楼主: eachy
2013-05-21 QQ群:ALISP&VLISP(143438137) 聊天记录:说说怎么画,想要什么
发表于 2013-5-21 11:42:07 | 显示全部楼层
也许沧桑(1436511711)于2013-05-21 11-42-07:
n -1
        zdjsc nil )
  (repeat aa
    (setq pts1(nth (setq n(1+ n)) cddj)
          pts2(nth (+ n 1) cddj)
          ljj1(nth  n ljj)
    (setq ljc(ljsc ljj1 pts1 pts2)
          zdjsc(append zdjsc (list ljc));交点集
  ;计算下端肋距实长
  (setq aa(length ljj)
        n -1
        xdjsc nil )
  (repeat aa
    (setq pts1(nth (setq n(1+ n)) xplist)
          pts2(nth (+ n 1) xplist)
          ljj1(nth  n ljj)
          xdjsc(append xdjsc (list ljc));交点集
  ;计算肋骨冲势、旋转角
  (setq pt11(nth zjlg splist)
        pt12(nth zjlg xplist)
        pt13(nth zjlg cddj)
        pt14(nth (- zjlg 1) cddj)
        pt15(nth (+ zjlg 1) cddj)
  (command "line" pt11 pt12 "" )
  (setq pl11(entlast))
  (SETQ N 0)
  (COMMAND "PLINE" (CAR cddj))
  (REPEAT (LENGTH cddj)
    (COMMAND (NTH (SETQ N (1+ N)) cddj))
  (COMMAND "")
  (COMMAND "pedit" (entlast) "f" f "")
  (setq pl12(entlast))
  (setq pt16(car (test pl11 pl12)))
  (entdel pl12)
  (if (> (abs (- (angle pt13 pt16) (angle pt13 pt14))) 0.8)
    (progn
      (setq pl13(ssname lgx (+ zjlg 1)))
      (setq lj1(nth zjlg ljj))
      (setq pt14a pt15)
    (progn
      (setq pl13(ssname lgx (- zjlg 1)))
      (setq lj1(nth (- zjlg 1) ljj))
      (setq pt14a pt14)
  (setq cc1(vlax-curve-getClosestPointTo (vlax-ename->vla-object pl11) pt13))
  (if (= (distance pt13 cc1) 0.0)
    (command "xline" (polar pt13 pi 500) cc1 "")
    (command "xline" pt13  cc1 "")
  (setq pl14(entlast))
  (setq pt17(car (test pl13 pl14)))
  (setq as1(lgsc pl13 pt14a pt17))
  (setq ss1(ljsc lj1 pt13 pt17))
  (setq ss2(ljsc lj1 pt13 pt14a))
  (setq pas(/ (- (+ (* ss1 ss1) (* ss2 ss2)) (* as1 as1)) (* (* 2 ss1) ss2)))
  (setq pad(sqrt(- 1 (* pas pas))))
  (setq ang (atan (/ pad pas)));求出的旋转角
  (entdel pl11)
  (entdel pl14)
  (setq ccs(/ (* (distance pt13 cc1) (distance pt13 pt17)) ss1));求出的肋骨冲势
(setq accs ccs)
  (setq ptt(getpoint "\n请指定插入展开图形的位置:"))
  (setq n -1
        ll 0)
  (REPEAT zjlg
    (setq ll(+ ll (nth (setq n(1+ n)) zdjsc))
  (setq n (- zjlg 1)
        ll1 0)
  (REPEAT (- (- (fix lgs) zjlg) 1)
    (setq ll1(+ ll1 (nth (setq n(1+ n)) zdjsc))
  (setq ptt1(list (- (car ptt) (+ ll ccs)) (cadr ptt))
        ptt2(list (+ (car ptt) (- ll1 ccs)) (cadr ptt))
  (command "line" ptt1 ptt2 "")
  ;求测地线坐标点集
  (setq n -1
发表于 2013-5-21 11:42:18 | 显示全部楼层
也许沧桑(1436511711)于2013-05-21 11-42-18:
;求测地线坐标点集
  (setq n -1
        po nil)
  (setq po(append po (list ptt1)))
  (repeat (length zdjsc)
    (setq pto(polar ptt1 0 (nth (setq n(1+ n)) zdjsc))
          po(append po (list pto));交点集
    (setq ptt1 pto)
  ;求中间肋骨上、下端点的坐标
  (setq ang1(- (/ pi 2) ang)
        ang2(+  pi ang1)
  (setq pts(polar ptt ang1 (nth zjlg sdjsc))
