查看: 1439|回复: 3
[日积月累]:测试多段线是否有弧段。
已领礼包: 593个
发表于 2003-6-26 23:51:56 | 显示全部楼层 |阅读模式
  1. (defun ea:pl_hasBulges (e  / tf)
  2.   (foreach x (entget e)
  3.     (if        (and (= (car x) 42)
  4.              (/= (cdr x) 0.0)
  5.         )
  6.       (setq tf t)
  7.     )
  8.   )
  9.   tf
  10. )
发表于 2005-10-10 02:46:20 | 显示全部楼层
  1. ;;(xd-hasbulge (car(entsel))) ;; 支持lwpolyline,polyline
  2. (defun xd-hasbulge (e / o n bgs)
  3.   (setq o (vlax-ename->vla-object e)
  4.         n (fix(vlax-curve-getendparam o)))
  5.   (repeat n
  6.     (setq bgs (cons (vla-getbulge o (setq n(1- n))) bgs))
  7.   )
  8.   (not(apply '= (cons 0 bgs)))
  9. )
已领礼包: 593个
 楼主| 发表于 2005-10-10 23:49:07 | 显示全部楼层
  1. ;;(xdl-pl-hasbugle (entget (car (entsel))))
  2. (defun xdl-pl-hasbugle (el / tf el)
  3.   (if (assoc 42 el)
  4.     (while (and (not tf) el)
  5.       (if (and (= (caar el) 42)
  6.                (/= (cdar el) 0.0)
  7.           )
  8.         (setq tf t)
  9.       )
  10.       (setq el (cdr el))
  11.     )
  12.     (progn
  13.       (setq e (cdr (assoc -1 el)))
  14.       (while (and (not tf)
  15.                   (setq        e  (entnext e)
  16.                         el (entget e)
  17.                   )
  18.                   (/= "SEQEND" (cdr (assoc 0 el)))
  19.              )
  20.         (if (/= (cdr (assoc 42 (entget e))) 0.)
  21.           (setq tf t)
  22.         )
  23.       )
  24.     )
  25.   )
  26.   tf
  27. )
已领礼包: 11个
发表于 2021-4-27 14:18:46 | 显示全部楼层
感谢!!学习了!
GMT+8, 2026-11-3 09:39 , Processed in 0.546006 second(s), 38 queries , Gzip On.
