查看: 1799|回复: 0
[分享] Insert Block from a different DWG using .NET
已领礼包: 593个
发表于 2013-5-25 02:40:18 | 显示全部楼层 |阅读模式
http://adndevblog.typepad.com/autocad/2012/05/insert-block-from-a-different-dwg-using-net-.htmlInsert Block from a different DWG using .NET By Virupaksha Aithal
Using the WblockCloneObjects() method, its possible to copy a particular block from a drawing in to the other drawing. The C# code snippet that shows how to use WblockCloneObjects to copy a specific block "test" from the drawing available at "C:\TEMP\test.dwg".
"C:\TEMP\test.dwg".
[CommandMethod("InsertBlock")]
static public void InsertBlock() // This method can have any name
    Document doc = Application.DocumentManager.MdiActiveDocument;
    using(Database OpenDb = new Database(false, true))
        OpenDb.ReadDwgFile("c:\\temp\\test.dwg",
            System.IO.FileShare.ReadWrite, true, "");
        ObjectIdCollection ids = new ObjectIdCollection();
        using (Transaction tr =
                OpenDb.TransactionManager.StartTransaction())
             //For example, Get the block by name "TEST"
             BlockTable bt;
             bt = (BlockTable)tr.GetObject(OpenDb.BlockTableId
                                            , OpenMode.ForRead);
             if (bt.Has("TEST"))
                 ids.Add(bt["TEST"]);
             tr.Commit();
        //if found, add the block
        if (ids.Count != 0)
            //get the current drawing database
            Database destdb = doc.Database;
            IdMapping iMap = new IdMapping();
            destdb.WblockCloneObjects(ids, destdb.BlockTableId
                   ,iMap,DuplicateRecordCloning.Ignore, false);
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力,资料分享奖!
查看全部评分
GMT+8, 2026-11-3 12:14 , Processed in 0.541309 second(s), 31 queries , Gzip On.
