楼主: XDSoft
[他山之石] 程序代码高亮设置方法,贴代码前必看...
发表于 2018-5-18 12:10:14 | 显示全部楼层
[pcode=csharp,true]
程序代码
[/pcode]
发表于 2018-6-20 09:41:40 | 显示全部楼层
不错继续学习
发表于 2018-8-27 11:13:54 | 显示全部楼层
顶...顶很多东西
发表于 2019-1-23 12:18:01 | 显示全部楼层
看看学习一下,规范起来才好
发表于 2019-3-15 16:27:30 | 显示全部楼层
  1. (defun c:tt (/ hz lst pt ss txt txt1 var x xw y)
  2.   (if (and
  3.         (xdrx_initssget "\n选取要统计的文字<退出>:")
  4.         (setq ss (xdrx_ssget '((0 . "TEXT"))))
  5.       )
  6.     (progn
  7.       (xdrx_begin)
  8.       (xdrx_sysvar_push '("dimzin" 0))
  9.       (setq lst (mapcar
  10.                   '(lambda (x)
  11.                      (setq txt (xdrx_getpropertyvalue x "textstring"))
  12.                      (setq txt1 (xd::string:regexps "[\\u4e00-\\u9fa5]{1,}[0-9.]+"
  13.                                                     txt ""
  14.                                 )
  15.                      )
  16.                      (if txt1
  17.                        (setq lst (mapcar
  18.                                    '(lambda (y)
  19.                                       (setq hz (xd::string:regexps "[\\u4e00-\\u9fa5]{0,}"
  20.        y ""
  21.                                                )
  22.                                       )
  23.                                       (setq xw (xd::string:regexps "(-?[0-9]+)(\\.[0-9]+)?"
  24.        y ""
  25.                                                )
  26.                                       )
  27.                                       (list (car hz) (atof (car xw)))
  28.                                     )
  29.                                    txt1
  30.                                  )
  31.                        )
  32.                      )
  33.                    )
  34.                   (xdrx_pickset->ents ss)
  35.                 )
  36.             lst (apply
  37.                   'append
  38.                   lst
  39.                 )
  40.             lst (xd::list:groupbyindex lst 0.1)
  41.             lst (vl-sort lst '(lambda (x y)
  42.                                 (< (car x) (car y))
  43.                               )
  44.                 )
  45.             lst (mapcar
  46.                   '(lambda (x)
  47.                      (list (car x) (rtos (apply
  48.                                            '+
  49.                                            (cdr x)
  50.                                          ) 2 1
  51.                                    )
  52.                      )
  53.                    )
  54.                   lst
  55.                 )
  56.             lst (append lst (list (list "合计" (rtos (apply '+ (mapcar '(lambda(x)(atof (cadr x))) lst)) 2 1))))
  57.             lst (append
  58.                   (list (list "统计表" nil) '("名 称" "数 量"))
  59.                   lst
  60.                 )
  61.       )
  62.       (if (not #miaomu-tj-height)
  63.         (setq #miaomu-tj-height 3.5)
  64.       )
  65.       (if (setq var (getreal (xdrx_prompt "\n字高<" #miaomu-tj-height ">:" t)))
  66.         (setq #miaomu-tj-height var)
  67.       )
  68.       (if (setq pt (getpoint "\n表格插入点:"))
  69.         (progn
  70.           (xd::text:init 1)
  71.           (XD::Table:MakeFromList lst pt #miaomu-tj-height (/ #miaomu-tj-height
  72.                                                               2.0
  73.                                                            )
  74.           )
  75.         )
  76.       )
  77.       (xdrx_sysvar_pop)
  78.       (xdrx_end)
  79.     )
  80.   )
  81.   (princ)
  82. )
发表于 2019-9-20 13:03:07 | 显示全部楼层
感谢分享,学习一下
发表于 2019-9-20 13:19:10 | 显示全部楼层
感谢分享,学习一下
发表于 2020-5-23 11:30:54 | 显示全部楼层
表示看不懂
发表于 2021-3-27 08:15:26 | 显示全部楼层
学习了
发表于 2022-5-17 08:23:11 | 显示全部楼层
学习了~学习了~学习了~
发表于 2023-10-26 23:36:30 | 显示全部楼层
x64win7 chrome100,语法着色不正常
发表于 2023-10-26 23:49:22 | 显示全部楼层
一直在高亮进行中
GMT+8, 2026-11-22 07:19 , Processed in 0.290678 second(s), 29 queries , Gzip On, File On.
