楼主: XDSoft
[研讨] 块中套块的实体修改其中的图元属性的实现
发表于 2013-4-20 20:43:58 | 显示全部楼层
再简化下
[pcode=lisp,true](defun c:tt (/ thisdrawing blocks chgblkcol)
  (defun chgblkcol (bn /)
    (vlax-for obj (vla-item blocks bn)
      (vlax-put obj acbyblock)
      (if (wcmatch (vla-get-objectname "AcDbBlockReference"))
                 (chgblkcol (vla-get-objectname obj))
  (setq        thisdrawing (vla-get-activedocument (vlax-get-acad-object))
              blocks            (vla-get-blocks thisdrawing)
  (if (ssget '((0 . "insert")))
    (vlax-for obj (vla-get-activeselectionset thisdrawing) ;_有时有Bug
      (chgblkcol (vla-get-name obj))
      (vla-put-color obj 4)
  (princ)
)[/pcode]
发表于 2013-4-20 21:01:00 | 显示全部楼层
解密下院长的函数
[pcode=lisp,true](defun *Thisdrawing* ()
(defun xyp-e2o (e)
  (vlax-ename->vla-object e)
(defun xyp-block-objlist (obj / lst)
  (vlax-for x (vla-item        (vla-get-blocks
                          (*Thisdrawing*)
                        (vla-get-name obj)
    (if        (wcmatch (vla-get-objectname x) "AcDbBlockReference")
      (setq lst (cons (xyp-block-objlist x) lst))
      (setq lst (cons x lst))
  lst
)[/pcode]
评分
参与人数 1D豆 +5 收起 理由
炫翔 + 5 技术引导讨论和指点奖!
查看全部评分
发表于 2013-4-20 21:04:35 | 显示全部楼层
  1. (defun xyp-Block-ObjList (obj / vlst)
  2.   (setq po (vlax-get obj "InsertionPoint"))
  3.   (defun bbb (obj / x)
  4.     (vlax-for x        (vla-item (vla-get-Blocks
  5.                             (vla-get-ActiveDocument (vlax-get-acad-object))
  6.                           )
  7.                           (vla-get-name obj)
  8.                 )
  9.       (if (= (vla-get-objectname x) "AcDbBlockReference")
  10.         (progn
  11.           (setq po (vlax-get x "InsertionPoint"))
  12.           (bbb x)
  13.         )
  14.       )
  15.       (setq vlst (cons (list po x) vlst))
  16.     )
  17.   )
  18.   (bbb obj)
  19. )
评分
参与人数 1D豆 +5 收起 理由
炫翔 + 5 技术引导讨论和指点奖!
查看全部评分
已领礼包: 8125个
发表于 2013-4-20 21:28:22 | 显示全部楼层
似乎这个题目如果不用递归的话,就没办法了吗?呵呵
已领礼包: 145个
 楼主| 发表于 2013-4-20 21:42:35 | 显示全部楼层
大家可以讨论下,不用递归怎么实现。递归的优点是代码量短,但效率往往不及迭代,递归算法一般也可以用迭代算法来实现。 看看谁能用迭代算法用LISP给实现了。
发表于 2013-4-20 22:01:34 | 显示全部楼层
不用递归也可以哦!
[pcode=lisp,true](defun chblkcolor (NAME COLOR / ITEMSALL OBJLIST BLOCKS OBJ OBJNAME)
  (defun itemsall (obj / l)
    (vlax-for a obj (setq l (cons a l)))
    (reverse l)
  (setq
    objlist (itemsall (vla-item        (setq blocks (vla-get-blocks
                                name
  (while objlist
    (setq obj          (car objlist)
          objlist (cdr objlist)
    (if        (or (= (setq objname (vla-get-ObjectName obj))
            (= objname "AcDbMInsertBlock")
      (setq objlist (append objlist (itemsall (vla-item blocks (vla-get-name obj)))))
      (vla-put-color obj color)
;;测试
(chblkcolor (cdr (assoc 2 (entget (car (entsel))))) 5)[/pcode]
评分
参与人数 1D豆 +5 收起 理由
炫翔 + 5 技术引导讨论和指点奖!