        ptx(polar ptt ang2 (nth zjlg sdjsc))
  (command "xline" pts ptx "");绘制法线
  (setq a1(entlast))
  (command"circle" (nth zjlg po ) (nth zjlg sdgsc) )
  (setq a2 (entlast))
  (setq ptss(test a1 a2))
  (setq ptss1(car ptss)
        ptss2(cadr ptss)
  (if(> (cadr ptss2) (cadr ptss1))
    (setq pts ptss2)
    (setq pts ptss1)
  (entdel a2)
  (command"circle" (nth zjlg po ) (nth zjlg xdgsc))
  (setq a2 (entlast))
        ptss2(cadr ptss)
    (setq ptx ptss1)
    (setq ptx ptss2)
  (entdel a2)
  (entdel a1)
  (command "line" pts ptx "")
  (setq szj(/ (* (angle ptx pts) 180) pi))
  ;求中间肋骨前的上、下端缝点坐标
  (setq pa1 nil
        n zjlg)
  (setq pt2 pts)
  (setq pa1(append pa1 (list pts)))
  (repeat zjlg
    (setq pt1 (nth (setq n(1- n)) po)
          pl1 (nth n sdjsc)
          pl2(nth n sdgsc)
    (setq pts1(dfjd pt2 pt1 pl1 pl2)
          pa1(append pa1 (list pts1));上端缝坐标
          pt2 pts1)
  (setq pa2 nil
        n zjlg)
  (setq pt2 ptx)
  (setq pa2(append pa2 (list ptx)))
  (repeat  zjlg
          pl1 (nth n xdjsc)
          pl2 (nth  n xdgsc)
    (setq pts2(dfjd pt2 pt1 pl1 pl2)
          pa2(append pa2 (list pts2));下端缝坐标
          pt2 pts2)
  ;求中间肋骨后的上、下端缝点坐标
  (setq pb1 nil
        n zjlg)
  (setq pt2 pts)
  (repeat (-(- (fix lgs) zjlg) 1)
    (setq pt1 (nth (setq n(1+ n)) po)
          pl1 (nth (- n 1) sdjsc)
          pl2(nth n sdgsc)
    (setq ptw1(dfjd1 pt2 pt1 pl1 pl2)
          pb1(append pb1 (list ptw1));上端缝坐标
          pt2 ptw1)
  (setq pb2 nil
        n zjlg)
  (setq pt2 ptx)
发表于 2013-5-21 11:42:28 | 显示全部楼层
也许沧桑(1436511711)于2013-05-21 11-42-28:
          pl1 (nth (- n 1) xdjsc)
          pl2(nth n xdgsc)
          pb2(append pb2 (list ptw1));下端缝坐标
          pt2 ptw1)
  ;求上端缝点坐标排序
  (setq pa nil
        n (length pa1)
  (repeat (length pa1)
    (setq pta(nth (setq n(1- n)) pa1)
          pa(append pa (list pta))
  (setq n -1)
  (repeat (length pb1)
    (setq pta(nth (setq n(1+ n)) pb1)
  ;求下端缝点坐标排序
  (setq pb nil
        n (length pa2)
  (repeat (length pa2)
    (setq ptb(nth (setq n(1- n)) pa2)
          pb(append pb (list ptb))
  (setq n -1)
  (repeat (length pb2)
    (setq ptb(nth (setq n(1+ n)) pb2)
  ;绘制上端缝
  (SETQ N 0)
  (COMMAND "PLINE" (CAR pa))
  (REPEAT (LENGTH pa)
    (COMMAND (NTH (SETQ N (1+ N)) pa))
  (COMMAND "")
  ;绘制下端缝
  (SETQ N 0)
  (COMMAND "PLINE" (CAR pb))
  (REPEAT (LENGTH pb)
    (COMMAND (NTH (SETQ N (1+ N)) pb))
  (COMMAND "")
  ;绘制肋骨线
  (SETQ N -1)
  (REPEAT (LENGTH po)
    (setq pt1(nth (setq n(1+ n)) pa)
          pt2(nth n po)
          pt3(nth n pb)
    (command "pline" pt1 pt2 pt3 "")
  ;打印型值
  ;旋转角
  (setq xzj(strcat "旋转角度:  "(rtos szj 2 1) "°   " "中间肋骨编号:" (rtos zjlg)"    ""中间肋骨冲势:  " (rtos accs 2 1)))
  (setq cd(- (length pa) 1))
