vertexs s1 3)
          ptn (cons (last ptn) ptn)
          p0  (getpoint (cadr e1) "\n基点")
          i   0
    (while (and        (setq p1 (nth i ptn))
                (setq p2 (nth (setq i (1+ i)) ptn))
      (setq p01        (polar p0 0 (distance p1 p2))
            p3        (xyp-get-Pt2XY p01 0 d1)
      (xyp-rectang p0 p3)
      (setq p0 (polar p01 0 d2))
  (xyp-initSet '(d1 d2) '(1000. 100.))
  (setq        Ilst '(("d1" "高度" "real" "10")
               ("d2" "间隔" "real" "10")
               (nil nil "spacer;")
  (if (= (xyp-Dcl-Init Ilst "【等高矩形】" t) 1)
    (main-pro)
  (CMDLA1)
)[/php]
 楼主| 发表于 2009-9-13 17:16:20 | 显示全部楼层
万分感谢,看了你的说明了,已经解决,谢谢
GMT+8, 2026-11-22 07:58 , Processed in 0.413232 second(s), 14 queries , Gzip On, File On.