查看全部评分
发表于 2013-4-21 09:38:08 | 显示全部楼层
将块改颜色进行到底,不知道这个算法算不算迭代[pcode=lisp,true](defun chgblkcol (bnlst / bn)
  (while bnlst
    (vlax-for obj
                        (car bnlst)
      (vla-put-color obj acbyblock)
      (if (and (wcmatch (vla-get-objectname obj) "AcDbBlockReference")
               (not (assoc (setq bn (vla-get-name obj)) bnlst))
        (progn
          (if (vla-get-hasattributes obj)
            (foreach x (vlax-invoke obj 'getattributes)
              (vlax-put x 'color acbyblock)
            ) ;_处理属性
          (setq bnlst (cons bn (cdr bnlst))) ;_再次添加不包括的图块,每个图块仅处理一次
        (setq bnlst (cdr bnlst)) ;_处理下一个图块
(defun c:tt (/ ss sl i e el bnlst elst)
  (if (and (setq col (acad_colordlg 4))
           (setq ss (ssget '((0 . "insert"))))
    (progn
      (setq sl (sslength ss)
            i  -1
      (repeat sl
        (setq e            (ssname ss (setq i (1+ i)))
              el    (entget e)
              bnlst (if        (not (assoc (setq bn (cdr (assoc 2 el))) bnlst))
                      (cons bn bnlst)
                    ) ;_块名列表
        (if (assoc 62 el)
          (setq elst (cons e elst))
        ) ;_首层属性块
        (vlax-put (vlax-ename->vla-object e) 'color col)
        (if elst
          (foreach x elst
            (foreach y (vlax-invoke (vlax-ename->vla-object e) 'getattributes)
              (vlax-put y 'color acbyblock)
      (chgblkcol bnlst)
      ;;(vl-cmdf ".cmdf" regen)
  (princ)
)[/pcode]
发表于 2013-4-21 09:50:02 | 显示全部楼层
再补充一句,块内的 SEQEND 实体也可以有图层,这个实体无法用 ActiveX 方法获取,只能 Entnenxt 来获取并修改,某些“专业”软件会自作主张的将这个实体也赋予图层,带来的问题就是 Purge 的时候找不到实体也不能删除图层。
发表于 2013-4-21 10:07:00 | 显示全部楼层
  1. (defun c:tt (/ i ss s1 pt)
  2.   (defun aaa (obj / vlst)
  4.       (vlax-for x (vla-item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object)))
  5.                     (vla-get-name obj)
  6.                   )
  7.         (if (= (vla-get-objectname x) "AcDbBlockReference")
  8.           (bbb x)
  9.         )
  10.         (setq vlst (cons x vlst))
  11.       )
  12.     )
  13.     (bbb obj)
  14.   )
  15.   (if (and (setq s1 (car (entsel "\n选择: ")))
  16.            (equal (cdr (assoc 0 (entget s1))) "INSERT")
  17.       )
  18.     (foreach a (aaa (vlax-ename->vla-object s1))
  19.       (vla-put-color a 4) ;4为颜色号,可自定义
  20.     )
  21.   )
  22.   (command "regen")
  23.   (princ)
  24. )
已领礼包: 1632个
财富等级: 堆金积玉
发表于 2013-4-21 13:42:49 | 显示全部楼层
这类处理一般都是先遍历块,然后再处理
已领礼包: 145个
 楼主| 发表于 2013-4-21 14:07:06 | 显示全部楼层
Free-Lancer 发表于 2013-4-21 09:38
将块改颜色进行到底,不知道这个算法算不算迭代(defun chgblkcol (bnlst / bn)
  (while bnlst
    (vlax ...
判断是不是用了“递归”,如果程序中没有函数再调用自身,那就不是递归。
发表于 2013-4-22 18:28:55 | 显示全部楼层
翻了多年不动的箱底,发现一个,这是个通用改特性的函数。前面有一个题目是改块属性角度的,可以在这个基础上稍微修改一下,也可解。
[pcode=lisp,true](xblkp blkobj prop val) = 递归改块属性.--------ok!---By lxx 2004.11.12
参数: blkobj = vla块实体.
      prop, val = 属性,新值.
测试: ok!
(setq blk (vla-item blks (vla-get-name (vlax-ename->vla-object (car(entsel))))))
(xblkp blk 'color 3)
(defun xblkp (blkobj prop val )
  (if (not *doc) (setq *doc (vla-get-activedocument (vlax-get-acad-object))))
  (if (not blks) (setq blks (vla-get-blocks *doc)))
  (vlax-for obj blkobj  ;; obj = 块内实体.
    (if(= (vla-get-objectname obj) "AcDbBlockReference")
       (xblkp (vla-item blks (vla-get-name obj)) prop val)
       (vlax-put obj prop val)
)[/pcode]
发表于 2013-4-22 18:31:50 | 显示全部楼层
用了lisp格式代码标志怎么没有效果?还不能edit?
发表于 2013-4-25 18:31:24 | 显示全部楼层
似乎只会用遍历
已领礼包: 145个
 楼主| 发表于 2013-4-26 22:16:36 | 显示全部楼层
江南,怎么理解你的话呢?
GMT+8, 2026-11-5 04:25 , Processed in 0.455602 second(s), 54 queries , Gzip On.