  (setq zfg(/ (distance (nth cd pa) (nth cd pb))(* 2 (length pa))))
  (setq pt(list (car (nth 0 pb)) (- (cadr (nth 0 pb)) 200) 0))
  (COMMAND "text" pt zfg 0 xzj)
  ;打印上端缝肋距
  (SETQ N 0)
  (setq zf1(strcat " " "0"",  " (rtos(nth 0 sdjsc) 2 1)))
  (REPEAT (- (LENGTH sdjsc) 1)
    (setq xh(setq n(1+ n)))
    (setq zf2(strcat zf1 "   " (rtos xh)",  " (rtos(nth n sdjsc) 2 1 )))
    (setq zf1 zf2)
  (setq zf11(strcat "上端缝肋距展开值: " zf1))
  (setq pt(list (car (nth 0 pb)) (- (cadr (nth 0 pb)) (+ (*   (setq zf1 zf2)
  (setq zf11(strcat "下端缝肋距展开值: " zf1))
  (setq pt(list (car (nth 0 pb)) (- (cadr (nth 0 pb)) (+ (* zfg 4.5) 200)) 0))
  (COMMAND "text" pt zfg 0 zf11)
  ;打印上端肋骨展开值
  (SETQ N 0)
  (setq zf1(strcat " " "0"",  " (rtos(nth 0 sdgsc) 2 1)))
  (REPEAT (- (LENGTH sdgsc) 1)
    (setq zf2(strcat zf1 "   " (rtos xh)",  " (rtos(nth n sdgsc) 2 1 )))
    (setq zf1 zf2)
  (setq zf11(strcat "上端肋骨展开值: " zf1))
  (setq pt(list (car (nth 0 pb)) (- (cadr (nth 0 pb)) (+ (* zfg 6) 200)) 0))
  (SETQ N 0)
  (setq zf1(strcat " " "0"",  " (rtos(nth 0 xdgsc) 2 1)))
  (REPEAT (- zfg 1.5) 200)) 0))
  ;打印地线肋距
  (SETQ N 0)
  (setq zf1(strcat " " "0"",  " (rtos(nth 0 zdjsc) 2 1)))
  (REPEAT (- (LENGTH zdjsc) 1)
    (setq zf2(strcat zf1 "   " (rtos xh)",  " (rtos(nth n zdjsc) 2 1 )))
    (setq zf1 zf2)
  (setq zf11(strcat "测地线肋距展开值: " zf1))
  (setq pt(list (car (nth 0 pb)) (- (cadr (nth 0 pb)) (+ (* zfg 3) 200)) 0))
  ;打印下端缝肋距
  (SETQ N 0)
  (setq zf1(strcat " " "0"",  " (rtos(nth 0 xdjsc) 2 1)))
  (REPEAT (- (LENGTH xdjsc) 1)
    (setq zf2(strcat zf1 "   " (rtos xh)",  " (rtos(nth n xdjsc) 2 1 )))
  (LENGTH xdgsc) 1)
    (setq zf2(strcat zf1 "   " (rtos xh)",  " (rtos(nth n xdgsc) 2 1 )))
    (setq zf1 zf2)
发表于 2013-5-21 11:42:49 | 显示全部楼层
也许沧桑(1436511711)于2013-05-21 11-42-49:
这是一个船体外板展开的插件
发表于 2013-5-21 11:44:35 | 显示全部楼层
真爱一生(848758009)于2013-05-21 11-44-35:
高手呀[face34.gif]
已领礼包: 145个
发表于 2013-5-21 11:45:39 | 显示全部楼层
XDSoft(7598165)于2013-05-21 11-45-39:
贴群里面这么长代码,有必要吗
发表于 2013-5-21 11:46:30 | 显示全部楼层
真爱一生(848758009)于2013-05-21 11-46-30:
用手机上的就。。。。。
发表于 2013-5-21 11:50:02 | 显示全部楼层
长风(龙少)(8240891)于2013-05-21 11-50-02:
如何用lsp加载cui文件
发表于 2013-5-21 11:51:49 | 显示全部楼层
长风(龙少)(8240891)于2013-05-21 11-51-49:
如何用lsp加载cui文件
已领礼包: 208个
发表于 2013-5-21 11:53:42 | 显示全部楼层
xshrimp(23417151)于2013-05-21 11-53-42:
加载mns就好了.cui是自动生成的.
发表于 2013-5-21 11:54:20 | 显示全部楼层
长风(龙少)(8240891)于2013-05-21 11-54-20:
我想用lsp的一段代码来加载
已领礼包: 1742个
财富等级: 堆金积玉
发表于 2013-5-21 12:11:01 | 显示全部楼层
炫翔(2363673534)于2013-05-21 12-11-01:
LOAD
发表于 2013-5-21 12:24:14 | 显示全部楼层
_GX_飞毅(359170905)于2013-05-21 12-24-14:
牛逼啊~
发表于 2013-5-21 13:52:19 | 显示全部楼层
梦回唐朝(27184507)于2013-05-21 13-52-19:
签到
发表于 2013-5-21 13:53:00 | 显示全部楼层
龍(358666107)于2013-05-21 13-53-00:
签到
GMT+8, 2026-10-13 14:29 , Processed in 0.458608 second(s), 23 queries , Gzip On.
