查看: 4663|回复: 6
[飞鸟集] 未公开的LISP函数用法讨论
发表于 2013-5-7 13:13:28 | 显示全部楼层 |阅读模式
函数:
seturl
geturl
设置链接在一个实体上,或者获取链接。
例如:
[pcode=lisp,true](defun c:test1 (/ e)
  (if (setq e (car (entsel "\nSelect Object to Add Hyperlink to: ")))
    (seturl e "http://www.google.co.uk")
  (princ)
(defun c:test2 (/ e)
    (vla-add (vla-get-hyperlinks (vlax-ename->vla-object e))
  (princ)
[/pcode]---------------------------------------------------
vl-bt
vl-bt-on
vl-bt-off
错误跟踪:
(defun c:ttt ( / *ERROR* )
(defun *ERROR* (ERROR )
  (vl-bt)
(+ 12 "asd")
运行后:
(vl-infp)
判断一个数是否无穷大?
譬如(vl-infp 333)  返回nil
(vl-infp 1e2222) 返回T
(vl-nanp)
(vlisp-* )是一系列函数
譬如vlisp-compile, vlisp-load-project
bherrs
In R14, (bherrs) could be used to check if the (c:bpoly) function
successfully generated a boundary.
fnsplitl
_$ (fnsplitl "c:\\path\\filename.ext")
("C:\\path\\" "filename" ".ext")
xstrcase
这个跟strcase有什么区别?
这些函数我暂时不知道它们的用法和用途,希望大家讨论一下,
待续...
评分
参与人数 1D豆 +5 收起 理由
炫翔 + 5 出题引导交流奖!
查看全部评分
发表于 2013-5-7 14:41:40 | 显示全部楼层
vlisp-compile 这个好像是用来命令行编译的
vl-init 大概是R14时用来初始化 Vl 环境的
发表于 2013-5-7 15:30:35 | 显示全部楼层
密切关注。
发表于 2013-5-7 19:24:24 | 显示全部楼层
*push-error-using-stack* (AutoLISP) 2014
Error-handling function that indicates the use of variables from the AutoLISP stack within a custom *error* handler.
                (*push-error-using-stack*)
Allows access to the local AutoLISP variables on the stack defined within the function where the error occurred from your                  custom error handler. A call to the *push-error-using-stack* function overrides a previous call to *push-error-using-command*.
If *push-error-using-command* or *push-error-using-stack* are not called, by default AutoLISP works as if *push-error-using-stack* was called.
NoteThis function cannot be used when the command function is used with in a custom *error* handler.
Return Values
A value of T is returned. [pcode=lisp,true](setq var1 "Global1"      ; Set some global variables
      var2 "Global2")
(defun mySub_err (err_msg)
    (if (/= err_msg "Function cancelled")
      (progn
        (prompt (strcat "\nError: " err_msg))
        (prompt (strcat "\nLocalSub1: " var1))
        (prompt (strcat "\nLocalSub2: " var2))
        (terpri)
    (command-s "._undo" "_e")
    (command-s "._U")
    (setq *error* olderr)
  (princ)
(defun subUtil (val / olderr var1 var2)
    (*push-error-using-stack*)         ; Indicates if the custom error handler has access to local
                                       ; variables defined in his function
    (setq olderr *error*
          *error* mySub_err)
    (command "._undo" "_group")        ; The following will not be executed in this sample, but is good
                                       ; framework for setting up your own error handlers
    (setq var1 "Sub1"                  ; Set some local variables
          var2 "Sub2")
    ;; Perform your tasks here
    (strcat "Foo" val)
    (command "._undo" "_e")
    (setq *error* olderr)              ; Restore old *error* handler
    (*pop-error-mode*)                 ; End the use of *push-error-using-command*
(defun my_err (err_msg)
      (progn
        (prompt (strcat "\nLocal1: " var1))
        (prompt (strcat "\nLocal2: " var2))
        (terpri)
    (command "._U")
  (princ)
(defun myUtil (val / var1 var2)
          *error* my_err)
    (*push-error-using-command*)       ; Indicate use of Command function instead of Command-s
                                       ; in the custom error handler
    (setq var1 "Local1"                ; Set some local variables
          var2 "Local2")
    (subUtil val)                      ; Call to a custom function that uses *push-error-using-stack*
    (/ 1 0)                            ; Call a function with incorrect values to trigger the custom error handler
                                       ; Remove when setting up your code
[/pcode]
这个错误处理函数怎么调用?有实例吗?  详情 回复 发表于 2016-6-2 14:30
发表于 2013-5-9 07:56:32 | 显示全部楼层
我也不知道 关注中
发表于 2013-5-9 20:44:07 | 显示全部楼层
非常赞的内容!
发表于 2016-6-2 14:30:32 | 显示全部楼层
Error-handling function that indicates the use of variabl ...
这个错误处理函数怎么调用?有实例吗?
GMT+8, 2026-11-22 09:04 , Processed in 0.477713 second(s), 24 queries , Gzip On, File On.
